Question about Sanyo DS27510 27" TV
Namco yellow and white inputs to Sanyo DS27510 27 " TV
Need to know where to connect White and Yellow connection to TV to Play Namco Games
    Sergeant:
  • 217 Answers
Yellow goes in the Video In ,White goes in the Audio in.If you don't have any imputs there are converters that will convert A/V inputs to RF (antenna).Good Luck
Posted on Sep 06, 2009
How do you hook namco game to hdtv
most should have Composite ( Yellow, White, Red cables) and will got in the same on the TV, if your TV doesnt have them, it may have the Red, green, blue inputs, you will use the green one to get the video.
Dec 25, 2013 | Video Game Consoles & Games
How to open case?
under the decals on ether side are four screws remove these and
separate the sides under these you will find white wedges that hold the case halfs together pull out these wedges and open the case. repair unit and Reverse the prosess to reassemble the unit. If you know how to work on electronics you may need to replace the electrolitic capacitors while the case is open. Kill 2 birds with one stone.
Oct 27, 2012 | Namco Arcade Classics Plug and Play TV...
Namco plug+play poor picture quality
if it has multible colors the yellow has to go to the green top plug and red and white go to the furthist away from the green plug.
Jul 10, 2012 | Namco Arcade Classics Plug and Play TV...
How to connect HDMI set top box to analogue VCR and then to Digital tv to record
Most set top boxes with HDMI also have a yellow video out and white audio out for connection to a VCR or DVD recorder. Connect these two RCA cables to the VCR's yellow and white INPUTS for recording. Set the VCR to LINE input. For VCR playback, connect yellow video and white audio OUTS from VCR to your TV's yellow and white INPUTS. Select this input on the TV set.
Feb 13, 2012 | Sanyo Televison & Video
I hooked up my gane to my tv .i only have sound from the but a blank screen.
Hi there and welcome to FixYa. The most common solution to your issue would be with the composite jacks provided with your product. The yellow cable represents Video and must be fully inserted into the yellow jack on your television. The other one or two remaining cables should be red and white representing your audio. If your product only has a red cable or a white cable please insert this jack fully into the jack on the back of the television as well. Alot of people have this problem by not color coding the jacks to the inputs or by not having them fully inserted. You don't have to force it in but just press firmly until you feel resistance. I hope this was of help to you and good luck.
Apr 22, 2011 | Namco Arcade Classics Plug and Play TV...
Got cox Digital cable box today, cox can not tell me how to hook up to box to make it rec/play. Info I read old cox papers from 2002 says I need a vcr controller, Cox does not know what that is and it...
For a standard VCR which is what most people have, all you need to do is connect a yellow RCA cable for video from the yellow output jack on the cable box rear panel to the VCR's yellow video input jack on its rear panel. Next connect a white RCA audio cable from the cable box white RCA output jack to the VCRs white RCA audio input jack. You can record a cable show by selecting the LINE input on the VCR and selecting the TV show on the cable box.
Now for playback, connect the VCR to your TV. Connect a yellow video cable from the VCR's yellow output jack to the TV's yellow video input jack. Same for the white audio connection. Select on the TV, the source input for the VCR. Its not complicated and you should not need any other devices for a standard setup with a digital cable box and vcr.
Aug 25, 2010 | Toshiba Televison & Video
Namco plug and play turns on, but no visual or audio shows up on the tv
Try changing the channel on the tv. If it's a newer tv then make sure that the tv settings are correct. If it's an older tv,or one that you've played the system on before,then trying wiggling the wires and see if you notice any differences. If you see flashes of the game then it's probably in need of new hook ups (wires).
Hope this helps.
Aug 12, 2009 | Video Game Consoles & Games
I don't know where to put the yellow, red and white connectors on the TV or the dvw
look on the back of your flat screen , there is a panel with inputs , example: VIDEO 1 , VIDEO 2 , etc. , connect your yellow , red & white from the DVD COMBO to video 1 (input) there colored to match with your cable , yellow w/ yellow , red w/ red , white w/ white , hope this helps AJ
May 08, 2009 | Sanyo DVW-6100 DVD Player/VCR
Sanyo DS27510 27" TV Logo
63 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Jerry Greenberg
Jerry Greenberg
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
