Question about Gigabyte GA-EX58-UD3R Motherboard
Takes a long time for programs on my c: drive to access files on any of the other three drives. All drives are new and are Western Digital SATA
  • 374 Answers
Slow performance can be caused by few things...RAM,Programs,Hardware,Ventilation... Now what you need to do is first check if you have installed the RAM according the OS/programs requirement [you can also try adding one more stick] then check the CPU usage into the task manager...if it's more than usual[not at the starup...coz that time it usually is high]...then there's some problem.I suggest you do a regular cleaning up and Defragmenting START---ALL PROGRAMS---ACCESSORIES--SYSTEM TOOLS---DISK CLEAN UP/DISK DEFRAGMENTER.[specialy for the C drive] or uninstall any unwanted software. Try removing any external hardware that you do not use very often...sometimes hardware installation also conflicts with some programs which leads to slow performing. Make sure the CPU gets a proper ventilation...lack of that would can cause some serious trouble.Do a regular cleaning by blowing some air and removing dust. Lastly you can try re-installing OS again [clean install would be better].Now if this doesn't help out then it's your motherboard...you need to take it to a service center.
Posted on Sep 06, 2009
    President:
  • 2,185 Answers
Do you have enough memory to do the process? Check your CPU utilization at it might be nearing 100% There might be other processes running that is eating up the resources. To check this, you need to go to task manager.
Also, try to clear your cache and defrag your computer and do a virus scan.
Pls remove your unwanted sofware from your pc particularly anti wires ant got good antivirus to scan your computer.
thanks
I need firmware for Western Digital WD Caviar Blue WD3200AAJS - hard drive - 320 GB - SATA-300 SATA
If you are troubleshooting a system or OS problem, you should not consider firmware updates until after exploring more typical troubleshooting steps like file system error checking and anti-virus scanning.
try uninstalling a few unnecessary programs then click start run type cmd then type chkdsk/r/f which will scan for and attempt to fix any bad sectors and automatically fix any corrupt files on your hard drive this should schedule the task on restart then defragment your hard drive
http://download.cnet.com/western-digital-disk-manager/3000-2122_4-10008018.html
This file contains the most up-to-date Disk Manager drivers for Windows 95 and Windows NT 3.5.1. This file fixes numerous issues, especially those with IBM PS/1 Value Point machines. These drivers will replace Ddloader.bin and Xbios.ovl files that were installed with previous versions of Disk Manager.
hope this helps you
Oct 20, 2011 | Western Digital WD Caviar Blue WD3200AAJS...
Says no hard drive devices found
Is it a "new" drive, or a drive that you have been using for a long time, i.e., it could have failed.
Turn the computer off.
Disconnect the AC power-cord.
Check that the "data" cable between the SATA drive and the motherboard is tightly connected at both ends.
Check that the "power" cable into the SATA drive is tightly connected.
Restart your computer, and enter BIOS SETUP.
Be sure that the BIOS-search for SATA devices is "enabled".
Note that Western Digital has a "Customer Loyalty" program; if you buy a new W.D. drive through their web-site, you qualify for a discount on the purchase.
Oct 31, 2010 | Western Digital Caviar SE WD1600AAJS 160...
Hello sir, i recovered some imported data from my corrupted hard disk (WD2500js) but after that i could not install the windows on it. I have partitioned it three times but didn't affect. i think i need a...
I think that your disk-drive is about to "die", and the symptom of not being able to install Windows (which tries to write many files onto the disk) is a strong indicator.
Is the drive still under warranty? If so, W.D. will give you a free replacement. If not, W.D. has a 'Customer Loyalty' program -- buy a new disk-drive from their web-site, and get a discount.
Oct 25, 2010 | Western Digital WD2500JS 250GB SATA2...
I dropped my Western digital 1TB hard drive.
The case maybe damage, so could the hard disk.
First try connecting to your computer or to an USB hard drive adapter, if it works then you know the hard drive is OK and you only need to buy a new USB hard drive adapter case.
WinHex is a edit program that allows to you see and modify the data files on the hard disk in ASCII and HEX format. If the hard disk is faulty no programs can access the data on the hard disk.
There are data recovery companies that can recover data from damages/faulty hard disk BUT it will cost you an arm and a leg for their services.
Sep 20, 2009 | Western Digital My Book Essential Edition...
Western Digital 1T MyBook keeps crashing
it seems a problem with the driver, try plugging it onto a different computer. If that works, reinstall the driver.
Aug 14, 2009 | Western Digital MY BOOK HOME 1TB EXT...
My western digital Passport 320Gb usb drive is not detected
hi ,
looks like u primary hard drive is inside the laptop and so should be displayed as c : drive ,
and the reason , the external hard drive is not displayed seperately is csue ., the external HD  may be added as slave to the internal HD .,
can u tell me ,make a right click on c:/ drive and choose properties : and tell the totalsize dispalyed
Jul 23, 2009 | Western Digital Passport WDXML800UE...
I have issues while transferring files back from Western Digital 1TB external drive. I copied all my important files there. In explorer all files are showing, but have issue, when you want to open or copy...
Hard drive may be going south and there may be bad sectors on it. Run WD diagnostic program on it and cross your fingers. Do not format the drive - that will erase all. If you do find bad sectors the check disk program will find and block bad sectors and move data in bad sectors to good ones whenever possible. After that you can recover as much as you can but not all because there will be areas where nothing can be read at all depending on the severity of the damage to the sector.
Sep 12, 2017 | Western Digital MY BOOK HOME 1TB EXT...
Installing new sata drive in HP pc
a clean xp installation does not recognize sata drives at all. you can either use nlite to build a custom install cd, press f6 during setup to load additional drivers, try to change your sata mode from native to compatible in your bios or use your restore cds.
Mar 18, 2009 | Western Digital WD2500BEVSRTL Scorpio...
WD Passport drive unmounts itself when connected
look up how to remove the drive from the enclosure on you-tube
it is easy and safe.
one of the removal videos also shows how to remove the USB-SATA adabter (it is really a sata drive). The removal is easy.. just pull it off.
You then have SATA ports.. just plug the drive into your computer through a SATA port and then you can access your data.
It is most likely the USB adapter that is broken (they break easily).
IDK if you can find a new one.
Dec 03, 2008 | Western Digital Passport WDXML800UE...
Auto format new hard drive in new custom pc
If you mean boot from cd with xp pro during setup you will have the opportunity to format drive either fat32 or ntfs use ntfs
I have never done it but if you can do it partition your hard drive so that you can save personal file and programs on second partition then if you have to format drive again your files on second partition will not be lost
Aug 04, 2008 | PC Chips (M925G) Motherboard
Gigabyte GA-EX58-UD3R  Motherboard Logo
Top Gigabyte Computers & Internet Experts
David
David
Tony
Matthew Spark
Matthew Spark
Are you a Gigabyte Computer and Internet Expert? Answer questions, earn points and help others
