Question about Dell Dimension E510 PC Desktop
Possible motherboard problem!
Power supply seems to check out. Green light on MB turns on. Amber light on power button use to flash slow. Now it flashes 3, sometimes 4 times when power up is attempted with no other result. My research informs me that a common problem with this computer is "bad solder connections" on the USB ports to the MB. Dell has not been much help, the PC is out of warranty!
  • 53 Answers
Try cleaning the mobo.. after that make sure that you have put it back in place.. avoid the mobo to be grounded on the chasis..make sure that all components is properly seated on the right place (im assuming that there is no faulty expansion cards)
Posted on Sep 06, 2009
Thought I should add more detail about what the laptop is doing. The laptop sat for a long time with a dead battery, because the power supply low voltage wire got chewed by one of our puppy's when it was...
from the web -
1 Removed the battery
2 Removed the AC power
3 Plugged in the AC power again
Note:- At this point the light from flashing amber light to solid green indicating AC Power
4 Plugged in the Battery
Note:- Solid green AC power light and Amber charge light
Oct 30, 2013 | Toshiba Satellite C655D-S5084 Laptop
E system 1212 Laptop won't switch on. Power
Laptops are so integrated that usually a system failure that involves power issues such as in your case where you cant get it turn on with anything on the screen mean the mainboard (motherboard) is damaged. This usually leads to buying a new laptop or paying for the board to be replaced which usually costs as much as the laptop.
May 12, 2011 | Computers & Internet
Does not boot at all!
Did you check the power supply on another system to make sure it is operational. have you reseated all the connections to the MB..
Does it post any info ? are there any Beep codes?.. Or just sit dead . If it is sitting dead all I can think is that it might be a Power-supply problem but if it powers up or beeps or gives a green light or amber light on the MB then it is some other problem
Sep 03, 2010 | ASUS MB P5KPL-CM C2D LGA775 INTELG31 ICH7...
Blinking amber light.I changed 2 motherboards out and still blinking amber. Changed the CMOS battery, same thing blinking amber. Swapped memory and removed all pci cards, same thing. The motherboard has a...
I'm not clear about the blinking amber light you are referring to. Is it on the computer or the monitor.
I checked Dell's web site for the service manual for this computer model, & found this document:
http://support.dell.com/support/edocs/systems/dim8300/sm/adtshoot.htm#1102195
If the blinking amber light is on the monitor, check the connection between it & the computer itself. Make sure the cable is not damaged & that it does not have any broken pins in the socket.
Dec 16, 2009 | Dell Dimension 8300 PC Desktop
Dell 4500 won't turn on,power light amber/green
Is the light more amber or more green? If you push the button and it goes amber, then you probably have a bad power supply. Try getting another power supply to test. If that doesn't solve the problem, then you probably have a bad motherboard.
Oct 22, 2009 | Dell Dimension 4500 PC Desktop
Dell XPS400 No Start!!
If you fan isn't turning like it should, it is definitely a power supply issue. Go out and purchase a power supply with 250-300 watts...thats a good standard wattage!!
May 12, 2009 | Dell XPS 200 PC Desktop
Dell Dimension 5150 automatically turns off
That flashing amber light is usually a sign the power supply is failed or is failing. I would suspect the power supply is the problem in yours. It is the better of the two problems connected with the flashing amber light..the other is motherboard is failing. Arrrr!
hope this helps (it takes a standard- oh say 350 watt 20-24 pin power supply unit.)
Hope an answer helps.
Please leave rating, thankyou
May 05, 2009 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Dell Dimension 8300 flashing amber power light and dead pc
it seems *********** board is having problem plz send it for servicing
Aug 08, 2008 | Dell Dimension 8300 PC Desktop
Dell SX260...Wont Boot...Power Button Flashing Amber....grrrr!
Try these (un order of degree of difficulty) 1. Try replacing the battery on the system board. it is  typically a CR2032 button-style battery. This helps if the computer has been off for a long time.  2. Make sure all dust has been blown or vacuumed out of the computer. 3. Check to see if the USB pins are bent inside the connector on the back and the front of the computer. Straighten if possible. 4. Remove add-in cards, fans, shrouds, and heatsinks, then check the system board for leaky or mushroomed capacitors. If you would like, this may also be a good time to see if the processor is seated correctly or possibly short-circuited (burned black on the bottom, burnt or missing pins, etc). If it is any of these, you may need a new system board (motherboard) 5. It may be that you need a new power supply. Do your best to make sure that it will fit your computer case and have all the power connectors you need; they are not created equal.
May 05, 2008 | Computers & Internet
Dell Dimension E510 PC Desktop Logo
78 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
