Question about Sony PS2 Dual Shock 2 Controller (PrePlayed) (PS2PRSODUSH2)
My PS2 controller does the same.
When i plug into the port it starts vibrating continuously and doesn't stop. There is also no red LED indication. Neither does any of the button works. I have tried many repair guides but none works. The connections inside my PS2 Controller are all tight, I've checked.
  • 53 Answers
Its vibrating because it is probably grounded.. check for stuck buttons...try opening it and check the rubber underneath the keys
Posted on Sep 06, 2009
How to install Polaroid Wireless Controller to a ps3
  • Power on the console either using the power button on the front, or by holding down the PS button on your first controller. On the top edge of your main controller, you should be able to see a single red LED flashing beneath the number "1." this indicates that the controller has paired with the console as the primary controller. In any multiplayer games you start, this controller will always be assigned to "Player 1"
  • 2
    Connect a second controller via the USB cable. Plug the larger end into the port on the front of the console and the small connector into the top of the controller. Check that all four lights are flashing, indicating that the controller is charging. It's advisable to let the new controller charge for as long as is practically possible; its rechargeable battery will have a longer lifespan if it is fully charged to begin with.
  • 3
    Press the PS button on the second controller and the red LED under "2" should illuminate. This controller is now paired with your console. You can continue charging the controller and use it to play or disconnect the cable and use it wirelessly.
  • Dec 06, 2011 | Computers & Internet
    I have a fat ps2 with a rumble controler problem
    just keep ure ps2 safely and always shining . so always clean ur ps2 and make the best use of controllers carefully
    Sep 19, 2009 | Sony PlayStation 2 (PS2) Console
    Dual shock does not work or led display on controller
    If it is wireless put your ps2 infront of remote
    Buy a new ps2 or remote
    Feb 28, 2009 | Sony PlayStation 2 (PS2) Console
    PS2 black console does not communicate with controllers
    Sounds like you have wireless Controllers. Be sure your batteries are good on the Controller and the controller is turned on, LED should light. Plug the receiver into the controller jack, and it should light up at least one LED. If you have channel number selector, set it to the same number on the controllers, channel selector.
    If old wired controllers will work, then you have dud wireless controllers. I know that cheap poor quality wireless controllers exist out there. You may have a dud. I also know that sometimessomething kills the controller ports on the PS2. The only way to know is to hook a wired controller you know works into the port to see if the port is good or bad.
    Jan 31, 2009 | Sony PlayStation 2 (PS2) Console
    How to check terminals on a dualshock2 ps2 controller
    does it stop working?or stopped vibrating?if the vibration stopped then wire connecting to the rotating motor is detached this is the common problem with dual shock because of constant vibration.Solution is to open the controller and connect the loose wire,dust is also a big factor if buttons are already not responding so try also to remove accumulated dust on the button touch board.
    Jan 24, 2009 | Sony PS2 Dual Shock 2 Controller...
    Power indicatoror
    From the manual:
    "Attach the barrel tip of the AC Charging Adapter to the AC Charging port of the POWER TO GO® and plug the standard two-prong plug into an appropriate, functioning 120 volt AC outlet. The red Battery Status LED indicator will flash, indicating a proper connection has been made and the unit is charging. The green Battery Status LED indicators will gradually light as the charge level rises. The POWER TO GO® must be charged for approximately 11-17 hours prior to first use. All Battery Status LED indicators will be lit solid (the red indicator will stop flashing) when the unit is fully charged.
    Aug 29, 2008 | Black & Decker Power To Go Cordless AC/USB...
    My PS2 controller port stopped working!
    Sounds as if it has been dropped .....or an impact to the controller port while one was plugged in. in some cases the in side of the port can become full of dust and dirt causing light rusting creating a loss of connection ...but an impact can break a small chip on the back of the controller port inside the machine , try cleaning out the controller port and check to make sure the metal tabs are clean and un bent.
    Aug 22, 2008 | Sony PlayStation 2 (PS2) Console
    Logitech Cordless action controller 2.4 ghz is not working
    Try Blowing into the peice that plugs into the playstation or whatever you have, after that, blow into the port that you would plug it into, sometimes dust gets in there. Good Luck. -JD
    Apr 01, 2007 | Logitech Cordless Action (9633200403) Game...
    Sony PS2 Dual Shock 2 Controller (PrePlayed) (PS2PRSODUSH2) Logo
    255 people viewed this question
    Top Sony Video Game Consoles & Games Experts
    shaun taylor
    marley mcelhinney
    juanmireles1
    Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
