Question about Video Game Consoles & Games
Want to get on internet got wirles but cant get my ip adress?
Want to get on internet got wirles but cant get my ip address where can i get it?
  • 20 Answers
Ugh.... XP , Vista, 7 or Mac?
Posted on Sep 07, 2009
I P ADRESS FOR MIVAR TV
To have an IP address, your TV must be connected to a home network or the internet...Is your TV a internet-enabled TV?Then there are three ways..
a) On the TV, go to network settings
b) From your router, check the DHCP table of the clients, if your TV is connected to your network, its IP should be listed.
c) Visit IP-details.com and get the IP.
Mar 01, 2014 | ip-adress.com
IR 22 30:HOW TO PUT IP ADRESS? i whant to
the easiest way is to print out a function list on the copier it should give the ip address on the list then open internet browser and input the ip address in the browser nd change the ip address there dont forget to make the ip address static hope you come right
Feb 19, 2011 | Canon IMAGERUNNER 2230 Copier
Can you tell me what an ip addresse is im trying to connect to xbox live and it keeps asking for ip addresse
Every device connected to the public internet is assigned a unique number known as an internet protocol (IP) address. IP addresses consist of four numbers separated by periods(also called a 'dotted-quad') and look something like 127.0.0.1
since these numbers are usually assigned to internet service providers with region based blocks, an IP address can often be used to identify the region or country from which a computer is connecting to the internet. an IP adress can sometimes be used to show the users general location because the numbers may be tedious to deal with, an IP adress may also be assigned to a host name, which is sometimes easier to remember hostnames may be looked up to find IP adresses,and vice-versa. at one time ISPs issued one IP adress to each user. These are called static IP addresses. beacuse there is a limited number of IP adresses and with increased usage of the internet ISPs now issue IP adresses in a dynamic fashion out of a pool of IP addresses (using DHCP). these are referred to as dynamic IP addresses. This also limits the ability of the user to host websites mail servers, ftp servers, etc. in addition to users connecting to the internet with virtual hosting,a single machine can act like multiple machines (with multiple domain names and IP addresses).
Jan 30, 2010 | Microsoft Xbox 360 Elite Console
Cant get on the internet
Check ethernet card, do a loopback test, run winipconfig or ipconfig release and renew, reboot modem and repeat steps good luck
Apr 22, 2009 | Computers & Internet
Cant connect to http://192.168.0.50
what you need to do here is manually set your static IP adress, I had this problem as well and I know what to do.
you need to go to your network connections ( Controll panel>network connections) in xp (Controll panel>network and sharing center then left hand it sais: change adapter settings )
then rightclick your wireless connection and look at it's properties. then you need to click on Internet Protocol, for vista/windows 7 it's internet protocol 4 which you need to select. once selected click on properties just a little below.
there you'll see the setting is on: obtain Ip automaticly, but you'll have to choose ( use the following IP adress ) and enter
IP adress: 192.168.0.99
subnet mask: 255.255.255.0 Default Gateway: 192.168.0.50
once entered press OK and now go to your browser and type the routers adress (192.168.0.50) in my case and now you should be in your modems setup menu.
once changed your setting you need to change your IP back to auto obtain IP adress. or your internet still won't work
Oct 20, 2008 | D-Link AirPlus Xtreme G DWL-2000AP...
Cant get online ip adress
my problem is that i cant get an ip adrees through my comcast internet .
Apr 19, 2008 | Video Game Consoles & Games
Driver help...Anyone?????
For Router drivers is not required ,U can configure though the command prompt
I can tell some configuration try it,
the default ip adress of the router will the 192.168.1.1 OR 192.168.0.1
In your Lan card configure,
1. obtain Ip adress automitically
go to command prompt----type ---ipconfig---check the ip address which ip is getting---
go to internet explorer ----type the ip address in adress bar-----------login page will get---
login as, user name admin
password admin------configure your internetip adress & DNS ip address,save & check.............
Mar 21, 2008 | Actiontec GT704WG Wireless Router...
Signing in
Connect it to your router with an ethernet cable.
Make sure the router is setup correctly to your modem, if you can connect all your devices by ethernet cable to the internet then it's set.
If you are using a wireless connection and if it asks for the WEP or WPA key, make sure that you are entering the correct encryption key. You may want to call your router manufacturer to know the correct key for the wireless connection. FYI, it will say that the wireless network is connected but it will still fail the IP Address.
If you have a wired connection and the IP Address or DNS failed, I suggest you to call your Internet Service Provider to check for the Internet connection and obtain these (static IP address, subnet mask, default gateway, primary DNS server and secondary DNS server). If your Internet is okay, enter the IP settings manually on the console (System > Network Settings > Edit Settings > IP settings).
That should work.
Feb 22, 2008 | Microsoft Xbox 360 Console
No ip address
you install your network card driver 1st.
then go to your network properties .....set as ip adress 192.168.0.1
then press tab.....then set as internet properly.
Feb 18, 2008 | Dell Dimension 2350 PC Desktop
Video Game Consoles & Games Logo
37 people viewed this question
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
