Question about Google Computers & Internet
How to install a floating countertop to kitchen wall Tools needed Size brackets to hold a 5'4'' countertop There is no cabinet for a base. Height the countertop should be.
SOURCE: dishwasher tils when door is open because the bracket is roken
There is now a universal dishwasher bracket for just this problem called E-Z DISHWASHER BRACKET. It is available through Braxton-Bragg or ask for it at a local granite fabricator. It is very simple to use.
Posted on Oct 30, 2008
SOURCE: mounting brackets for granite countertop
This is the best way i have found. You must check this company out. Granite Grabbers www.GraniteGrabbers.com They are extremely simple mounting brackets secured with a very strong double sided adhesive. You do not have to drill you cabinets or deal with any expoy.
I have used them with excellent success, took 5 minutes to install
Posted on Feb 03, 2009
  • 74 Answers
SOURCE: Can you install a garbage disposal in a corner undermount sink
Are we concerned about the distance between the bottom of the sink and the bottom of the cabinet?
I have installed a lot of disposals on under-mount sinks and I have found the the Badger company has a 1/3 hp unit that is quite short. It may seem a bit small but we need to remember that disposals are not made to chop wood.......1/3 is plenty strong for a person who uses their head when shoving food sown it. Their 1/2 hp unit might also work.
They are available at Lowes and Home Depot for around $60.
Hope this helps
Posted on Apr 28, 2009
aasc
  • 1606 Answers
SOURCE: Installing cooktop into granite countertop
Put a bead of clear sylicone caulking around the cutout , then set the cooktop in place .
Posted on Aug 08, 2009
  • 154 Answers
SOURCE: what size bolts hold the wall mount bracket to the
The bolts that hold the wall mount bracket to the TV vary in size depending on the manufacturer of the tv you have.
The best thing to do is to purchase a wall mount bracket specifically made for your TV.
It may be possible that your owners manual will list the size of the bolts you will need.
Posted on Aug 23, 2009
What is a standard kitchen counter depth?
Counter depth is key to functional, comfortable kitchen design. Standard dimensions keep cabinetry within reasonable size for average-height users, and in relation to common sink and appliance sizes, but guidelines allow for slight or moderate changes. The countertop overhang plays a couple of roles and affects counter depth.
Standard lower, or base, cabinets are 24 inches deep, while upper, or wall, cabinets are 12 inches deep. Countertops typically overhang their base cabinets by about 1 inch, or at least 3/4 inch beyond the drawer fronts and cabinet doors. The overhang helps keep crumbs and spills from getting into drawers and cupboards below and completes the comfortable cabinetry contour that includes a 3-inch-deep toe kick on the floor. Island or bar-style overhangs often extend about 15 inches or more to create knee space for people seated at the bar. Deep overhangs require bracing, which may be provided by brackets, legs or even a steel plate underneath the countertop.
Apr 14, 2018 | Refrigerators
What are modular kitchens?
Modular Kitchen a term used for the modern kitchen layout, which consists of number of cabinets to hold different things in different sections. There are two sections namely floor section and wall section, floor section is one having cabinets attached to the floor and wall section having cabinets attached to the wall and basically near to the rooftop
Types of Modular Kitchens
U shaped
L shaped
Straight
Parallel or Galley
Island Layout
You can find various types of affordable modular kitchens manufacturers
here https://www.exportersindia.com/indian-suppliers/modular-kitchens.htm
Feb 01, 2016 | Relton 3/16" x 6" long Groo-V Tip Granite,...
I have a GE OTR microwave JVM1460 spacesaver xl1400. I am trying to take it down. I unscrewed the two top bolts from inside the cabinet. I thought it should just swing down on the mounting strip, b
remove-ge-spacemaker-800x800.jpgRemove a GE Spacemaker
The GE Spacemaker series of microwave ovens are designed to be installed above an oven range, freeing up counter space in your kitchen. Some of these Spacemaker models are connected to an outside venting system to carry kitchen vapor and odors outside. Other Spacemaker models utilize a ductless system to do this. Removing a GE Spacemaker microwave oven isn't a difficult task, but, because of the size of some of the oven models, it is a two-man operation. Have a question? Get an answer from an appliance repair specialist now!
Other People Are Reading
Things You'll Need
  • Assistant
  • Sharp knife
  • Phillips screwdriver
Instructions
    • 1 Open the cabinet above where the Spacemaker microwave oven is installed. If you see a vent in the cabinet leading to the Spacemaker oven below, your Spacemaker is vented. This vent needs to be disconnected before continuing with removal. Disconnect the vent either by loosening the duct clamps or by cutting the duct tape away with a sharp knife. Pull the vent out of the top of the oven.
    • 2 Have an assistant support the oven from below. Loosen the mounting screws connected to the Spacemaker through the cabinet bottom. Loosen the screws by turning counterclockwise with the Phillips screwdriver.
    • 3 Unplug the Spacemaker from the socket in the cabinet.
    • 4 Continue loosening the screws while your assistant holds the oven in place. Once the screws are removed, have your assistant slowly lower the Spacemaker down by lowering the front face at a 45-degree angle.
    • 5 Feed the power cable for the Spacemaker through the hole in the bottom in the supporting cabinet.
    • 6 Help your assistant slowly pull the Spacemaker forward and out of the mounting brackets on the rear wall. Once the Spacemaker is cleared of the mounting cabinet and rear wall, set it down.
    • 7 Remove the mounting bracket from the rear wall by loosening the screws.
