Question about Verizon Communications enV2 Cellular Phone
I dont know how to update my env2 firmware
How do i check if my phone runs through the same firmware as my brother's, and how do i update it?
LG env2 keypad is locked and I don't know the code or the phone number or if it still even has an active phone number. Help unlock the keypad please
if u didnt change the password its the last few numbers of your number and if you dont know your number go to the website it will tell you
Oct 11, 2011 | LG enV2 EnV-2 VX-9100 VX9100 Premium Pink...
Tried to print using my MFC-685CW. Was told that my ink cartridge was empty. Put in a new cartridge (LC51BK). Was told that the cartridge container was now empty. What to do?
STEP 1: Verify the firmware version of your Brother machine:
a. Press the OK key 2 times.
b. Press the UP ARROW (+) key 5 times.
c. Press the OK key 2 times.
The firmware version will be displayed on the LCD.
- If the firmware version is 1.01 or 1.02, go to STEP 2: Update the firmware of your Brother machine.
- If the firmware version is 1.08 or above, go to STEP 4: Toner usage and yields.
STEP 2: Update the firmware of your Brother machine:
A firmware update tool is available that will allow you to update your Brother machine with the most recent version firmware by downloading updates over the Internet. The updated firmware will assist in optimizing toner usage.
The Brother printer driver must be installed and working properly prior to the update of the Brother machine. The firmware update tool also requires that you have Java installed on your computer. The firmware update tool will not work if Java is not installed. If you do not have Java installed or are not sure if it is installed on your computer, you may download Java from http://www.java.com.
To update the firmware, follow the instructions listed below:
DO NOT interrupt the process or turn off the machine once the update has begun. Doing so may corrupt the memory on the machine and may require the machine to be serviced in order to correct the issue.
1. Open an Internet web browser and go to http://welcome.solutions.brother.com
2. Select your country and language.
3. Type in the model of your machine or select it from the appropriate section (Ex: HL3070CW in the Color Printer section).
4. Select Downloads.
5. Select your OS and language for step 1 and 2 on the web site. Click the Search button.
6. The Firmware Update Tool will be listed at the bottom of the web page. Click Information & Download.
7. Click the Download button and I Accept if you accept the license agreement.
8. A dialog box appears with options for Run, Save, or Cancel. Select Run. You may also download the firmware update tool for later use by selecting Save.
Nov 01, 2010 | Brother MFC-685cw InkJet Printer
There is no unlock options for my env2
check if your brother's phone and yours run the same firmware - if not update and all should have same settings.
Sep 01, 2009 | Verizon Communications enV2 Cellular Phone
Env2 charger wont fit in the hole and wont charge my phone
The issue is the charger port on the ENV2 breaks fairly easily. Thefirst step is to contact your carrier to see if it is covered underwarranty. If it is, great get it replaced.
If not, you have 3 options:
1. you can get the charging port repaired. The cost is about 50 dollars. I recommend Cellulardr.com
2. you can get a new phone. cost ???
3. You can get an external battery charger to charger the battery separatefrom phone. cost about 25 dollars. Check out the following link forones that are available on ebay. A extra battery is a good idea as well so you can have one charging at all times.
LG VX9100 ENV2 External Battery Chargers
Hope that helps
May 28, 2009 | Verizon Communications enV2 Cellular Phone
I can't hear people when I talk to them on the phone
When u can listen to music it's not hardware issue
1) Check the setting
2) Reset the unit
3) update the firmware
Hope it helps....keep the hope :)
May 20, 2009 | Verizon Communications enV2 Cellular Phone
Software update on Env2
One of the biggest problems with this phone is the OK button not working, and the front keypad doing the same eventually. Everyone I know with this phone has the EXACT same problem.
Mar 13, 2009 | LG enV2 VX9100 Cell Phone Car Charger
Can not connect to printer via ethernet since I did firmware update on Brother MFC 420cn
pal i dont know why u did the firmware update ...
contact the brother people they will be able to help u in the best way
Nov 01, 2008 | Computers & Internet
Verizon Communications enV2 Cellular Phone Logo
187 people viewed this question
Top Verizon Communications Cell Phones Experts
Computer Repairing
Computer Repairing
Laxman Bisht
Laxman Bisht
Are you a Verizon Communications Cell Phone Expert? Answer questions, earn points and help others
