Question about Husqvarna Lawn Tractor 48" Deck, 23 Hp, Model# Yth2348
Going dead atfer fuel system simple repair.
Lawn mower has had a brand new fuel pump replace new filiter and replace fuel line along with air filiter kit.But still runs for a few secods and then gos dead again ,what eles should I be looking at ? " husqvarna tyh2348"
    Problem Solver:
  • 10 Answers
Try checking the carburator, spark plug/wire, idle setting, tightening all the hose connections, and, maybe check the manual's trouble shooting guide, and if you still have problem with your mower, try and find a good repair shop and have them diagnose the problem.
Hope this helps! :)
Posted on Sep 06, 2009
When I pump the primer bulb, why doesn't it fill with fuel and stays collapsed?
new carbies start around $25.00 us on e-bay so get a new carby
take it to a mower shop for a service
rebuild the carby using a new carby kit
Nov 28, 2015 | Husqvarna 125 Bvx Leaf Blower Lawn Yard...
Toro lawn mower troubleshooting
Clean the carb, gas tank and fuel line (s). Replace air filter with a new one, I wouldn't recommend that you run it without the filter because that allows dirt and grass debri to enter the carb, fuel line and gas tank.
Replace the plug with a new one that is recommended for your engine.
Check oil level.
Other option is lawn mower repair shop....
Hope this helps, I had the same problem.
May 11, 2013 | Garden
Murray mower starts with choke but dies
most likely your main jet in the carb is clogged, water in fuel, or a plugged fuel line, filter, or plugged in the tank where the fuel line connects. it is common to have a plug where the fuel line exits the fuel tank if there is a 90 degree turn in the fitting, debris may build up in the 90 degree area. check by replacing old fuel with new, then pull fuel line from carb and fuel should flow freely, look for a blocked fuel line if it does not flow. it it does flow, pinch off fuel line then remove the float bowl to drain remaining gas and give acess to the main jet. the main jet is located in the side or bottom of the lowest protruding area into the float bowl. run a thin wire like a guitar string thru the small jet hole to unplug, then squirt a little wd-40 thru jet hole to visually check flow. next, unpinch fuel line and fuel should flow from carb into float bowl area. then check to make sure the fuel stops flowing when the float is gently lifted to the top of its travel. if problem in this area, remove float pin, float, and needle valve and check for blockage in the needle valve seat. clean out with wd-40 and reassemble, add fresh gas and give it a try!
Aug 20, 2012 | Briggs & Stratton Garden
2 year old 19.5 hp Craftsman riding mower will not start, or will start, run for a few seconds, then stop.
Sounds like you might have a bad fuel pump or it is sucking air in the fuel sysyem.take a air hose and force air into gas tank and see if line is leaking fuel.if so change fuel line where it is leaking.
Dec 08, 2010 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Won't run unless you continue pushing priming bulb
sounds like the carburator needs to be cleaned out and a new needle and seat valve installed along with a gas tank cleaning and all new fuel and a new air filter.
Jun 21, 2010 | Toro Lawnmower 20099 Mower Mowers Lawn
Motor backfires
It sounds like your engine is firing out of time.
Here is a link to the manual for your engine. It does contain some good info and I hope it will help you to solve this problem.
http://www.gardenresources.co.uk/content/garden_machinery/manuals/husqwm227_hwen2002_0000000-01.pdf
Best of luck!
Aug 31, 2009 | Garden
Mower dies after running for a few minutes
It sounds like the carburetor is running out of fuel.First make sure the tank is full then loosen or remove the gas cap when it starts sputtering to see if that corrects the problem. Then with engine off remove the fuel line that goes from the tank to the fuel pump,hold it low and see if any fuel flows out of it,if not lightly blow air backwards to the tank,(with fuel cap off),then see if the line is plugged. Next remove the fuel line that goes to carburetor from the fuel pump,crank the engine and see if any fuel flows,if so the carburetor should be cleaned by removing it and disassembling it.
Aug 09, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
The engine will not stay running (Ariens 34' Zoom)
a lawn mower is not much different than a car, you still need 3 things to make it run: fuel, electricity, and a spark. you say it doesnt stay running, Before trying to make any repairs, ensure that you are using the correct fuel, also make sure the fuel lines are not leaking or crimped. if the lines seem fine, check the fuel filter and/ or fuel pump. though the mower is new, they can still have faulty componets.
Jul 24, 2009 | Ariens 34 In. Zoom Series Riding Mower
Lawn mower
The best way to check the mower is to follow the fuel system first, and then the air system.
I know you've checked some of this, but its easier to go step by step from the beginning anyway:
Fuel System Check:
Fuel Level, age of fuel, quality of fuel. Drain the lines to check for plugs in the lines. If your mower is equipped with a fuel filter, check the filter for clogs (Usually inline on the fuel line)
Check the priming pump and the fuel pump/suction hose. A lot of push mowers run on suction, and a small leak can be to blame, look for wet areas along the hose to trace for leaks.
Air System: Check the air filter for clogs and clean it out while you've got it out (always helps extend the life of the mower), check the air lines for clogs and debris. Check the carburetor, make sure the throttle cable is working and all parts are functioning.
If I had to make an educated guess as to the source of the problem, I would lean towards the air/fuel mixture. It sounds like the mix is too rich. A telltale sign of this would be a significant amount of smoke on start up. Try playing with the choke (if equipped) or carburetor to lean out the mixture a bit (Adding more air and less fuel) and give that a go. If it starts, I would doubt it would be the coil or part of the electrical system.
Jul 12, 2009 | Garden
Husqvarna Lawn Tractor 48" Deck, 23 Hp, Model# Yth2348 Logo
234 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
