Question about Whirlpool Washing Machines
What type of gear oil does whirpool top load washer transmissions use?
  • 415 Answers
If you go to the part select web or sears website just order I don know if this oil is non-detegent type or not and just order the oil
Posted on Sep 06, 2009
After some loads, what appears to be gear oil (about 8 or 10 streaks of it) shows up on the inside of the agitator. I thought it was just years of buildup, so i cleaned it and ran through a small load. ...
GE washers are notorious for transmission leaks. Personally, I wouldn't spend much time or effort on a major repair of a 14 year old washer. Suggest you contact a local parts house and see if the upper seal is available as a kit. Other sites suggest that this transmission is no longer available new, and even then it's a $250 part. If you ruin one load of clothes with transmission oil, you're probably halfway to the price of a new one.
Apr 19, 2017 | GE WWRE6260D Top Load Washer
Washer not spinning during rinse cycles. The motor is running fine, you can hear the motor running but when you open the top the washer is not spinning. Open the top then close again and the washer starts...
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.#######) and you'll see a list of major sub-components with diagrams and parts.
The Kenmore / Whirlpool top load uses a reversing motor to initiate the pump for draining and the transmission to spin.
If it will drain but won't spin the problem is likely in the transmission. "Neutral Drain Assembly".
See the Whirlpool / Kenmore Service manual for top load direct drive washers.
WHIRLPOOL INST AND MAINTENANCE INCLUDING HOW TRANSMISSION WORKS
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
WHIRLPOOL TRANSMISSION DESCRIPTION AND SPRINGS
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/2550f737b3129b0c85256b0600504738/$FILE/787772%20%234.pdf
Those cams/gears etc. in that assembly keep the washer from spinning until all of the water is pumped out and then go into spin mode.
When ours had a similar problem, (We had to raise and lower the lid two or three times) we looked at the transmission parts list (available on a number of sites) and on the Whirlpool site (Whirlpool makes Kenmore) and noticed that the one of the cams in the neutral assembly which is supposed to have a small spring, didn't on ours when we tore the transmission apart again Apparently, the torque from the motor when raising and lowering the lid was enough (sometimes) to let the cams/gears connect.
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Repair%20Part%20List%20-%20W10114743.pdf
Found the part number for a kit (Whirlpool part number 388253 Neutral Assembly) for $15.00 and replaced the cams and gears.
In order to get the transmission out, you have to remove the cabinet, the fabric dispenser and both agitators. The top agitator uses a plastic 1/2" drive bolt (a 1/2" socket extension works well).
You don't have to remove the drum.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=137
Lay the machine down (after disconnecting power and hoses, remove the pump (two clips), the motor (two screws hold two clips on the motor), lift and set the motor aside.
Remove two 1/2 inch bolts for the motor mounting plate and three 1/2 inch bolts for the transmission.
Pull the transmission, remove the clutch (there is a spring clip that holds the clutch on the main agitator shaft), remove the 8 screws carefully the transmission holds 15Oz of 80-90 weight gear oil (auto parts store for non-detergent oil), remove the clip holding the main spin gear on and check the plastic cams.
If the cam that should have a spring doesn't, or the others look damaged, or the main spin gear is damaged the washer won't go into spin mode.
If that's the problem, install a Neutral drain kit, put everything back together carefully and the problem may be solved.
As an aside, fixing ours cost less than $30 including 80-90 weight gear oil vs. $170 for a new transmission.
May 14, 2010 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Change motor coupling clothes still come out wet kenmore elite top load
That could be the clutch or it might even be the main drive gear inside the transmission. Both are very easy to replace. Does the inside of the washer case have oil? Thats a sign of a leaky transmission cover seal. 0d4e74a.jpg The clutch lining comes out real easy with pliers making it easy to clean. The whole clutch comes off easily so you can inspect the main drive gear and pinion. My brother had to put that in his washer recently. No big deal. I have photos and manuals HERE
Apr 24, 2010 | Kenmore 22642 Top Load Washer
NEED TO KNOW THE TYPE OIL IN THE TRANSMISSION OF WASHER
First, see the Sears parts site for your washer.
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?modelNumber=+110.26912691
You'll see part numbers and prices for oil.
When we had to tear out transmission apart (3 times) we did some research and found that basic 80-90 weight non-detergent gear oil (available much cheaper than Sears oil at most auto parts stores) works for these transmissions.
Jan 26, 2010 | Kenmore 24032\24036 Top Load Washer
Kenmore commercial washer making grinding noise
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?modelNumber=110.82403140
Also see the Whirlpool / Kenmore service manual for top load direct drive washers.
See the following for how to remove the cabinet, pump, motor and transmission. YOU DON'T HAVE TO REMOVE THE AGITATORS OR TUB.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=137&osCsid=1051095663c7f2d5997fa53b976529d6
I had the same problem with major gear grinding during the spin cycle and this solved it.
