The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or, despite what I said first, you can use any photo cataloging program such as Picasa.
Had the same problem till I found the right drivers to run this camera, but if you want to save yourself time and headaches its now worth it Im taking mine back, Ill spend a lil more and get them cameras that work, they dont need Hannah Montanas picture on it anyways. for the manuel to work this fancy gadget go here ....http://digiblue.com/customer-service/downloads/index.html to get the right driver for windows XP go here should work
The software that came with your camera is not compatible to Windows Vista. Go to www.olympusamerica.com and click link for software downloads and download the free copy of Olympus Master 2. This software is Vista compatible and you should be able to download and transfer images.
There are two ways to solve this problem. I am assuming you are simply clicking on the pictures and choosing "edit" or double clicking on the pictures and they are opening in "Vista picture editing" The first way to overcome this is by opening the desired program first (in this case canon's photo editor) and then choose open and find the desired photos. The other way is to set the file type association in vista so that RAW programs open with the canon program see below for step by step: 1. Click Start 2. Click default programs on the black bar 3. Click Associate a file type or protocol with a program 4. Find the file types you want to open automatically in your canon editing program (RAW .jpg etc) 5. Click once at the top of the page click change program 6. A new window will open, if it does not list the correct program click browse at the bottom of the window and find your editor in it's folder. 7. Select the desired program by double clicking 8. Click OK 9. Click close 10. Test the new file association by double clicking a RAW file or one of the other file types and see if it loads into the correct program.
The final (and this is simply my plug for open source programs) solution would be to try something like GIMP (it is a photo editing suite developed under linux but adapted for windows) you can search for it on google.
If you are having trouble with any of these steps please post a comment and I will try and add some clarification. Hope this helps
windows vista should automatically search for a solution to your problem if it does'nt search for a solution check vista internet settings. or contact windows tech support
Uninstall Windows Vista. Do a fresh install of Windows XP Professional Sp2. Download XP drivers and install camera. Many software programs have trouble initializing in Windows Vista. Good luck!
