Question about Epson STYLUS R230 InkJet Photo Printer
It's is asking service required,
And parts inside your printer are near the end of their service life.
This is message is comming, how can i do this problem, please tell me
Parts inside your printer are near the end of their service life. This is message is coming, how can i do this problem, please tell me
Posted on Sep 06, 2009
    President:
  • 566 Answers
Read this article:
Epson Ink Pads Reset Utility .
  1. Parts inside your printer are near the end of their service life. See your printer documentation
  2. what do solution plz......
5 Suggested Answers
MUKHTAR
  • 2022 Answers
SOURCE: Service Required Parts inside your printer are
Unplug the power and USB cables from the printer.
  1. Prepare your work area by putting scrap paper down. Have some spare, just incase. You may also require tissue paper. It is also recommended you use protective gloves as the ink will stain your skin for quite some time.
  2. Unscrew the screw at the back of the printer.
  3. There are two or three tabs at the back and two at the front. Gently push them in, and then using a bit of force pry apart the cover.
  4. At the back of the unit you need to locate some white pads, or sponge type things, initially they will seem fine, but they will infact be full of ink. You need to grab a pair of pliers and pull them out one by one, there should be four, put them on your scrap paper.
  5. Take the scrap paper with the pads on to your sink, turn on the hot tap and hold each one under the tap using the pliers until the water runs clear. If you have protective gloves on it may be worth squeezing the water out also.
  6. It is recommended that once you have done this, you let them dry.
  7. Now return the pads back into the printer.
  8. Put the printer back together, (mind out for the paper alignment, and give it some force), not forgetting the screw at the back.
  9. Plug in the USB and power cable and turned it ON. (Yes the lights will still flash)
  10. Download and install the SSC Service Utility for Epson Stylus Printers.
  11. Select your printer and model number (There is no Stylus C42 UX, so select Stylus C4x), then close the window.
  12. If it asks if you replaced with the pads; say "YES". Then close the window.
  13. You will see a SSC Service Utilitiy icon (it looks like a printer) in the system tray (next to your click), and LEFT click.
  14. A menu will appear, from here you can click on "Protection counter" (its a red cross), then "reset protection counter".
  15. Turn the printer power OFF, wait 10 seconds and then turn it back ON.
Hope this helps. Please rate my response.
Thanks.
Have a good day
Posted on Jan 03, 2011
  • 127 Answers
SOURCE: message: service required parts inside your
reset the waste ink tank counter here is a link for the software http://www.ssclg.com/epsone.shtml
Posted on Mar 31, 2010
SOURCE: service requires Parts inside your printer are
The Model p50 does not appear in scc service utility
Posted on May 13, 2011
Parts inside in my printer are near the end of their service life
A Service Error where you get a message telling you that "Parts inside your printer at the end of their service life, contact your dealer for replacement", or "Parts inside your printer require maintenance or replacement, call your service company", is normally a Maintenance Request Error. The maintenance request error is actually a Waste Ink Ink Pad Error and usually your remedy is:
1. Replace the Waste Ink Pad/Pads with a new one/ones (many people ignore this one, and they just follow #2)
2) Reset the Internal Waste Ink Pad Counter by using SSC Utility
Download from this site http://www.ssclg.com/epsone.shtml and follow instructions.
I hope this information will be helpful. Thank you for using FixYa!
Jun 08, 2011 | Epson Stylus Multifunction Inkjet Printer/...
Parts inside your printer are near the end of their service life. See your printer documentation. _ Epson R200 printer.
Regarding the Epson Artisan 800, I must thank FixYa and ask that the search for a solution be discontinued.Yesterday, I had an unfortunate accident while trying to unclog the print head which had been printing poorly over the last three months. I used a syringe to force a solvent solution through the clogged head. To my utter surprise the supply line exploded with a loud "POP" meanwhile spraying ink all over the place. At this point it was clear that it was pointless trying to redeem the old Artisan 800. Thank you FixYa. Henry.
Feb 27, 2011 | Epson Stylus Photo R200 InkJet Printer
Parts inside your printer are at the end of their service life. See your printer documentation.
Q: What should I do if my printer driver displays the message parts inside my printer are reaching their end of service life?
A: See the Epson Ink Pad Reset Utility page.
If your product is displaying an end of life service message, please view and complete the required information below to proceed.
Please explain the message I am getting in my printer driver that says parts inside my printer are reaching their end of service life.
Like so many other products, all Epson consumer ink jet products have a finite life span due to component wear during normal use. At some point, the product will reach a condition where either satisfactory print quality cannot be maintained or components have reached the end of their usable life. This is the normal product life cycle for highly mechanical devices like printers. This message is a warning that certain parts have reached the end of their usable life and that your printer will no longer work until it is serviced.
