Question about Sherwood Scuba Diving & Snorkeling
Looking for a low pressure hose from regulator to bcd can I find one on line
  • 121 Answers
I just googled "scuba hoses online" and there's dozens of hits.. Give that a try, as long as you're happy to fit it yourself.
Barring that any dive should have them in stock..
Posted on Oct 20, 2009
Fuel pressure 1998 jeep grand cherokee 4.0 L V6
You should have a test port on the Fuel Supply rail, use a tool from a local auto parts "Tool Loaner program" where you can borrow tools for free,w/a deposit of course,then follow the steps provided;
MPI Fuel System Pressure Test
The MPI fuel system used in vehicles equipped with a 4.OL engine employs a vacuum balanced pressure regulator. Fuel pressure should be approximately 55-69 kPa (8-10 psi) lower with the vacuum line attached to the regulator than with the vacuum line disconnected. System fuel should be 214 kPa (31 psi) with the vacuum line connected to the regulator and 269 kPa (39 psi) with the vacuum line disconnected. CAUTION: Some fuel may be discharged when connecting fuel gauge to fuel rail.
  1. Connect a 0-414 kPa (0-60 psi) fuel pressure gauge to test port pressure fitting on fuel rail (Fig. 7).
  2. Remove vacuum line from pressure regulator.
  3. Start the vehicle.
  4. Note gauge reading. With vacuum line disconnected, fuel pressure should be approximately 269 kPa (39 psi).
  5. Connect vacuum line to pressure regulator. Note gauge reading. Fuel pressure should be approximately 214 kPa (31 psi).
  6. If fuel pressure is not approximately 55-69 kPa (8-10 psi) higher with vacuum line removed from regulator, inspect pressure regulator vacuum line for leaks, kinks or blockage. CAUTION: Fuel pressure will rise to as much as 655 kPa (95 psi) when the fuel return tine is pinched shut, shut engine down immediately after pinching oft fuel return line.
  7. If fuel pressure is low, momentarily pinch shut the hose section of the fuel return line. If fuel pressure remains low, inspect the fuel supply line, fuel filter, and fuel rail inlet for blockage. If fuel pressure rises replace fuel pressure regulator.
  8. If fuel pressure is above specifications, inspect the fuel return line for kinks and blockage.
Capacity Test
  1. Remove the cap from the pressure test port in the fuel rail.
  2. Connect a 0-414 kPa (0-60 psi) fuel pressure gauge to the pressure fitting on the fuel rail (Fig. 7).
  3. Start the vehicle. Pressure should be approxi- mately 214 kPa (31 psi) with the vacuum hose connected to the pressure regulator and 269 kPa (39 psi) with the vacuum hose removed from the pressure regulator.
  4. If the pressure is not to specification, check the following before replacing the fuel pressure regulator:
  • 4a - Inspect the fuel supply and return lines/hoses for kinks or restricting bends
  • 4b - Check the fuel pump flow rate. A good fuel pump will deliver at least 1 liter of fuel per minute with the fuel return line pinched off. If the fuel pump does not pump adequately, then inspect the fuel system for a plugged fuel filter or fuel pump inlet filter (sock). Fuel pump flow rate can be done by connecting one end of an old A/C gauge hose to the fuel test port on the fuel rail and inserting the other end of the hose into a container of at least 1 liter capacity. Run the fuel pump by installing a jumper wire into diagnostic connector terminals D1-5 and D1-6. Be sure to pinch off the fuel return line or most of the fuel will be returned to the fuel tank.
May 19, 2014 | 1996 Jeep Grand Cherokee
I have a 40000 btu all pro and it lights but the line freezes up and it starts throwing a large flame out, what is going on ?
Sounds like the regulator is bad or the tank is overfilled. The liquid propane is supposed to vaporize under high pressure within the tank, and the regulator lowers the pressure to feed the burner. It seems that your regulator is getting liquid and it is vaporizing at low pressure in the regulator. When the liquid vaporizes at low pressure it gets super cold.
Jan 26, 2014 | All-Pro Propane Garage Shop Heaters - All...
What regulator does a empire model 115 15000 btu take?
The regulator on the heater probably is not but is probably a device to prevent the heater being used unless the gas pressure is high enough and also serves to prevent air entering the gas line and also serves to arrest flashbacks.
The standard propane low pressure regulator is 14" water gauge but the heater might need a high pressure regulator. The best way to decide which type of high pressure regulator to use, because there are several, is to use an adjustable regulator.
After installing the adjustable regulator the pressure is increased until gas can be heard to be flowing and the heater lit. The regulator should then be adjusted to produce a clean flame of the correct length and then the regulator adjustment locknut should be tightened.
If the heater is to be used indoors it is important to ensure there is plenty of ventilation and the emissions are checked by a gas engineer.
Sep 06, 2017 | Empire Heating & Cooling
Excessive crankink time when car sits in heat for hours, otherwise ok
The first hing I would do is check fuel pressure with a fuel pressure gauge. Fuel pressure should hold steady. If it drops more than 10 psi in a couple of minutes than there is a problem with the fuel system.
Look on the fuel rail. if there are two fuel lines than look for a fuel pressure regulator mounted on the fuel line. It will have a vacuum hose going to it. remove the hose. if you see fuel coming out of the regulator replace it.