Read more : http://www.ehow.com/how_7344250_remove-ge-spacemaker.html
Nov 26, 2014 | GE Microwave Ovens
I have a new viking stove slide in electric top range that was installed in our kitchen with existing granite counter tops. But there seems to be a small gap between the stove and the counter. My previous...
If you are talking about a gap caused by the height of the stove, You can lower the height of the stove by adjusting the threaded leg posts on the bottom of the stove. A more difficult fix would be in raise the height of the countertop and cabinets by shimming the bottom of the cabinets.
If your gap is not a height issue, then you can experiment with some type of trim around the stove itself. Local granite dealers has an assortment of trims for issues like this.
I was able to find a number of trims for a back gap on my granite countertops and backsplash from my local European Marble and Granite.
Mar 15, 2013 | Cooktops
Thermidor GG30 cooktop front large burner will not light, does not spark. Three other burners work fine. Need instructions how to disassemble and repair. I am handy but no experience with this item. ...
Here is the part to order.
Close the valve in the gas line connected to the Thermador oven. Unplug the cooktop's electrical cord from the wall outlet.
Remove the screws under the front edge of the Thermador cooktop below the cabinet to release the cooktop from the countertop.
Put on work gloves then raise the cooktop at an angle. Recruit a friend to hold up the appliance while you work on the igniter underneath. The igniter is a pronged strip of black metal in a housing wired with two plugs connected to powericon1.png sockets underneath the Thermador cooktop.
Disconnect the two wired plugs on the end of the igniter from the sockets.
Take out the two screws in the metal plate that hold the igniter in position under the Thermador cooktop. Pull the igniter out of the mounting bracket in the cooktop.
Hold the new igniter by the housing and insert the part into the mounting bracket. Secure it with the two screws.
Connecticon1.png the two wired plugs to the sockets. One plug is larger than the other, which makes it simple to connect them correctly.
Lower the Thermador cooktop into position on the countertop and reattach it with the screws through the underside of the front edge.
Plug inicon1.png the cooktop's power cord and open the valve in the gas line.
Feb 09, 2013 | Kitchen Ranges
Dishwasher slides when both top and bottom trays are out at the same time
Please clarify if the dishwasher is tilting forward when both the trays are out.
If so there are ways to install the machine so that it will not tilt. If your dishwasher is installed under the kitchen bench and there is a gap on top, the machine will tilt from the weight of dishes once the trays are rolled out.
The legs are adjustable, therefore, free the hoses and power cord. Pull the machine out so that you can untwist the legs to a height suitable to minimise the gap. Just leave enough space to allow you to push the machine back in with ease. You can always pack in cardboard or phoam later when machine is in.
If after legs are heightened and you still have a big gap, the you need to get to pieces of timber cut on either top edge to fill the gap.
There are specialty brackets (e.g. L-shaped brackets) which you can buy and screw into the cabinet walls to hold machine in.
Some machines have holes on the side or top to allow you to screw in from the wall of machine into the cabinet. However, I do not believe Electrolux models have this.
Let me know if I have misunderstood your problem.
Ash
Sep 19, 2011 | Electrolux Dishwashers
We purchased a slide in range, Frigidaire fggs3045kf. We want to put a granite countertop and use tile on the floor. When we raise the heighth of the range to make room for the tile, the ridge of the...
Hello Mkoffice, this a very common problem when floors are installed in front of cabinets and not underthe cabinets. it also causes a problem for the dishwasher. it will become trapped or cant be installed.If you dont want to removed cabinets to install the tile. you will need to raise the cabinet height. my shop has run into this before. We add 1 inch tall strips of wood across the entire front edge of the cabinets. the same is done to the back wall and any area where two cabinets sides meet. we dont use full sheet of ply wood because the granite installers will need access into the top of the cabinets to level the counters. The wood type should match the cabinet.( at least in the front) it will have to be stained or painted.
Hope this helps
Joe Connolly
Aug 16, 2011 | Frigidaire FGGS3045KF Stainless Steel Gas...
How do you install an over the range micro-wave, i can't seem to figure out how to insert the micro wave onto the bracket on the wall.I'm having trouble with the clearance from the cabinets above .
Use the template that came with the microwave to insure proper height of the wall bracket. If height is correct and you have drilled the three holes in the top cabinet, (one for power cord two for mounting bolts), the unit must be tipped forward (front lower than back) so the bottom can be hooked to the wall bracket. Once hooked, start the power cord throught he hole into the upper cabinet and the unit can be tilted upward to allow you to start the bolts that support the front of the unit. It is nice to have help with the weight of the microwave. If attempting alone, make sure that everything is within reach when you start and if possible pull the range and move it aside. Good luck.
Aug 25, 2009 | Magic Chef Kitchen Ranges
One stud in the middle for an OTR Microwave Install?
i had the same trouble, yes i used a solid bolt to hold the microwave bracket in the stud then used the biggest toggle bolts that will fit, also the cabinet will not have to be changed. it works fine, if you had a vent a hood dont forget to hook up the exhaust vent. i figure your old exhaust vent is in the cabinet like mine was
Dec 31, 2008 | Whirlpool 1.6 Cu. Ft. Over-the-Range...
Mounting brackets for granite countertop
Dec 19, 2008 | Dishwashers
Computers & Internet Logo
929 people viewed this question
Top Google Computers & Internet Experts
Sunil Pratap Singh
Sunil Pratap Singh
David Payne
David Payne
Colin Stickland
Colin Stickland
Are you a Google Computer and Internet Expert? Answer questions, earn points and help others
