Question about ATK Wenonah Fisherman Rx Royalex 14 Foot Canoe
I gave a Wenonah royalex canoe that needs some bootom repairs and a repaint. I would like to do this myself. What materials will I need and where can I buy them?
    Novelist:
  • 269 Answers
Bullseye trading post appears to be offline, and in any case a proper answer depends on what kind of repairs are needed. Is it just a few scratches? A severe crack? What is it?
Posted on Jul 06, 2013
    Problem Solver:
  • 12 Answers
Try www.bullseyetradingpost.com they have a repair kit for plastic canoes and are working on a skid plate kit, as far as paint try krylon fusion you may have to repaint every now and then.
Posted on Dec 11, 2009
  • 2,418 Answers
Not sure what materal it's made from but I would try a Fiberglass mess  bond-o patch. You can mix your own with Fiberglass matt and a bond-o resin. See  http://solutions.3m.com/wps/portal/3M/en_US/Marine/Home/
Posted on Sep 06, 2009
Replace vinyl gunwales on canoe
Usually from the manufacturer, but ask at local dealers or canoe-repair shops and they may know of sources of the correct thing for your boat, or at least a workable substitute.
Mar 23, 2014 | Boating
Approx 2 wide by 7 inch long gash in starboard side at the waterline
That's a pretty serious size gash to repair. I'd contact Old Town Canoes to see it that material can be plastic welded and if so, where to get the materials. Good luck.
May 09, 2011 | Old Town Predator K140 Angler...
My tripper has the bow worn down by constant running on ground and hitting rocks. What materials do I need and how do I repair it?
Try bullseyetradingpost.com they were working on a skid plate for poly plastic canoes e-mail and ask for help! they were very helpful with solving a few seat problems for me.
Aug 05, 2010 | Old Town Tripper Canoe (17' Royalex(R))
How do I fix my badly faded canoe, colour is red and only faded down one side?
I would recommend painting it with a type of paint that would adhere to the material the canoe is made of whether that is aluminum, fiberglass, etc. My guess is that you have been leaving only half of the canoe in the sun, so when you store the canoe, either keep it in a shaded area or cover it with a tarp to keep the sun off.
Jun 06, 2010 | EA Sports Pelican Int'l. Colorado 15' 6"...
Royalex canoe -wood trim. I live in Canada down to -35F. this winter. I forgot to loosen screws ongunnels. I now have completely through vertical cracks through screw holes in royalex. Suggestions?
Are there washers on the plastic side of this boat? You could get some stainless finish washers to grab the plastic instead of just the screw head. I'm not really sure what you have there without seeing it, If it is that bad, you could also take another piece of wood, to match the gunwale on the outside and put one on the inside. Then drill some neat holes and run screws into the thicker one. I have a strip canoe, with the 2 gunwales, and have no problems with draining the boat or anything like that. Of course we don't freeze down here.
Feb 10, 2010 | Mad River Canoe Boating
How to repair an open split in a royalex canoe
key the surface using sandpaper to make it rough, and apply a fibreglass matting repair. They are available in kit form from canoe outfitters, often sold a kicker plates.
The application is very simple, just follow the kit instructions.Be aware though that the boat has to be perfectly dry before you start. (leave it indoors for a couple of days first) I often use a hairdryer on the surrounding area for a few minutes beforehand to ensure no moisture is present. Be careful not to get the area too hot though, you don't want to melt your boat!
Once the kit is applied and has set you can smooth the edges down with a sander.
Aug 09, 2009 | Boating
Canoe has damage on the front bow.
Bondo would probably work.
Also, you could laminate a few pieces of something like vinyl siding/facia board over the hole. If the canoe is ABS, the vinyl siding cold be "welded" / fused to the ABS with PVC primer & solvent/cement.
May 27, 2009 | Coleman Cable Coleman Inflatable Boat...
Wenonah Sundowner ABS Canoe repair
no actually you can't.. but heres an idea. get a couple pieces of gum, and flavor you like, and chew it up till its super duper sticky, then take it out of your mouth and stick it in the hole :) and thats its done,
Apr 12, 2009 | Boating
Small crack in hobie kayak
what is the canoe made of... it may not look pretty but fiberglass will work.... you can sand and paint it later as well
Mar 26, 2009 | Hobie Mirage Outfitter Kayak
Popular canoe material
ABS, or acrylonitrile butadiene styrene, has earned a reputation among canoeists for near indestructibility. It is one of the most damage-resistant canoe materials in use today. Badly dented hulls, even those that have literally been bent around a rock, have been restored to their original shape, without cracks or leaks, by the application of heat. Canoeists have dubbed ABS craft "rubber boats" and with good reason. Since the material tends to flex slightly, it is forgiving, tending to slide over rocks, or bounce off them, with little more than a surface scratch. Some of its limitations are marginal buoyancy - it will float when capsized but just barely, so don't expect to climb into a swamped ABS canoe to await rescue, or to hand-paddle it ashore. Also, when wet, the floor of an ABS canoe is slippery, which can prove troublesome in rapids. ABS canoes require little maintenance and can be left outdoors all year - although ones with wooden gunwales and peaks should be propped to avoid ground moisture. ABS canoes also require special epoxy resins for repairs.
Dec 01, 2008 | Advanced Elements Straitedge Canoe
ATK Wenonah Fisherman Rx Royalex 14 Foot Canoe Logo
387 people viewed this question
Top ATK Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you an ATK Boating Expert? Answer questions, earn points and help others