If there is one fuel line than the regulator is part of the pump assembly. Replacing the fuel pump assembly will resolve the fuel pressure drop.
there could also be an injector leaking. Typicall the engine will run rough at start up until that cylinder clears out.
Aug 12, 2013 | 2002 Jeep Grand Cherokee
Low Fuel Pressure
You might have a clogged fuel line or filter. Maybe a bad fuel pump.
Aug 28, 2012 | Nissan Quest Cars & Trucks
Exhaust pipe is blowing out a mist of black smoke
BLACK EXHAUST SMOKE IS A RICH FUEL MIXTURE.CAUSE BY WEAK SPARK IGNITION, FAULTY MAP SENSOR CHECK MAP SENSOR VACUUM HOSE AND ELECTRICAL CONNECTOR BECAUSE BAD MAP SENSOR WILL CAUSE RICH FUEL MIXTURE CHECK THE VACUUM LINE GOING TO FUEL PRESSURE REGULATOR, MAKE SURE FUEL PRESSURE REGULATOR GETTING VACUUM AT VACUUM LINE IF NOT LOOK FOR BROKEN OR DISCONNECTED VACUUM LINE TO FUEL PRESSURE REGULATOR, CHECK FUEL PRESSURE REGULATOR VACUUM LINE IF YOU SEE GASOLINE IN VACUUM DIAPHRAM TO FUEL PRESSURE REGULATOR REPLACE FUEL PRESSURE REGULATOR,CHECK THE EVAP CANISTER IF GAS SOAK IT WILL CAUSE RICH FUEL MIXTURE.
Aug 05, 2011 | 1995 Chevrolet Blazer
On a 99 Olds Alero, in the return lines of the power steering hoses, which place does the high pressure hose attach to?
RETURN TURN LINE GOES TO THE LEFT OF RACK PINION AND HIGH PRESSURE HOSE GOES TO THE RIGHT OF RACK PINION.LOOKING AT POWER STEERING PUMP HIGH PRESSURE HOSE THICK HOSE SCREWS INTO POWER STEERING PUMP.WHILE LOW PRESSURE HOSE HAS A HOSE WITH A CLAMP THE LOW PRESSURE HOSE HOOKS TO TOP OF POWER STEERING PUMP.LOW PRESSURE DONT SCREW INTO POWER STEERING PUMP IT IS HELD IN PLACE BY A HOSE SMALL CLAMP.
Jun 24, 2011 | 1999 Oldsmobile Alero
1996 Ford Ranger 4X4 4.0L V6 Manual Trans. Replaced Catalytic and rear O2 Sensor. Throws a Code P1131. Sprayed Carb Cleaner along as much of Air intake as I could, no change in idle. Where should I be...
The first thing i would do is check the fuel pressure it should be 35-45 psi with key on engine off,because low fuel pressure will cause this code too.Also check fuel pressure regulator pull vacuum hose off and if there is any fuel in hose replace regulator.
Apr 22, 2011 | Ford Ranger Cars & Trucks
It missing sputtering blowing out carbon from tailpipe
SOUND LIKE VACUUM LEAK AT INTAKE MANIFOLD LOOK FOR STUCK OPEN PCV VALVE OR LEAKING EGR VALVE GASKET.CHECK MAP SENSOR VACUUM HOSE MAKE SURE ITS CONNECTED AND GETTING VACUUM OR CHECK FOR A DISCONNECTED ELECTRICAL CONNECTOR AT MAP SENSOR.IF ALL LOOK GOOD CHECK FUEL PRESSURE SHOULD BE 40 - 50 PSI FOR 98 TO 2001 CADILLACS WITH 4.6 ENGINES CADILLACS 92 TO 97 MODELS WITH ENGINES 4.9 TO 3.8 FUEL PRESSURE 41 - 47 PSI. THATS YOUR FUEL PRESSURES WITH NEW FUEL FILTERS.IF FUEL PRESSURE WAY LOW FUEL FUEL PUMP WEAK.IF FUEL PRESSURE GOES HIGHER THAN NORMAL OR SEE GAS IN FUEL PRESSURE REGULATOR VACUUM LINE.FUEL PRESSURE REGULATOR IS FAULTY.WEAK IGNITION COIL OR COILS BAD PLUGS WORN DISTRIBUTOR CAP AND ROTOR WILL CAUSE SPUTTERING.
Oct 15, 2010 | Cadillac Brougham Cars & Trucks
Hey guys, im confused... i want to buy my new diving gear and i have come to a conclusion between two packages... these are : Scubapro : 1st stage din/int Mk17/395 reg + Oct R295 + seac sub BCD (First) +...
Denx7d could have not said it any better i have about 1300 dives on my gear and still in good shape and have annual service on my gear now i am a certified repair technician for scuba pro these regulators they sell are the best on the market hands down
Jan 21, 2010 | Scubapro MK11/R395 Regulator SCUBA...
Scuba Diving & Snorkeling Logo
91 people viewed this question
Top Sherwood Scuba Diving & Snorkeling Experts
Bill Boyd
ray gallant
Are you a Sherwood Scuba Diving and Snorkeling Expert? Answer questions, earn points and help others
