Question about Maytag Performa PAV3200
Dishwasher buttons not working - Maytag Performa PAV3200
  • 415 Answers
The most common problem with this can be the thermal fuse located on the microprocessor its white and has 2 wires to it
Posted on Sep 06, 2009
Cannot push the start button of my wirlpool dishwasher (WDT710PAYM3)
If you can get to the motor, unfortunately, you may have to pull the dishwasher out to get to it unless you can access it from the adjoining cabinet. The motor may have a red button on the back of it which is the "Reset" button. Press it in and if it clicks, you have reset the motor. I hope this helps, good luck.
Oct 22, 2014 | Dishwashers
Frigidaire professional dishwasher buttons don't work
I appreciate your inquiry, friend!
I have identified a few possibilities as to why the buttons are not working on your Frigidaire Professional dishwasher. It could be a stuck button on your keypad and I would recommend pressing every button to see if one is stuck or loose. It could be that the keypad or control panel needs to be replaced. This is not a simple DIY job and I would recommend reaching out to a professional technician for proper diagnosis. I hope this helps. -Matt
Sep 25, 2014 | Frigidaire Professional Series 24 in....
The power button dont work
Hello. The best thing to do is call someone who fixes dishwashers.
Apr 21, 2014 | AEG 23 in. Favorit 50750Vi Built-in...
The setting push panel does not respond - can't turn it on
follow this steps and fix it. God bless you
Touchpad and Control Panel
If the buttons don't work on the control panel the entire touchpad and control panel assembly may need to be replaced. If the display works but the dishwasher functions are all out of synch, or some of the buttons don't respond properly the entire touchpad and control panel might need to be replaced.
Touchpad
If the buttons don't work on the control panel, the dishwasher touchpad might be at fault. Generally speaking, if the dishwasher display is working and some of the buttons respond correctly but some don't, the problem is with the touchpad.
Main Control Board
The dishwasher has a main control board which regulates nearly every function in the dishwasher. If the control panel buttons don't work, and other causes have been ruled out, the main control board might need to be replaced.
Jun 14, 2013 | Dishwashers
Regency problems
Enter your model number to see parts for your dishwasher.
Help me find my model number
Touchpad
Main Control Board
Jun 14, 2013 | Maytag Dishwashers
My leisure dwlt65 dishwasher keeps switching its self off when going till wash
see this causes and fix it. God bless you
Touchpad and Control Panel If the buttons don't work on the control panel the entire touchpad and control panel assembly may need to be replaced. If the display works but the dishwasher functions are all out of synch, or some of the buttons don't respond properly the entire touchpad and control panel might need to be replaced.
Touchpad If the buttons don't work on the control panel, the dishwasher touchpad might be at fault. Generally speaking, if the dishwasher display is working and some of the buttons respond correctly but some don't, the problem is with the touchpad.
Main Control Board The dishwasher has a main control board which regulates nearly every function in the dishwasher. If the control panel buttons don't work, and other causes have been have ruled out, the main control board might need to be replaced.
Sep 28, 2012 | Leisure DWLT65 Dishwasher
The clean light is blinking and the dishwasher does not run???
Close the dishwasher door. Push the "normal wash" button, then push the "heated dry" button. Push the "normal wash" button again, and push the "heated dry" button again.Try out his and see what happens.It must reset the memory and your dishwasher must work.
Jul 06, 2010 | Kenmore 24 in. 16352 / 16354 / 16359...
Dishwasher not working. Start button works ok as
It sounds as though the Anti-flood device has kicked in,could be due to a leak under the dishwasher,it will need to be pulled out and investigated.
I would also check that there is water at the hose to the machine.
Hope this helps.
May 21, 2010 | Neff 24 in. S4456 Built-in Dishwasher
Dishwasher wont work
Press back and forth between the "sani rinse" button and the "heated dry" button several times. This should put it into a "test mode" where all of the buttons light up and the dishwasher does a self-test. Wait about 5 minutes until you're sure the test is complete, and the dishwasher will operate normally. If those 2 buttons don't work, try going back and forth between the "sani rinse" button and the "hi temp wash" button.
Jun 02, 2009 | Kenmore 24 in. 17032 Built-in Dishwasher
DISHWASHER LOCK
I too had the same problem,,and tried it again,,,and it worked for me,,i pushed the button next to the lock light it blinked and i kept holding in the dry button and the lock went off,,,,good luck
Aug 15, 2007 | Whirlpool GU2400XTP Built-in Dishwasher
Washing Machines Logo
89 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
