Question about Kenmore Elite HE4 Electric Dryer
Water is not draining F1 code appears - Kenmore Elite HE4 Electric Dryer
  • 10,515 Answers
This means you have an internal short in the machine control board. There are 2 control boards if you take the console off--- the one on the right is the motor control board and the one on the left is the machine control. The part runs about $200 for the part alone.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Sep 06, 2009
What does the code F1 means?
On Fisher and Paykel.
F1 on a fisher paykel is in fact a water/flooding issue. But in your case you said it was running fine at the old location and now you have problems. Just be sure of a few hings.
1. The drain hose does not rise above the machine.
2. The drain hose doesn't just run straight down from the bottom of the machine.
Make sure your drain hose is mounted at a level that is a little above the middle of the dishwasher. High hoses cause back flow and too low of hoses can cause constant draining.
I think you may be constantly draining the machine. just be sure the hose is positioned correctly let it come from the bottom of the machine rise almost to the top and then back down. in a hump shape. (this should be mounted like this from the factory on the side of the machine but just check to make sure.)
Also be sure your water is on. I know this sounds obvious but it happens more often than people think. The f1 code could be coming from you not getting any water in the machine. There is a water level sensor built into it. and if the water valve is open for a while and then detects no water after a while it will throw the f1 code. mainly because the machine thinks its filling but the water level sensor says its not therefore the machine thinks it is leaking out.
Check your water.
Check your hose.
Check to make sure there isn't anything plugging the hoses.
Check that there isn't any water sitting under your machine by all its motors and wires.
Check that you have it level
If all this checks out good then you may have an actually problem machine. But i think its just fine. You may have just overlooked a step while installing it. get it all adjusted and you'll be golden. Hope this helps you!
Aug 11, 2015 | Dishwashers
Why does a fisher and paykel DD-603 randomly gives f1 code even when not in use
Fault code F1 can come from a number of different sources and can remain on as long as the machine has power (does not need to be operating). Once a fault is repaired it can be cleared by pressing the Power button. If the fault is still present then it will not
clear. The service manual says: The faults are displayed in the LCD as one of 5 F (fatal) faults or 1 U (user) fault along with the symbol of a spanner. A fatal fault will usually require the assistance of a qualified service person...
Fault Code Description:
Fault Code: F1
LED Display: Rinse LED
Fault: The flood switch has been activated for more than six seconds
Possible Causes
_ Inlet hose to inlet valve connection loose
_ Inlet valve body leak
_ Damage to the fill or drain hoses
_ Heater plate damage (chipped enamel)
_ Seals/O Rings (pinched, contaminated or poor join)
_ Dispenser (seal, diverter valve or weld leak)
_ Lid area (lid motors not functioning correctly, lid off yoke or foreign object interfering with lid seal)
Fault Code Problem Solving:
    1.Question: Is there a F1 on both displays? Yes: Go to Question 2. No: If power fails to the bottom tub it will cause thetop tub to go F1. Test heater plate.
    2.Question: Has a flood occurred? (N.B. The flood may have dried up) Yes: Go to Question 3. No: Go to Question 13
    3.Is the lid sealing on the tub correctly? Yes: Go to Question 5. No: Go to Question 4
    4.Question: Are the lid actuators functioning correctly? Yes: Go to Question 5. No: Check the lid actuators are assembled correctly on the slides and yokes. Check the plugs on the RFI board and the terminals on the lid motors. If the lid actuators look slow replace them.
    5.Question: Is the water level in the tub high? Yes: Go to Question 6. No: Go to Question 8
    6.Question: Is the water inlet valve leaking? Yes: Replace inlet valve. No: Go to Question 7
    7.Question: Is the DishDrawer priming correctly? Yes: Go to Question 12. Go to Question 8
    8.Question: Is the spray arm split? Yes: Replace spray arm. No: Go to Question 9
    9.Question: Is the spray arm running freely? Yes: Go to Question 10. No: Check the rotor is running freely, clear of foreign objects and fitted correctly. Make sure the wash impeller is not slipping off the rotor shaft.
    10.Question: Is water leaking from a split inlet or drain hose? Yes: Replace split inlet or drain hose. No: Go to Question 11
    11.Question: Is water leaking around the heater plate 'O' rings? Yes: Replace or refit 'O' rings. No: Go to Question 12
    12.Question: Is the drain hose blocked? Yes: Clear drain hose of blockage. No:Go to Question 13
    13.Question: Is there condensation or foreign matter around the flood switch PCB? Yes: Clear flood sensor of condensation or foreign matter. No: Go to Question 14
    14.After clearing water does the F1 fault code still activate? Yes: Replace Chassis RFI board. No: Go to Question 15
    15.Refer to Bulletin DW028 DW025, 028, 031, 040
Sep 06, 2014 | Fisher and Paykel 24 in. DD603H W Built-in...
