Question about Gateway GTW-P42M303 42 in. Plasma Television
Gateway GTW-P42M203, tv inputs as well as
Gateway GTW-P42M203,(not 303) tv inputs as well as component inputs all display a full screen scrambled picture. Audio is fine. On screen menu looks fine. I connected a laptop to the RGB input and it looks beautiful. I've removed the back and have noticed a few swollen capacitors on the Main Power Assy. board at locations C8099, C8100, C8101. I see no burnt connectors and haven't searched for any bad solder joints. Would those caps cause that problem? Strange that RGB input looks just fine.
Thanks for any help. Awesome site.
  • necrobiker
    necrobiker Nov 27, 2012
    I had the same exact problem except I only had two swollen capacitors (c8099, c8100). I replaced both and now I have a picture with the other video inputs but it is shaky. Small words like are in the credits are almost unreadable. One of the capacitors that I replaced didn't get pulled all the way tight against the board since the old solder kept getting hard and I was afraid that I was going to get the board to hot. Could that have an effect like that? Should I replace c8101 even though it doesn't look bad?
    Brigadier General:
  • 8,619 Answers
Hi
Yes you are right, this issue can be because of swollen capacitors. Also check for bad solder joints. It seems that you have electrical expertise and know how to solder/desolder components so that should not be a tough job for you. Usually the issue is there because of cold solder joints/swollen capacitors.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Posted on Sep 06, 2009
  • necrobiker
I picked up a gateway GTW-P24m303 for free from a friend. The unit powers on, but I just get the occasional flash of static, nothing more. The capacitors look good, but I don't have the equipment to...
The main tv Tuner signal board it the causes and the problems,it have ICS and some components are short in the circuits somewhere.Try website like Ebay.com to a whole refurbish main Tuner signal board for the replacement.This problems could be any components parts and ICS dies on the main tv Tuner signal board,best just replaced the whole board because tries to troubleshoot,u have to know alot of electronic theories and components functions to repair it.
Jun 07, 2011 | Gateway GTW-P42M303 42 in. Plasma...
I have a gateway 50 inch plasma tv that flickers. It started off with only flickering a short time but as time went by it would not stop. The flickering get less pronounced but will not go away. I have all...
hello. The problem you are having has haunted Gateway ever since they went into the television business. Here is a link to an article about the issue. http://www.techdirt.com/articles/20051214/0211209.shtml
Getting back to your set, I would definitely not put one penny into a repair. Instead, cut your losses and upgrade to digital, right now the prices are shockingly low. good luck with it.
Oct 15, 2009 | Televison & Video
GTW-P42M203 shut off and will not stay on
Chances are there are cracked solder on one of the boards. This is a common problem with Gateways. If you're handy with soldering then this is an easy fix.
Jun 30, 2009 | Gateway PLSM42TV 42 in. HD-Ready Plasma...
The screen on my Gateway Plasma 42 in TV went blank tonight. There is sound.Model GTW-P42M203. We purchased it in 2003.
I have over 10 years experience in electronic tech support.
I know this isn't what you want to hear, but the problem you've described can't be fixed with troubleshooting. Your TV will have to be repaired. There is a part that has developed a defect and needs to be replaced. The question will be, is the part still available? Before paying a TV repair person $75+ to diagnose the problem, ask yourself if you're willing to pay $250 minimum to fix this particular set. Also keep in mind that most TVs that old have a very limited number of replacement parts still available. Normally it will cost at least $75 to have the set looked at by a repair shop (diagnostics). If the part needed to complete the repair isn't available, you won't get that money back.
I hope I've provided you useful assistance and that this information allows you to make an informed decision as to how to proceed from here.
Please let me know if I can be of further assistance.
Jun 18, 2009 | Gateway GTW-P42M303 42 in. Plasma...
Black lines across the screen gtw 42'' plasma
Hello mohunters, Dave here! sounds like you may have a bad Y drive. If your still in need of help with the repair of your Gateway plasma TV feel free to give me a call or message me. @ 1-503-432-9904 / pleasefixitdave@yahoo.com Ask for Dave! Talk to you later buddy!
Dave, :-)
Dec 29, 2008 | Gateway GTW-P42M303 42 in. Plasma...
Gateway gtw l17m103 light out
For the solutution repair of the Gateway Model GTW-L17M103 TV 1/2 lit screen - I was told by a local authorized Sanyo Flat Screen Repair shop that the lamp or bulb is going out and needs to be replaced. He said the replacement would run around $125. I have the same problem as well and now am seeking to purchase a lamp/bulb.
Dec 17, 2008 | Gateway LCD17TV 17 in. Television
GTW-P42M203
Has the childlock function been activated?
Sep 10, 2008 | Gateway GTW-P42M303 42 in. Plasma...
Weird problem not convergence
Mine is doing the exact same thing! have you found a fix yet?
Apr 23, 2007 | JVC AV-48WP74 48" Rear Projection...
Gateway GTW-P42M303 42 in. Plasma Television Logo
142 people viewed this question
Top Gateway Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Gateway Televison and Video Expert? Answer questions, earn points and help others
