Question about D-Link Computers & Internet
Ive run the install disk for the dlink adaptor but i still cant connect. it wants me to enter the ssid but it says the ssid doesnt exist. what else am i meant to be doing to get my laptop onto a wireless home network. im a real dummy at this stuff.
  • daz_n_caz Sep 06, 2009
    Ur kidding. i would say its to do with configuring my router but i have no idea how to do that... i have tried reading up on it but theres nothing in 'dummies' terms...
  • 7,993 Answers
Your adapter cannot connect i
1. f there is no wireless networks to connect to
2. If there are networks around but they hide their SSID (some thing like a name or call letters for a radio)
3. If the power signal received is weak
4. If there are security measures enforced on the network that prevent non authorized.
If it is your nework you are trying to connect to you must configure your router to allow your computer access to your network and through your network to the Internet.
Hope it helps.
Posted on Sep 06, 2009
How can I connect to my new WiFi using my dlink dap 1320 thru my Samsung tablet, how can I reset the old one
You need to get the Wireless Range Extender to communicate with your existing router. Instructions are attached. If you have already done this, you should be able to search for WiFi connections and connect to the SSID with your password. It should be the network that has the most strength. In Canada, you can contact Dlink at (800) 361-5265. In the US, (877) 453-5465.
http://www.dlink.com/-/media/Consumer_Products/DAP/DAP%201320/QIG/DAP%201320_QIG_US.pdf
Feb 03, 2015 | Samsung Tablets & eReaders
My dlink is not connecting.
Have you reset the D-Link to default setting, and reconfigure the SSID and the Security Key? Perhaps this will help: http://www.dlink.com/-/media/Consumer_Products/DIR/DIR%20835/Manual/DIR-835_Manual_US.pdf
Apr 19, 2013 | D-Link Dir-835 Wireless N750 Db Router...
I have a dlink n150 router dir-600L. i tried to configured it and changed the SSID and network key. the problem is, i cannot connect it to the wireless connection even though the network appears on my
Did you enter the security key (password)? It may be your laptop? Try resetting the D-Link to default settings and connecting to the laptop. They reconfigure the SSID and Security Key. Write down the info for future use. Here's a user Manual: http://www.dlink.com/uk/en/home-solutions/connect/routers/dir-600-wireless-n-150-home-router
Jan 24, 2013 | D-Link DIR601 WirelessN 150 Home Router...
Wireless ssid not showing in some laptops and mobiles -dlink router
The D-Link wireless router may have the SSID broadcast turned off.
In this case only computers that have wireless connection to the D-Link will show the SSID.
If you know the SSID you can enter the SSID manually in the wireless card settings in the laptop/computer.
OR
Turn on SSID broadcast in the D-Link wireless settings.
Aug 08, 2012 | D-Link Computers & Internet
Dlink wireless windows vista
Connect an Ethernet cable to one of the 'LAN' ports on the router and to the network-port on your computer.
Click Start
Click Run
Type CMD and press ENTER
Type IPCONFIG and press ENTER.
You should get output like:
Ethernet adapter Local Area Connection:
IP Address. . . . . . . . . . . . : 124.268.336.448
Default Gateway . . . . . . . . . : 123.456.789.0
Start Internet Explorer.
Type: http://123.456.789.0
to connect to the web-server "inside" the router.
Run the "wireless network setup wizard" to configure the router
with an SSID and a password.
Save and reboot the router.
Disconnect the Ethernet cable.
Your computer should report "Wireless Networks are available".
Choose your network, and enter the password for the network.
Nov 18, 2009 | D-Link DIR-615 Wireless Router
Ssid network
The SSID setting is part of the DLink wireless setting.
To configure the DLInk wireless/router from new, you may need to connect the DLink wireless/router the laptop with a 10baseT cable, then open your browser and enter the URL address http:/192.168.0.1 The default login = admin, no password required. Unless you have previously altered the default settings.
You should configure the DLink wireless with a different SSID from the default one and set it up with encryption preferrably WAP.
You should also setup a password for the admin login, so to prevent someone from hacking into your wireless/router to change your settings and steal your Internet access.
You would need to setup the wireless card in the laptop to have the same wireless/router settings eg. SSID and encryption.
You can now remove the LAN cable and connect to the Internet by wireless.
All this information is in your manual.
Jan 24, 2009 | Dell Latitude D600 Notebook
Verification and signal problems
Hi Sir F,
You don't need to do a re-install of the DLink WiFi adaptor since I believe it is running as it should (as you posted). All that is needed is to configure it to exclusively select only your NetGear WiFi Router. This could be done in the DLInk Wizard (Start/All Programs/DLink.../) set the DLInk to connect only to the SSID of your NetGear. Though it may pick up your neighbors WiFi, the DLink will only acknowledge the presence of the other WiFi but connect only and always to the NetGear.
A couple of other things that may help improve your WiFi connection. Use static IP add in your PC to match that of the NetGear, disable wireless security (WEP or WPA) but rather enable MAC filter and input that of your PC's WiFi Networking Card.
Should you need a more detailed instructions, pls post back the model of your router and the make/model of your PC as well as your OS.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Apr 07, 2008 | D-Link Air DWL-122 802.11b Wireless...
Computers & Internet Logo
461 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
