Question about Mitsubishi HC1600 Projector
What should the projector settings be if connected to a hp laptop.. and how?
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 149 Answers
The projector is capable of 1280x1024 and 1280x720. That is great for HD and gaming! Look on the function keys...An example would be F4 or F8...There will be a symbol of a TV screen. Press and hold the "alt" button and then press the key with the symbol on it. That tells the laptop to send the video display to an external display. You should see it on both your laptop and projector. Press the buttons again, ONLY the projector will have the image. A final press of the buttons will return you to laptop-only viewing.---rick
Posted on Sep 08, 2009
My hp m3222 projector is not working with my laptop via USB cable
The USB connection only allows the projector's remote control to be used as a "mouse" to advance presentation slides on the PC and perform some other limited functions. The USB connection cannot be used to feed video or other signals to the projector. Refer to the operation manual here:
HP mp3220 series User Manual
Feb 26, 2015 | HP Hewlett Packard MP-3222 Compatible...
When i plug my projector into my laptop the screen on laptop goes black
Depending on the windows and your computer, your settings may have the laptop's monitor shutoff when connected to an external device such as a projector. You need to find the settings and use (i believe its called something like) dual screen mode. I had to do this for my hp laptop with windows 7. Feel free to write me back.
Feb 17, 2011 | Dell 1510X Projector Projector
I need to be able to connect my hp pavillion to a projector to display a power point presentation. What is the correct process?
Usually all one has to do is power up the projector, then while the laptop is turned off, plug the projector into the VGA port, boot the laptop, and there it is.
If that doesn't happen for some reason, you'll have to go into display settings and make the projector the primary display.
Nov 29, 2010 | HP Pavilion dv6000z Notebook
I've connected my laptop to the projector. It displays the image for a second and then displays 'Analog RGB searching'
Try setting the projector to VGA instead of RGB input if you can, you should be able to toggle though input modes.
Make sure that the resolution of the laptop is equal or lower to that of the projector.
Jan 28, 2010 | HP Digital Projector Vp6120 Multimedia...
HP Elitebook 2730 s video problem
Connect the s-video to your projector.Restart your laptop.Sometimes you have to restart the computer so your video detects the new connection.You can also try and check the video settings to see if you can get the laptop to detect the new connection.
Sep 04, 2009 | HP EliteBook 2730p Notebook
Cannot see videos when connecting my HP laptop to Panasonic proje
this is mostly due to the laptop screen resolution please change the resolution by the below step by step procedure.
right click desktop -> properties -> settings->screen resolution.
did this information help?
Mar 27, 2009 | Dell Inspiron E1705 Notebook
Unable to transmit image to projector
Usually you can use a VGA connection cable to connect your computer with a projector. They also have inputs for s-video and RGB but these are much rarer on computers. Once you have connected the projector press the key on your keyboard that looks like a square with two lines on either side (mine is FN+F4) This will shuffle through different setups (mirrored to screen, extended to screen and back to normal) if this doesn't work try plugging in the vga cable and restarting the computer with the projector on.
Jan 06, 2009 | HP Pavilion dv4000 Notebook
Connecting cinego projector to hp laptop
don't know much about the cinego ( resolution ect)
but on most laptops you will have a "F" button or function key near the top row.. mine is F5 that has 2 square icons to show 2 monitors, 1 black, 1 white, when your projector is hooked to your laptop, hold down the FN key probably lower left or right, and tap the F5 or f7 which ever has the 2 montiors on it, it should be a 3 position switch, 1..laptop only, 2 laptop and projector, 3rd position projector only.
that cingo is pretty low-end so you may have to goto display properties on your laptop and reduce the resolution to 800 x 600 or 1024 x 768.
if you can't get a setting that works, try the 3rd position with just the projector display on, and laptop display off, since your laptop screen is higher resolution it corrects a lot of issues.
Jul 14, 2008 | Radio Shack Cinego D-1000 Multimedia...
Hp vp 6210
connect the laptop with projector and power up the projector and select the input 'computer' now start the laptop. the Projector will automatically detect the signal. secondly also chek with the display setting set to 800x600 then check with higher resolution.
Mar 28, 2008 | HP VP 6210 Multimedia Projector
HOW TO CONNECT MY PROJECTOR TO MY LAPTOP?
I have hp laptop with hdmi & vga, sharper image projector with rca connector what do I need to connect these two
Dec 22, 2007 | Philips cBright XG2 Multimedia Projector
Mitsubishi HC1600 Projector Logo
64 people viewed this question
Top Mitsubishi Office Equipment & Supplies Experts
Martin Murray
Are you a Mitsubishi Office Equipment and Supply Expert? Answer questions, earn points and help others
