Question about Qca Spas Majestic Series Aruba Xl Hot Tub
Only one jet is working - Qca Spas Majestic Series Aruba Xl Hot Tub
  • 37 Answers
Possible shut off valves closed
Posted on Oct 11, 2009
Hello, myK236 root jet nozzle has stopped working. There is no rotation of jet. Also it just stared pulsing on one wand, but works fine with the root jet wand. Thanks
the rotating nozzle is clear and that is why it is working It requires pressure out of the jet to make it rotate so a simple tap on the ground will generally get it rotating again as for the straight jet and pulsations
the jet is blocking up
unscrew it out of the wand and clean it out
the pulsations are from the pressure regulator unloading from a blockage ( same as taking you finger off the trigger ) coming and going in the jet
as the jets blocks up the increase in pressure operates the regulator and as the blockage moves around the pressure regulator again works giving full pressure until the blockage again occurs
Nov 06, 2016 | Garden
I have a 1980 rm125 and I have a 140 main jet on it is that the right jet or if not please tell me the right stock jetting.
You should really have the workshop manual if you are working on the carb. Not only will this tell you the correct main jet size, you will also get the pilot jet size, mixture screw, and jet needle positions. All of these should be checked if you're taking apart the carb yea?
Mar 10, 2015 | Motorcycles
Jets not working in spa on one side
the other jets work off a 2nd pump make sure it is on
Aug 26, 2014 | Pool & Spa
Pool jets not working
there may be a crack or break in the line feeding the bad jet. this would cause the symptoms above. if you are losing water, this diagnosis would be supported. if you are not losing water, and the lines pressure test ok, it might just be how the plumbing feeds the jets
Jun 16, 2013 | Pool & Spa
Some of the jets are not working how do we fix it
Assuming this spa is equipped with the single pump system and the rest of the jets are functioning as expected, you need to check to see if the jets that are not working are closed or shut off. Most jets can be opened and closed by gripping the outer ring of the jet face and rotating in either direction. If the jet has sand or gritty debris inside, the jet assembly may not turn easily and will likely need to be taken apart and cleaned. Most jets can be rotated counter-clockwise beyond a detent and pop out. Others require unscrewing completely or by releasing an internal latch to remove. If you need further assistance with this, feel free to contact us.
The jet could also be stopped up with debris, preventing the jet from working.
Taking it apart and cleaning it will likely resolve your non-operational issues.
Nov 26, 2010 | Dream Maker Spas Dream Maker Ez Spa Hot...
Two jets stopped working
Most of these jets turn to close. Check if you turn the nozzle. Hope it helps
Jun 04, 2009 | American Standard 2770.018w.020 Cadet...
Some jets dont work
jets don't 'clog' - turn the face of the jet nozzle - it is perhaps an adjustable jet you have that has been turned off.
Apr 18, 2009 | Home
Only 3 of 6 jets in jacuzzi tub working
Make sure the jets themselves are fully opened. Some models you can turn individual jets on & off
Dec 04, 2008 | Home
Beaumark jet dry dispenser
Hi puretonedoug,
I'm Harvey the Master Plumber.
Your question is: Beaumark Whisper Wash IV dishwasher jet dry dispenser does not appear to be working ( not using any jet dry) do they plug up or malfunction, if so how do you get it to repair or unplug?
The liquid jet dry dispencer only dispences a few drops in the last rinse. It is not uncommon for it to go a few months before needing refilling so it may not "appear" to be working. Are there spots on your glasses? That's the real test. If there are then just buy the jet dry that comes in a little basket that you hang from the top rack. Replace when it's empty and forget about the auto dispencer. If the glasses are clear then it's working and don't do anything..
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Oct 13, 2008 | Dishwashers
Qca Spas Majestic Series Aruba Xl Hot Tub Logo
117 people viewed this question
Top Qca Spas Pool & Spa Experts
Ian Kime
Ian Kime
byrdhaus188
Level 1 Expert
Shehu Pro
Shehu Pro
Are you a Qca Spas Pool and Spa Expert? Answer questions, earn points and help others
