Question about Gateway 7405GX Notebook
I have a Gateway M-6843 Notebook PC that won't power up.
The power light comes on but the monitor is black can you help me fix this problem?
  • Gateway Master
  • 32,281 Answers
You may have a defective CCFL backlight, it may have the following symptom: Screen flashs on red/pink and off. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickering on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp.
Connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out
www.lcdparts.net
Posted on Sep 06, 2009
Audio codec for gateway M6843
K-Lite is the best and most powerful codec packs out there. Not to mention free.
Oct 01, 2012 | Gateway M-6843 Notebook
Gateway M 6843 won't turn on
You may have already done this, but remember many laptops require that you remove the battery for about 30 sec. as
well as disconnect the AC power to reset them.
Always try this when everything appears completely dead.
Source: pcsupport.com <<<and it's worked
Aug 28, 2012 | Gateway M-6843 Notebook
Gateway M-6843 wont turn on
Hi
What happens when you connect the charger and try to power it on?
Does it power on?
Try replacing the battery and see what happens.
Hope it helps.Thanks!
Feb 19, 2012 | Gateway M-6843 Notebook
Internal microphone not working on Gateway M-6843
First check the settings under Sound Settings of the Realtek HD sound Manager. If everything looks ok and it works with external microphone, then the problem could be Hardware problem which won't be fixed unless the motherboard is replaced.
In the meantime, I would also suggest you to uninstall and re-install the sound driver. By the way, what's the operating system installed on your laptop?.. Hope this helps.
Let me know if you need further help..
Good Luck.
Thanks for using FixYa.
Sep 06, 2011 | Gateway M-6843 Notebook
Please help. I want to reinstall the operating system and drivers from the recovery dvd disk for my Gateway M-6843 Notebook, but the DVD drive is not able to read and let the system to boot from the dvd.
if ur dvd drive is working, try this. go to ur bios and then the boot section, then keep ur dvd/cd drive in first priority then save and exit. shal work. its easier to reboot OS win7 with pendrive. download win7 USB download tool. install it, run the tool and proceed as it asks.
Dec 08, 2010 | Gateway M-6843 Notebook
I have a gateway M 6843. my scren freezes, lines appear
Sounds more like a loose video connector on the back of the screen.
Nov 13, 2009 | Gateway M-6843 Notebook
No Ethernet drivers
You can download the drivers for your model Gateway laptop from this
WEB site, make sure you select the correct XP or Vista drivers. Click on this link: -
http://driver-pro.com/related/english/hardware-drivers/?a=12221&gclid=COmm19XHtpwCFSMSagodPRuwnQ&hit=1
Need new DVD-rw the one that came with notebook M 6843 died it just spins and says no disc installed
there is one screw holding the drive in either on the bottom at the back of the dvd drive or under the keyboard. Once you remove it find the model number and check ebay.Order one and when it comes just slide it back in and screw it down
Jul 16, 2009 | Gateway M-6843 Notebook
Gateway 7405GX Notebook Logo
499 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