What parts are we talking about?
The message refers to the ink pads, which are actually a number of porous pads in the printer that collect, distribute, and very importantly contain the ink that is not used on printed pages. Ink is collected by these pads during the initial setup of the product, during cleaning cycles and when printing borderless photographs. Most users will not receive this message before the printer is replaced for other reasons. Some high volume users or those who use the printer for many years may receive this message about ink pads before other components reach the end of their usable life.
Why does my printer stop functioning when I get the message?
Epson is committed to ensuring the proper operation of all our devices to minimize the risks of property damage or personal injury during the lifespan of the product. The printers are designed to stop operating at the point where further use without replacing the ink pads could create risks of property damage from ink spills or safety issues related to excess ink contacting an electrical component.
Is there anything I can do to continue using my printer?
Epson recommends replacing the printer, but if you want to continue using it, Epson recommends having the printer serviced at an Epson Customer Care Center. You may also be able to have the ink pads replaced by an independent service provider and use the Ink Pad Reset Utility to reset the Ink Pad Counter to continue using the printer. Please note that replacement of ink pads is relatively expensive and may not be a good investment for lower cost printers because the printers' other components also may be near the end of usable life. Epson does not recommend ink pad replacement by users without technical training or resetting the Ink Pad Counter without replacing the ink pads.
Note: This utility is for Windows XP and Vista operating systems only. We hope to develop an option for Mac users as well; however, we do not have an ETA or the OS requirement at this time.
To download this utility, please complete all fields below, select the agreement check-box and click Download. Required fields are noted with an asterisk(*). Some models may require you to be redirected to another website to finalize the process.
Go here to complete the agreement and download the utility:
http://www.epson.com/cgi-bin/Store/support/InkPadsForm.jsp
Dec 09, 2010 | Epson Stylus 1400 InkJet Photo Printer
We're getting this Service Required message - Parts inside your printer are near the end of their service life. See your printer documentation. What part are we needing to replace?
the parts most likely to be replaced with such a message are the waste ink pads. (sponge pads that collect the ink that is used for print head cleanings). these pads are difficult to reach inside the printer (full dissassembly is necessary) and doing so is a VERY dirty job. i suggest contacting a repair center near you.
Sep 11, 2010 | Epson Stylus Photo RX600 All-In-One InkJet...
Strange message epson cx8400
Your printer needs to be reset, the part that is near the end of their service life is the waste ink pad, it means that it is almost full, when it's full your printer will stop printing.
Jan 11, 2010 | Epson CX8400 All-In-One InkJet Printer
Reset the waste ink counter!
Assuming you have completed your modification you can reset your printers waste counter using this method (I did this and it worked on the CX6400) can't guarantee it works on all)
1. You will see big button on your printer like power on (this is on the left
2. side), black & white photocopy, color photocopy, and then the stop button (these are on the right side).
3. first turn off your printer
4. push the b/w + color + stop buttons together and hold
5. push the power on button and hold (so you'll now be holding down 4 buttons together)
6. Don't release all the buttons until you see the light indicator is blinking and then a message display on the lcd
7. release all the buttons
8. push the color button (once)
9. turn off the printer
10. turn it on again
After this one may need to reload the printer driver and locate the printer!
May 27, 2009 | Epson STYLUS R230 InkJet Photo Printer
" parts inside your printer are at the end of their service life.
This usually happens when the waste pads become full and need to be replaced.
You can try to do it yourself like this guy did on his printer:
http://www.hm2k.com/posts/parts-inside-your-printer-are-at-the-end-of-their-service-life
you can actually just use the software to reset the printer but eventually the pads will overflow and start to leak.
The last option is too take it to Epson and ask for a quote.
May 14, 2009 | Epson Office Equipment & Supplies
EPSON PRINTER R22O
Hi-
yes actually there is. the parts its talking about is the inkpad, you can send this over to an epson certifies servicer in your are to have inkpad change and they will reset the counters for it. go this link and look for a servicer near your place
http://www.epson.com/cgi-bin/Store/support/SupportIndex.jsp?BV_UseBVCookie=yes
or you can contact epson at 562-276-1300
pls rate as fixya if helpful. thanks!!
Jun 21, 2008 | Epson Stylus 2200 InkJet Photo Printer
EPSON PRINTER R22O
display This massages Parts inside your printer are near the end of their service life.
Nov 08, 2007 | Epson Stylus Photo R320 InkJet Printer
Epson STYLUS R230 InkJet Photo Printer Logo
1,276 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
