Question about Whirlpool Refrigerators
The ice door does not close so ice has formed inside the freezer, how do I get the fromt cover off to check the plunger to see if it is working to close the little door.
  • Whirlpool Master
  • 1,606 Answers
Remove the top freezer hinge cover and disconnect the plug there . This removes power to the door . Between the grill and the lower portion of the dispensor cover , at the inside bottom , use a butter knife and push down and inward , to force the lower portion of the cover out slightly . Do this on both sides , being careful due to plastic tabs can break , Once bottom is out , lift the dispensor cover upward to disenguage top plastic tabs . Unplug the cover from the plugin . Remove the 2 screws holding the dispensor housing and slide outward . This gives you access to the door flap , flap spring and pin . You will be able to see the problem .
Posted on Sep 06, 2009
Freezer frosts up to the point of not being able to open the door without ice falling on the floor. Can this be fixed?
Yes it can be fixed, This can be as simple as replacing the door seals if bad to replacing the defrost board.If the seals are good and the doors close and seal as they should then the defrost is not working properly.
Aug 25, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Frost forms on the inside opening of the chute for the water/ice dispenser. Also frost on the exit chute from the ice cube tray. The frost is present a day or so after I clean it off.
The door flap which releases the ice , on the door , is not closing completely .Usually this is caused by a rusted plunger so both the solenoid and plunger will have to be replaced , These parts are located behind the dispenser board so be sure to remove the top freezer door hinge cover and unplug the plug there , to remove all power going to the door , before attempting this repair . I think the part number is WR62X10055 for the kit .
When it doesn't close , it lets warm air into the freezer and causes frost on the dispenser AND on the ice bin outlet . Also , using 10 glasses or more , of crushed ice a day can cause this .
Aug 19, 2010 | GE Profile Arctica 25.4 Cubic Feet...
Our automatic ice dispenser hums but doesn't move ice through to be dispensed
Resolving the frost in shoot problem .
Remove the top freezer door hinge cover , and disconnect the plug there . This removes any power , going to the door . If no plug there , remove the bottom kick plate , by removing the screw on each side in the front , and disconnect the receptical from the wires comming from the bottom of the freezer door .
Remove the dispensor control board , by prying , or pulling , from the bottom of the board . Disconnect the 3 plugs to the board . You should now see the white dispensor cover , being held on by 4 screws . Remove these screws , and slide the cover out .
In the top right , inside the dispensor area , you will see a solenoid with a plunger , with the door flap arc , inserted into the plunger . Usually rust inhibits the movement of the plunger , keeping the door flap from closing completely .
Remove the 3 screws holding the plunger and solenoid ( part number WR62X10055 ) and replace . Cleaning will not help , due to rust will return .
Jul 28, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
The ice dispenser door stays open. Selenoid works
This is due to a rusted solenoid plunger .You will need to remove the top freezer door hinge cover ( 1 screw ) , and disconnect the plug there . This will remove power to the dispensor . Using a screwdriver , insert it just behind the dispensor board , and twist , to pry the board off . Remove the 3 plugs there , and remove the board . Remove the 4 screws on the white cover , and slide the cover out and off . In the top right , in the dispensor area , you will see the solenoid and plunger . 3 screws hold the solenoid on . Lift the flap , and the plunger will lift off . Part number for solenoid and plunger is WR62X10055 . The closing spring is probably good , and if you are pushing the flap closed , you are moving the plunger itself , instead of it gliding inside the solenoid , to the closed position .
Nov 06, 2009 | GE Profile PSW26P Stainless Steel Side by...
Frost inside the ice dispenser chute and the ice cube dispenser seems "stuck" on crush mode instead of dispensing full cubes.
The stuck on crush mode , is caused by ice frosted in front of the ice bin , blocking the ice bin flap from opening , when calling for cube ice . Removing the ice bin and cleaning or defrosting completely , will solve this problem , AFTER , resolving the frost in shoot problem .
Oct 10, 2009 | GE Refrigerators
Frost building up in ice maker exit shoot and
Look into the dispensor , and see if the door flap is closing , or letting warm air in which will cause the frost buildup . If not closing completely , remove the top cover on the freezer door hinge , and unplug the plug . This will remove power to the door . Use a small screwdriver , and insert under the freezer door dispensor control board , and pry outward . Remove the 3 plugs on the board . Next , remove the 4 screws holding the white dispensor cover , and slide outward . At the top right , you will see a solenoid and plunger , which control the door flap . Usually , this plunger rusts on the solenoid . Replace both , the solenoid and plunger ( come together in kit ) Pt # WR62X10055 . Re-assemble in reverse .
Oct 02, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Frost forming on top of inside door by hinge
you probably have an air leak. if the gasket is bad it needs to be replaced. Air could also be coming in through the door flap if you have water and ice dispensor on door
Sep 17, 2009 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Freezer door light switch sticks, have to pull on switch nob.
sand it with 600 grit sand paper. and spray some lube W-D-40 on it.
Jul 25, 2009 | Sub-Zero 690 Side by Side Refrigerator
Ice build up
Check that the door is closing properly otherwise the freezer will be working overtime to cool and ice will form. If the door seal is good, it is possible that the thermostat needs to be checked.
Oct 02, 2008 | Refrigerators
Refrigerators Logo
114 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
