SOURCE: bridge mode
i see,, seems your router is not configured, you can try an alternate way.. if you have windows xp, goto control panel select internet options, goto to connections tab then click set up button a wizard will pop up, click next then select connect to the internet then click next, select set up my connection manually,, select connect using a broadband connection that is always on then finish...
SOURCE: Reseting "Bridge mode" in RCA DCM 305R cabel modem
you can't set teh modem to bridge mode, however, you can set the router to bridge.
The linksys should have bridge mode configuration in the uer guide.
connected the 2 router together
configure the IP address of the liksys to be inthe same subnet as the moem, but out of the range of the DHCP of the modem. ie. DHCP address 192.168.0.2 through 192.169.0.100, the linksys should have the IP address as 192.168.0.200
disable the DHCP on the linksys
setup the wirless just the way you would if ti was the modem.
connect from the modem LAN port to the LAN port on thelinksys. leave the WAN port open.
SOURCE: have a Thomson st546 V6 modem and trying to
i have problem everytime i want to log in ...very difficult to access in yahoo messenger
SOURCE: cant get speedstream modem into
Hi I was in a live session with you earlier. Seems like you lost contact after restarting your router. Any luck?
