Question about Sharp Office Equipment & Supplies
Misfeed indicator is blinking I've tried all the steps on page 34,35,36 of copier manual operation book. misfeed ligt still blinking thank you
  • 32 Answers
You have to do simulation on the sensors if they are all okay.
Posted on Sep 08, 2009
Bike Yamaha xt1200z what are error codes 34,35,36 and 14. Thanks.
Tom,
Hope this helps point you in the right direction.
motorcycle-repair-manual.jomdo.com/Yamaha-fault-codes
Fred-
Sep 29, 2016 | 2011 Yamaha XT1200Z Super Tenere
MISFEED INDICATOR BLINKING
DEAR SIR WHERE YOU REMOVE THE PAPER IN THE MACHINE THAT SECTION THERE IS PAPER PATH SENSOR ,THAT SENSOR POSITION IS ABNORMAL PLEASE CHECK THE SENSOR OF THAT SECTION WHERE YOU REMOVED THE PAPER
Hope this may help;
Regards,
VOTIT
Aug 29, 2008 | Sharp AL 800 Copier
How removed misfeed indicated problem?
a miss feed mean the roller could not get the paper, so clean the roller (s) or have them replaced, try a different paper draw
Jun 25, 2014 | Konica Minolta Di2010 Di2510 Di3010 Di3510...
I have a Sharp Al-2040cs when I turn it on the misfeed indicator is blinking. I checked it there no misfeed paper or piece of paper inside. How can I fix this problem?
The MISFEED Indicator blinks when a MISFEED has occurred. Remove the misfed paper referring to the the description of MISFEED REMOVAL beginning on page 65 of the pdf Manual at:
http://files.sharpusa.com/Downloads/ForHome/HomeOffice/PrintersFaxMachines/Manuals/cop_man_AL2030_AL2040CS.pdf
When the MISFEED Indicator is blinking you should look closer at the paper feed area (see page 66 of the PDF). You may need to remove the paper tray to find any remnants of paper. If after closing the side cover the light does not stop blinking you will need to follow through as per the illustrated instructions.
Remember after removing jammed paper, you need to press the clear key to clear the MISFEED error.
If after doing all this the error signal has not cleared, power down the printer; unplug from the power supply; let rest 5 - 10 minutes; plug back i to power supply; turn printer on and see if this resolves issue.
Trust this is helpful. Please vote. :)
Dec 12, 2010 | Sharp AL2040CS Digital Laser Copier,...
Indication warns that beside you in device is jammed paper, in printer there is three sensors, first when entering with manual presenting, second at passing thermo part and third on output first and second inaccessible for review .
We Do so. We Open the lid.
2 Take out the cartrige
3 straight before you adown two grosses, in the middle there is sensor, he must be an integer and liberally swing
4 lights to in depth, there in tag ends on middle one more sensor, lookout to depth, did not remain there piece of paper
If you have not been able to find the stuck papers, signifies the fault in blast thermotape or in sensor thermo part. Here I you not advice most, you hardly manage. The Printer it is necessary to analyse, but he not simply understands, there secret snaps, apply to service service.
Sep 06, 2009 | Sharp AL 800 Copier
I JUST CHANGED THE TONER AND THE COPIES ARE PRINTING OUT WITH A HEAVY THICK LINE ON THE SIDES
Indication Cause and remedy Page
Drum replacement
required indicator
Steadily
lit
Replacement of drum cartridge will be needed
soon. Prepare a new cartridge. 70
Blinking Drum cartridge must be replaced. Replace it with
a new one. 58
TD cartridge
replacement
required indicator
Steadily
lit
Replacement of TD cartridge will be needed
Blinking TD cartridge must be replaced. Replace it with a
new one. 57
Misfeed indicator Blinking
A misfeed has occurred. Remove the misfed
paper referring to the description of "MISFEED
REMOVAL".
63
SPF misfeed
indicator Blinking
An original misfeed has occurred in the SPF.
