Question about GE Washing Machines
Drum Gasket in GE front load is a design flaw
I have had my GE in Front Load for 2.5 years a chunk in the drum gasket appeared and my husband ordered a new gasket for $150 and attempted to replace it. What a nightmare. Sounds like a defect in the product design. Anyone have any tips how to install the gasket?
  • fixrguy May 11, 2010
    send me your model # of the unit located in the area of the front door and msg me back I'll see if I can guide you..............
  • Grace Mainhood Nov 16, 2012
    my front loader bellow has seperated from the drum twice now , first time it was still on warrenty we had it repaired byGE now we havent been able to even find the part for it.
    President:
  • 704 Answers
Since each model can be slightly different and without your particular model number, you might want to confirm that the gasket you have is the correct one for your particular washer.
I'd suggest you call the folks at Sears Parts Direct at 1-800-252-1698 and give them your complete model number AND serial number before you start in on the repair, so you can be sure you have the correct bellows gasket.
It's a relatively easy repair, all you need to do is remove the spring retaining wire around the outer edge of the bellows gasket, just peel it back at the edge to see it. Now locate the locking loop by going around the rim. Once you find the locking loop, you can remove it using a couple pairs of small needle nose pliers as they make it easier to get off.
Once you've done that, you'll see the locking plate that holds the back side of the bellows gasket onto the outer washer tub. Remove those fasteners and you can get the bellows off and start in on putting the new bellows onto the washer, just reversing the order you used in the removal process.
Here's a line drawing that shows the exploded view of a tub section, with the gasket (item #306). Just take your time removing the old gasket so you remember what you're doing and when installing the new gasket so as not to rip or tear it in the process. I'd also suggest you let the gasket relax for a good 4-5 hours (to get the kinks and folds out of it from the packing box) before you do the installation.
http://www.searspartsdirect.com/partsdirect/getSubComp.pd?modelNumber=WCVH6260F0WW&productCategoryId=0153200&brandId=0432&modelName=WASHER&diagramPageId=00004&componentDescription=TUB%20&%20MOTOR&documentId=G6090505&backToLink=Return%20to%20Sub%20Components%20list
If you enter in your model number, you can see the line drawing for your particular washer and verify you have the correct part.
Here's another link to one of my other solutions for installing a bellows gasket on a GE front loading washer that you can also review for more installation tips, etc.
http://www.fixya.com/support/t2730376-need_help_in_installing_door_bellow_ge
Hope you find this Very Helpful and best regards!
Posted on Sep 17, 2009
    thankyou for the information, this will make my repair 100 times easier
My ge front load washer has a substantial leak when it is running. it is leaking from the bottom of the unit. It is not the drain hose or a clog in the drain. But it leaks like crazy PLEASE HELP
Check the door gasket for rips. Also there is a gasket between the two halves of the the outer drum, check that for leaks. Look at the pump housing and the hose that connects the pump to the drum for leaks.
Aug 27, 2010 | GE WSXH208A Front Load Washer
Smell from water remaining in grey seal
My GE washer model wcvh6400j0ww was leaking. May be standing water under your machine. The repair person thought the gasket. It turned out to be the water in-let pipe (WH41X10118 and you will need seal WH41X10119) and not the gasket. He ordered the gasket and took machine apart to replace and found cracked pipe. Take your machines front off and make sure it is the gasket leaking. Good Luck,
Jul 13, 2010 | GE Energy Star WCVH6260F Front Load Washer
GE Profile front loader washing machine is leaking front of door, believe the problem is the rubber washer ring, however can this be replaced?
Hello, this is usually the door seal, most machine incorporate a one piece combined door seal and outer drum seal(often just called a DOOR GASKET), the door seal are put in on the front panel first in the factory, then the drum assembly is put in and the seal pushed over the outer drum. This means a lot of stripping down has to be done just to replace the drum to the door seal.
Thanks
Jun 14, 2010 | GE WSXH208A Front Load Washer
My dryer squeaks upon starting to dry a load of clothes...everything else works fine except it squeaks the whole entire time. Any advice?
GE dryers have a straight rod in the back center of the drum that goes through the rear bulk head and that is what supports the drum in the rear, it is also what squeaks when it gets warn out , around that short rod that goes into rear bulk head from the drum is a black Teflon plastic sleeve called a barring replace it and that will fix the noise
Apr 05, 2010 | GE DVL223EBWW Electric Dryer
Rubber Gasket Torn
IT IS EASY :
1- IF YOU SUCCEED TO TAKE OLD gasket YOU CAN DO IT FOR THE NEW ONE
2- IT IS JUST A RUBER PEICE SO YOU CAN
3- LIKE YOU SAID a {spring securing OR CLAMP } USING A SMALL TOOL {SCREWDRIVER OR BLAYER } TO DISCONNECT THIS SECURING PIECE IN FRONT THEN
4- FLAP THE RUBBER TO INSIDE THE DRUM THEN
5- THERE IS ANOTHER SECURING PIECE HOLD THIS RUBBER WITH DRUM INSERT YOUR TOOL AND DISENGAGE THEN
6- NOTICE THE TRIANGLE IN THE RUBBER PIECE
IT IS THE MARK TO CONNECT AGAIN IN RIGHT WAY OR YOU CAN MARK BY A PEN
7- REVERS THE MANAR
YOU WILL REACH
GOOD JOB
Jun 18, 2009 | LG Washing Machines
Front load washer- coin removal
Hi, The coin is probably inside the baffle that tosses the clothes around. I believe this nodel has a screw that holds the baffle in place. I hope this helps you. Please let me know if I can assist you further.
Thanks
Vic
May 28, 2009 | GE WSXH208A Front Load Washer
THANK YOU!
Same problem here and Ge refuses to fix no charge it is clearly a recall sitition they are trying to avoid the drum is out of round on ours only 1 1/2 years old smoke was actully coming out of it does someone have to have a fire b-4 it is recalled ( or how Many fires will it take ) Very unsafe !!!
Dec 28, 2008 | GE Energy Star WCVH6260F Front Load Washer
Washing Machines Logo
258 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
