Question about LG W1934S-BN 19" Monitor
Flatron W1934S screen has suddenly started to go bright pink
The entire screen (used as second monitor) has suddenly started to go bright pink when I turn it on.
  • 53 Answers
Clean the graphics card first
Posted on Sep 06, 2009
How do i increase my moniter brightness
assuming you know about using the buttons on the front and it has not worked i would guess the internal lamps are faulty you could just replace the monitor or try and repair it i have linked the service manual
Jun 12, 2014 | LG 19" Flatron W1934s-Bni LCD Monitor
My LG FLATRON W1934S was working fine last night. went to turn it on this morning and nothing happened. no orange or blue lights and it wasnt left in sleep mode either. what could be wrong with it?
I would suspect a problem in the monitor power supply, either a fuse or possible bad filter caps especially if you had to turn it on several times to get it on just before it failed.
If you are able to open it here is what bad caps look like:
Dec 17, 2012 | LG Electronics W1934S Flatron W1934S...
I v a 19" lg
Try changing a resolution of AU.
Or contact Adobe
Jun 08, 2011 | LG W1934S-BN 19" Monitor
Hi my LG w1934s LCD monitor suddenly not working it screen is full with color lines even I disconnect the VGA cable from the system unit the screen is not change the color lines are as it is what can I do...
That have not simple solution better take it to a tv repair shop, you already disconnect the data cable and discard the possibility of computer problem.
The Monitor must have in the menu a reset configuration option but I doubt it will help, its time to get it to a repair shop.
Mar 17, 2011 | LG Flatron L1951S 19" LCD Flat Panel...
What is the problem if my LG w1934s-BN LCD monitor when the color of the screen is pink ?
The reason for that is because the main board inside of the monitor is bad and since there are no parts for that monitor available you would need to replace the monitor. The main board controls the output of colors onto the lcd.
Sep 30, 2010 | LG W1934S-BN 19" Monitor
My lg flatron model w1934s was working fine but now it will not come out of power saving mode at all. What should I do?
Try turning it off and hold the power switch in for about a 30 seconds. This may help to reset the monitor. Afterwards, try and power it up again.
Oct 09, 2009 | LG Flatron L1951S 19" LCD Flat Panel...
Lg Flatron W1934S Moniter Problems
You could have a faulty inverter board or a faulty CCFL lamp. The inverter supplies high voltage to the CCFL lamp and the CCFL lamp is a mini fluro tube.
Have a look at LCD Patrs WEB site for service, parts and DIY info Use this link to their WEB site :-
www.lcdparts.net
Oct 02, 2009 | LG Flatron L1951S-SN 19" LCD Flat Panel...
Used as second monitor suddenly stared to go dark
If the screen is lighting up for a fraction of a second when you turn on & then goes dark, this indicates a fault either with the backlights on the screen or the inverter part of the monitor. You can check the backlights if you have access to a backlight tester, you need to remove the rear cover & connect the backlight cables into the tester, if this checks ok then look for a problem on the inverter board, checking the capacitors for any signs of distress.
Aug 11, 2009 | LG W1934S-BN 19" Monitor
What is the best method for cleanig a flatron
Take a clean cloth and spray some windex on the cloth and then wipe down the screen and it should come nice and clean. Never spray it directly on the screen cause if the liquid goes down inside of the screen then it could damage it.
Mar 01, 2009 | LG 22" FLATRON LCD Monitor
LG W1934S-BN 19" Monitor Logo
1,126 people viewed this question
Top LG Computers & Internet Experts
Michael Vincent Cruz
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
