Eureka Smartvac 4870 Bagged Upright Vacuum
Problem for Eureka Smartvac 4870 Bagged Upright Vacuum
Brush roll continue to turn while the vacuume is in the upright.
By pknakane on Sep 06, 2009
Is there any simple solution?
Solution #1
posted on Sep 06, 2009
Not Rated)
Chemist1961
Rank: Guru  Vacuums  Expert
Rating: 93%, 131 votes
Check to see the bare floor switch is fully engaged and the vac hose is in its socket as well
Was this helpful?
Yes
No
Popular Solutions for Eureka Smartvac 4870 Bagged
Questions and Unsolved Problems for Eureka Smartvac 4870 Bagged
Do you recommend Eureka Smartvac 4870 Bagged Upright Vacuum?
Answer
Answer
my belt doesn't engage when I try to sweep but when it's in an upright position the roller is... (More)
Answer
I have a Eureka Smartvac 4870 which has very weak suction both on the floor and with the hose. There... (More)
Answer
replacing motor in 4870, replacement motor slightly different, need wiring diagram......replacement... (More)
Answer
when putting the dial on carpet, the beater won't start. why???
Answer
brush does not turn and culprit seems to be that the barefloor /carpet switch will not stay in the... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Eureka Smartvac 4870 Bagged...:
Top Vacuum Experts
Rank: Guru Guru
Solutions: 1205
Experience: installed and repaired audio/video equipment for over 23 years at 2 colleges and 3 businesses.
Ask Me
Find more Vacuum Experts
Top Vacuum Repair
(877) 822-8227
When you browse our large selection by vacuum...
Vacuum Cleaner Shop
(502) 348-4900
Authorized Dyson and Miele Service center. Work...
VACUUM SOLUTIONS
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
