Question about Dishwashers
Standing Water After running our dishwasher we have standing water in the bottom, it won't completely drain out. Thanks, ---Joe
  • NoDummy Jan 25, 2008
    we have the same problem. The drying cycle is complete. Lines are not clogged or kinked. How do you get to the filter to check it?
  • aauxier Mar 16, 2008
    after the complete cycle there is water standing in the bottom. How can I see if the drains or food traps are clogged?
    Problem Solver:
  • 17 Answers
Are you leaving it long enough to finish it's programme or are you opening it when the drying light is on as some dishwashers leave a bit of water in the bottom to help with the drying programme
Posted on Dec 11, 2007
Why is there water standing in the bottom of my dishwasher after it has completed the wash and dry cycles.......
If water remains in the dishwasher after the cycles end, check the kitchen sink drain to make sure it's not clogged. If there's no clog, try pressing the Cancel button; most dishwashers run the drain pump when the Cancel button is pressed.
Check the dishwasher drain line, drain path and drain pump.
Oct 25, 2017 | Dishwashers
Dishwasher won't drain completely. Several inches of standing water left after last cycle
Sounds like the wash/drain selector valve might be stuck. my Kenmore operating solenoid rusted and hung up. I cleaned and oiled it up. You can also have something that got into the valve and it won't close, or an obstruction in the drain hose or the drain pipe connector. Something is restricting the flow or the pump itself may have a bad impeller. Does it wash with vigor or has it lost a little oomph and sound different? Does it leave any debris on the dishes?
Jan 25, 2012 | Dishwashers
The dishwasher won't drain completely. Water is left standing in the bottom of the tub.
Hi
Dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. First make sure that the drain is not clogged and remove clogs if present. If no visible lint is present then remove the lower front access panel to check the drain filter and drain pump for any clogs, you'll need to clean the drain filter and drain pump completely. Also, check for any food pieces stuck near the pump impeller & clean the chopper assembly. Please note that dishwashers don't drain out the complete water such that heating element doesn't overheat. Hope this helps... Please post back for any further assistance.
Daniel
Aug 02, 2011 | Dishwashers
After drying there is water in filter trap is this normal
IF THE WATER IN PORTABLE DISHWASHER AT THE BOTTOM IS MORE THAN THE DRAIN HOSE FULL OF WATER THEN ASK WARRANTY PEOPLE. WHEN PUMPING WATER UP IT CAN ONLY PUMP SO MUCH WATER OUT OF HOSE BEFORE THE WATER DRAINS BACK INTO DISHWASHER.-- HOPE THIS HELPS
Mar 08, 2010 | Hotpoint 24 in. FDW60 Free-standing...
Tappan Dishwasher w/ Standing water
Try draino first then take it apart on the inside bottom to see what might be clogging it.
Aug 04, 2009 | Dishwashers
My Dishwasher works but still leaves some standing water.
Check the filter unit located at the bottom (inside) rear for clogging. Sometimes food will accumulate in the filter and not allow the unit to completely drain.
Jul 23, 2009 | Whirlpool 24 in. DP840D Free-standing...
Water in the bottom of dishwasher
try running it empty there is usually a drain hole in the bottom check if anything is in it or try a dish washer wash solution I bet the drain or drain line is cloged let me know if this dont work. Hows your sink draining
Feb 15, 2009 | Kenmore 17459 Free-standing Dishwasher
Not draining completely
always going to be some water left inside your d/w, cant pump it all out as long as its under the grate and not filling entire floor of unit i wouldnt worry, before each cycle its going to dicharge standing water anyway
Feb 23, 2008 | Admiral 18 in. DWCA500AA Free-standing...
try pressing the cancel/drain button.Do you hear water draining into sink freely?? if not i would disconnect drain undersink look for a clog right there first
Feb 22, 2008 | Kenmore 24 in. 17482 / 17484 / 17489...
Dishwashers Logo
633 people viewed this question
Top Dishwashers Experts
Oloyede Monsuru
Marvin
Marvin
