Question about Karcher G2500PHR Factory Refurbished 2,500 PSI 2.4 GPM Gas Pressure Washer
Karcher G 3050 OH the pressure is not constant, I think that is the pumps pressure regulator but I'm not sure
  • 832 Answers
Check the suction line for leaks. It needs constant water
supply to build a constant water pressure. You may also
check the pressure regulator for leaks. You may also
check the carbide or ceramic pistons for breaks. Send you e-mail for further assistance.
Posted on Oct 27, 2009
Where is the inlet regulator on my karcher 3300 high pressure washer
no inlet pressure regulator as they work of mains pressure
the only pressure regulator ther eis works off the wand trigger
when the trigger is pulled the pressure in the line drops off and the regulator switches on the motor to produce high pressure
when the trigger is let off the regulator reads the pressure and shuts off the pump;or allows the pressure to by pass back to the inlet side of the pump
Oct 30, 2016 | Karcher Garden
Karcher hds 558c after about 15mins looses pressure, then about 30 seconds later pure stream come out
Sounds like water is not getting to the pump for some reason. As the pump needs constant water flowing through it for cooling, you should not operate the unit until you find the problem. The pump could be damaged.
Jul 18, 2016 | Karcher Garden
How to rebuild High pressure pump
You can get a repair or rebuild kit for this pump at any store that sells Karcher. You need to have a torque wrench and a set of picks to remove the packing. Take the head off the pump and pull the packing and the valves. Replace them as the instructions show and then put the head back on.
Sep 07, 2015 | Karcher G 3050 OH
How do I remove the connectors from the output hose?
Does it have brass quick connects or is it screwed directly into the pump? Feel free to email me.
Sep 26, 2014 | Karcher G 3050 OH 3000-PSI Honda Gc190...
No water pressure from unit
check inside the pump fro sticking valves
Apr 06, 2012 | Karcher G 3050 OHR Gas Pressure Washer
HELLO SIR I HVE MY KARCHER WASHER WASHING PUMP HAVING PRESSURE PROBLEM THERE IS NO PRESSURE WHEN I START THE ENGINE
Check the pump. If it's turning you should have pressure unless the pump is leaking . Look it over closely.
Jun 22, 2009 | Karcher G 3050 OHR Gas Pressure Washer
My Karcher high pressure sprayer is delivering intermitant pressure.Every 15 seconds or so it developes high pressure for only about two seconds. Why is it not delivering a constant high pressure stream?
Check that the water supply is constant , it sounds like the pump might be pushing out more water than can be delivered , or it could be a dirty inlet filter
May 17, 2009 | Karcher PSI Electric Pressure Washer
Karcher G2500PHR Factory Refurbished 2,500 PSI 2.4 GPM Gas Pressure Washer Logo
358 people viewed this question
Top Karcher Plumbing Experts
Paul Carew
obsteiner
JonSnell Electronic
JonSnell Electronic
Are you a Karcher Plumbing Expert? Answer questions, earn points and help others