Error F1 on sansung dishwasher
F1 fault code is an indication that you have a water leak. Before calling in a professional, try to troubleshoot the problem on your own. Many times it can be something as simple as a leaky hose, a broken seal or a blocked drain hose causing the F1 error.
Additional details and codes in Samsung/DMR57-00026A_EN.pdf
Hope helps.
Jun 18, 2011 | Samsung DMR57LF Builtin Dishwasher
Fisher& paykel F1 Fault code
F1 means u have a leak on the machine somewhere. they leak from , lid, drain hose , lid activatiors, the leak has flood sensor to come on. to stop the F1 code u have to repair leak. please reply 4 more help.
Apr 25, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
DISHDRAWER IS SSHOWING FAULT CODE F1. WHAT ARE THE
F1 means the flood switch has been activated. here is a trouble shooting flow chart.
1. did a flood occure? yes. q-2 or no q-12
2. is the lid sealing on the tub correctly? yes Q-3 no=Answer
3. Is there a high water level in the tub. Yes-q4 no q-6
4. is the water valve leaking? yes=Answer no-Q 5
5. Is the dish drawer priming correctly? yes q-11 no q-6
6. Is the spray arm split. yes=answer, no q-7
7. is the spray arm running freely. yes q-8 no q=answer
8. is the water leaking from a split inlet or drain hose? yes = answer, no q9
9. is the water leaking around the heater plate or o rings. yes=answer, no q10
10. carroy out more testing to locate the source of the leak.
11. drain hose may have been blocked or partially blocked.
12. is there water or condensation around the chassis flood switch pcb.
13. if power fails to the bottom tub, it will cause the top tub to f1
Jan 04, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
TOP DRAWER WAS NOT DRAINING..NOW THE F1 ON BOTH DRAWERS IS ON
F1 code indicates a leak,you will find the water under bottom drawer.Lid probably not sealing well.
Jun 17, 2009 | Fisher and Paykel 24 in. DD-602 Built-in...
Fisher Paykel F1 error / double dishwasher drawer
F1-water on bottom of dishwasher. Uselly it cost by broken drain hose. Need expert tech to fix the problem.
I’m happy to help further over the phone at https://www.6ya.com/expert/vitaliy_f406165329c75ede
Dec 01, 2008 | Fisher and Paykel 23 in. DD-603SS Built-in...
CODE F1-1 STOVE MAYTAG GIMENI/ WHIRLPOOL S/S NO ICE TO ICE BUCKET
Sorry i still have this problem with code f1-1 appears on the screen panel especially when it get warm or hot and still need help. thanks
Aug 08, 2008 | Kitchen Ranges
Fisher and paykel dd-603ss
F1 is a flood code meaning excessive amounts of water have collected on the bottom catch basin. If a flood condition is detected, both draws will activate the drain motors and flash F1. Remove the bottom drawer and dry the catch basin.
There are three possible scenarios; 1. Defective lid motor(s)...Each drawer has two lid motors that pull the lid tight to the drawer when the cycle is started. (this was very common on early models) 2. Something too tall was placed in the drawer preventing the lid from closing completely. OR 3. (only seen this once) the drain hose developed a crack causing water to leak only when draining. Hope this helps....
Jun 06, 2008 | Fisher and Paykel 23 in. DD-603SS Built-in...
F1-6 Fault Code
This code is in responce to a fault/failure in the lower keypad assembly. It is possible the keypad was bumped.
Maytag Gemini fault codes.
Fault code Suspect area Fault code Suspect area
F0 - 0 None
F1 - 1 Runaway cook upper oven
F1 - 2 Runaway cook lower oven
F1 - 3 Runaway clean upper oven
F1 - 4 Runaway clean lower oven
F1 - 5 Keypad cancel upper
F1 - 6 Keypad cancel lower
F1 - 7 Keypad disconnected
F1 - 8 Keypad shorted
F1 - 9 Slave
Dec 29, 2007 | Maytag MER6769 Gemini Electric Kitchen...
Kenmore Elite HE4 Electric Dryer Logo
37 people viewed this question
Top Kenmore Dryers Experts
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
