Question about Saws
Blade and motor not stable after replace belts
I replaced the belts on my Ryobi table saw and trying to put it all back together. Something is wrong, as I can get the motor, drive and blade to be stable. As a unit, everything is tight, but the unit moves. Any thoughts?
  • 5,603 Answers
If you mean there is vibration that moves the unit, check thaat the bllade is PROPERLY indexed on the mandrel. Sometimes they can get off center.
Posted on Sep 06, 2009
Ryobi mitre saw jamming when cutting
There's a normal adjustment process of squaring the blade to the table, page 19 of your manual. If the blade is not square to the table then it will bind. Here's the link for the manual, see page 19.
http://manuals.ryobitools.com/system/files/400/original/TS1342_942_eng.pdf?2011
Dec 21, 2013 | Ryobi ZRTS1342L Factory-Reconditioned 14...
Ryobi TSS100L blade guard spring
I think what you are refering to is a circlip washer , and can only be
fitted with ( CIRCLIP PLIERS ) do you know any Michanics or Engineers as they are bound to have a set in their toolbox ,on the other hand you
can buy them. What they do is work in the opposit way normal pliers do
when you squees the handles together the jaws open,therefor opening
the (CIRCLIP ) and allowing you to place it over the pin and into the
recess. Hope this has been of some hellp goodluck T.C.
Mar 29, 2013 | Ryobi Saw. 13 Amp 10 in. Sliding Compound...
Bosch 4000 table saw run backward and slowly
I had the same problem with the Bosch 4000.
Changed the field for a new one...end of problem
Apr 28, 2011 | Bosch 4000 - 07 Electric Table Saws
How do you align the motor on an older (JET) JWTS-10 Table Saw. The manual does not go into it and I have looked inside the saw and can't find any way to align. The rear edge of the blade is out of...
Remove the drive belt, loosen the motor base bolts on the motor and put a straight edge on the outside edge motor pully rotate the motor till the straight edge lines up with the outside edge of the saw blade pully then retighten the motor base bolts and replace the drive belt.
May 11, 2010 | Jet 708100 Jwts 10 1 1/2HP Workshop Table...
I have a 10' Craftsman table saw model 315-218290. I ordered new belts I removed the motor how do you attach the belts, I tried to stretch it won't work
Jun 20, 2009 | Craftsman 10" Table Saw
Motor not working on Delta table saw: I just got a used Delta table saw for free, the previous owner said the motor wasn't working. I wonder if it could just be a switch... how could I check that? I also...
Ok, the motor turns, but throws sparks on the brushes. This is normal to an extent for universal motors used on that type of equipment.
Try reassembling the saw, and put a blade on it, then try it. If it runs, try cutting a piece of scrap 1x, both crosscut & rip. If the motor can't hold the load, you may still have to replace it.
Apr 16, 2009 | Delta 10"Hybrid Tablesaw with 30"Unifence
Ryobi bt 3000 table saw belt installation diagram
The BT3000 actually has TWO v-belts! Here's a link at the end of this solution to an exploded diagram. Basically you have a major disassembly, but it really isnt that complicated.
More great info on the BT3000 is available from the web site http://bt3000.com/
I have a BT3100 saw, and it is a good tool, but does require attention in maintenance procedures, but Ryobi did outline the necessary steps in their manuals. The above website also has the owner manual if you need one.
  1. Unplug saw
  2. Remove the blade
  3. Lower mechanism all the way to the bottom
  4. Flip over saw and lay on it's top
  5. Remove the blade guard panel opposite the motor
  6. Unbolt the motor assembly and remove the belt cover
  7. Replace the broken belts
  8. Re-assemble (be careful not to cross-thread the bolts in the aluminum housings!)
http://bt3000.com/Manuals/BT3000-Parts-Manual.pdf
Mar 18, 2009 | Saws
Blade does not turn
Disconnect the electric from the saw. Remove the throat blade cover. Bring the blade all the way up. Look for wood  caught between the blade and anything else. Finding none,remove blade. Try motor w/o blade. If it runs now,w/o the blade then the motor is likely ok . Reinstall blade. Now if it stil stalls, Replace motor.
Feb 11, 2009 | Craftsman 10" Table Saw
Saws Logo
109 people viewed this question
Top Saws Experts
Tom Chichester
ray gallant
Are you a Saw Expert? Answer questions, earn points and help others