Remove the misfed originals referring to the
description of "D: Misfeed in the SPF".
67
Power save indicator is
steadily lit.
The unit is in the preheat mode. Press any key to
cancel the preheat mode. 54
The unit is in the auto power shut-off mode.
Press the start ( ) key to cancel the auto power
shut-off mode.
54
The paper tray indicator is
blinking.
The paper tray is not installed properly. Push the
tray into the unit securely. –
"CH" is blinking in the
display.
The TD cartridge is not installed. Check if the
cartridge is installed. 57
"CH" is steadily lit in the
display.
Side cover is open. Close the side cover
securely by pressing the round projections near
the side cover open button.
"P" is blinking in the display.
The paper tray or multi-bypass tray is empty.
Load paper. 15, 17
A misfeed has occurred in the paper tray or
multi-bypass tray. Remove the misfed paper. 63
A letter and a number appear
alternately.
The scan head locking switch is locked. Unlock
the scan head locking switch. 9
alternately.
The unit will not function. Turn the power switch
off, remove the power cord from the outlet, and
contact our Technical Assistance Department at
1-(630)378-3590 in the USA or 905-568-7140 in
Canada.
May 13, 2009 | Sharp Office Equipment & Supplies
Paper misfeed indicator light continues to blink even after paper
some machines will want all covers to be opened, then closed, for good reset. if you are having jams in the adf, then open all adf covers, and lift the adf upward, if it allows. also, try turning unit off, then back on. some jams only clear that way.
Apr 02, 2009 | Sharp AL-1641CS Laser Digital Copier
Misfeed Indicator light is on - there are no jamed copies present. Other solutions recommended. Thank you
Make sure that there isn't any little piece of paper caught near a sensor. Often when a jam is removed, the operator rips the paper, leaving some if it there inside. If it's near a sensor, you'll get a constant jam indication. Use a flashlight to check for it.
Feb 21, 2009 | Sharp AL-1642CS Copier
Misfeed indicator
It could be comming from the paper feed mechanism above the paper tray. Make sure its installed properly. It could be as simple as cleaning the feed tires.
Jul 12, 2008 | Sharp AL 800 Copier
Help
ok, you can also try the following without a code, I have a question for you since those codes didn't work, the manual that I gave you, the picture of the remote is the same, similar, or totally different? If you can give me the model of the remote (not the brand name) I may be able to find something even more specific or it might have different codes but the below can be done without a code and since you say that the remote seems to be programming, just not accepting the codes, then I think the following should work, it just may take some time. That manual that I sent you, you should probably print out and the directions below are from it. Thank you
Programming with Code Search
1. Manually turn on the device (TV, VCR, etc.) to be
controlled.
2. Press and hold Code Search button until the red
indicator stays on. Release the Code Search button.
3. Press and release the desired mode button (TV, VCR,
etc.).
The red indicator blinks, then stays lit.
4. Press the Channel Up button repeatedly (up to 300
times) until the device to be controlled changes
channel. The red indicator blinks, then stays lit. If
you accidentally overshoot the code required, press
the Channel Down button to backtrack through the
library until the device changes channel. Pressing
Channel Up changes direction to forward again.
Press and release the Mute button to install the
code.
The above assumes that you want to store VCR codes
under the VCR button, Cable codes under CBL, etc. If
you want to store a VCR code under CBL, etc., first
follow the procedure on page 10 and try ANY CBL code
from the code tables, e.g. press CBL in step 2, page 10,
and then enter ANY VCR code. Then follow the steps
above.
Note: If the device does not have a Channel Up button,
use Play (VCR only) or Power instead. Code Search
starts from the currently stored three digit number
under that mode e.g. if the mode has 100 codes and the
currently stored code is 050 then the Code Search starts
from 051 continuing to 100 before looping back to 000
and finishing at 050. This simplifies the process if you
find that several preprogrammed codes operate your
device by allowing you to bypass codes already tried.
Apr 11, 2008 | Televison & Video
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