Within the transmission are a set of plastic cams that raise the agitator gear when moving into the spin cycle. If the cams are worn, the gear won't lift high enough (about 1/18") and the gears will grind.
Assuming that you know how to remove the cabinet, agitator (you don't need to remove the tub), pump, motor and transmission the agitator cam and follower use the same whirlpool part number 62580/01. This is a plastic set used to raise the agitate gear on the shaft.
I had the same problem with gear grinding and this solved it.
Pull the transmission.
Remove the clutch (the spring holding the clutch to the spin pinion is a bear to replace.
Remove the 8 transmission screws carefully, the transmission is full (15 oz.) of 80-90 weight oil.
Remove the transmission cover.
Pull off the spin pinion.
Push down on the agitate spring and remove the spring clip. Note where is attaches to the main shaft.
The two plastic agitate cam parts pull right off. Don't lose the washer on top of the cams.
Replace the cams, washer, spring and clip, pinion, oil (assuming you drained the oil first), cover and clutch parts.
Line up the transmission so that the release cam on the brake drum will snap onto the clutch spring retaining clip and put all parts back in the washer.
The basic tools are screwdriver, small socket set with up to a 1/2" socket, vice grips or good pliers (to remove and replace clips)
Be sure to align the holes on the Motor Coupler correctly or the motor and transmission won't fit together correctly.
Following is also the Whirlpool parts list for their commercial top load direct drive washers that has a better description of the cams.
It is a bit of a messy job but much ($10 vs $170 for a transmission) less than having a service person replace the transmission.
Be sure to study the Service manual so that you can see exactly how the cams work.
While you've got the motor and transmission out, you should check the Motor couplers for wear.
Jan 23, 2010 | Kenmore Washing Machines
I have a Kenmore 80 series washing machine and the spin cylcle isn't working. There is a loud grinding noise during the spin cycle and the tub doesn't spin.
Enter your model number and you'll see a list of major sub-components with diagrams and parts.
This also assumes that:
1. The machine will agitate and go through the rest of the cycles.
2. It will pump out the water.
3. Since it tries to spin, the Lid Switch is OK.
The problem points to the clutch and / or transmission
See the following for how to pull the clutch on Kenmore top load direct drive washers.
If the clutch springs and pads seem OK, the problem points to the main spin gear inside of the transmission. If the clutch springs and/or pads are damaged, there is a rebuild kit for them.
Following is the Whirlpool / Kenmore installation and maintenance PDF on how their top load, direct drive, neutral drain washers work.
Here is another PDF of the Whirlpool parts list for their commercial washers, consumer models are basically the same.
If you look at the operation PDF you'll see how the transmission works when going into the spin cycle. If the "Neutral Drain" cams are intact, they drive the main spin gear which drives the spin gear connected to the clutch.
If the main spin gear is broken (It's a metal plate surrounded by plastic gears) you would hear a major grinding noise and the washer wouldn't spin.
Opening the transmission is not difficult but is a messy job. It holds about 14Oz. of oil.
Pull the transmission, remove the clutch (there is a spring clip that holds the clutch on the main agitator shaft, remove the 8 screws carefully the transmission holds 14Oz of oil, remove the clip holding the main spin gear on and check the plastic cams.
If the main spin gear or neutral drain assembly cams are damaged, they aren't too difficult to replace.
The Whirlpool Parts PDF has part numbers for both.
The Neutral drain assembly costs about $15 which is a lot less than $170 for a new transmission.
The Main spin gear is quite a bit more but still less than a transmission.
Oct 12, 2009 | Kenmore 24032\24036 Top Load Washer
Agitator not agitating whirlpool quiet care 11 about 9 yrs old
Please see the Whirlpool installation and maintenance PDF on their Top Load, Direct Drive washers.
If this is the type of washer that you have, I'd pull the cabinet and check the Motor Coupler.
Following is a description of how to do it.
http://www.fixya.com/support/r385250-replacing_motor_coupling_kenmore_top
If it isn't the coupler, and you want to go further, it is possible that the "Agitate Gear" in the transmission is damaged.
Here is a description of how to "pull" the transmission on top load washers.
Although getting into the transmission is somewhat messy (it holds about 14 oz. of oil) it can be done, and replacing the gear isn't too difficult.
Oct 01, 2009 | Washing Machines
Oil leaking from gear box on whirpool washer,theres no play inthe shaft,i just replaced the coupler,and 9 load later a puttle of oil was under the washer
The seals on the gearcase (transmission) are defective. Check with your manual, the gearcase usually has a 10 year warranty.
If it's older than 1 year be prepared to pay for labor.
Mar 01, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Oil leaking from washer
if it smell like wd 40..your transmission is defective,,need help replacing post question,,
Dec 27, 2008 | Frigidaire FEX831CS Top Load Stacked...
Washing Machines Logo
59 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
