Question about Digi-Weigh Body Fat & Calorie Monitor/Scale
When you turn on the scale it displays eeee - Digi-Weigh Body Fat & Calorie Monitor/Scale
Cooktop gives EEEE error code how
search this problem on Google with MAKE,MODEL and error code EEEE
Sep 12, 2015 | Cooktops
Resetting my accur 8 digi scale cp-1000
please preform the following procedure
Calibration
1. Place the scale on a leveled surface & turn off the scale.
2. Press and hold the "MODE" key and ON/OFF key until the LCD
displays a random number.
3. Now release both keys and press the ON/OFF key once. The
display will read "CAL" and then "1000.0".
4. Place a 1,000g weight on the center of the platform and wait 3 to 4
seconds. The LCD display reads "PASS", then "1,000.0g". Remove
the weight and turn off the scale.
5. Calibration is complete and the scale is ready for use.
check this link for manual:
Untitled Page
Apr 25, 2014 | Health & Beauty
I have pro-form esp 10 w/ the console does not function/an error code(EEEE)
see the diagram attached, and adjust the REED switch, clean, and tight the connector very well.
tight the ribbon cable from keypad + tigh the connector from display board vs lower board.
after your fix it RUN the software calibration for diagnose and troubleshooting.
See my perssonal tips for Help.
sincerely. God bless you
May 01, 2012 | Proform Exercise & Fitness
Its nan oxo pull out display food scale and the screen reads F when turning it on
My OXO scale has a removable weighing platform. I removed it and wiped off the top of the scale base. When I put the platform back in place and turned the scale on, the display showed the normal numbers and icons. The F was gone.
Apr 07, 2011 | Microwave Ovens
When i try to weigh something on it it displays 'our2'. And does not work
OUR2 is probably OutZ or Out2, means you have to recalibrate your scale. Refer to your scales manual for instructions on recalibrating, usually you have to turn on your scale, press CAL button, wait till it displays for example 100g, depending on how much your scale can weight, then put that weight, for example 100g on your scale (you can use coins if you don,t have anything else, though be precise as coins can weigh more or less,informationon coins weight can be found in your country national bank site. After you put the weight, it should display OK or PASS, if it's FAIL or the scale turns itself off, it's either broken or the weight is not correct
May 16, 2010 | Microwave Ovens
HealthSmart bathroom scale displays "Err"
Put scale in round file can. Buy another cheap scale.
Oct 03, 2009 | Dmm Elscale Healthsmart Glass Electronic...
Mini digital scale displays out2
I just had this problem on set Salter scales (says 3309 on label on back so assume that's model no) which came up OUT2 solidly after hadn't been used for a while.
Looking on WWW this means on other scales they need to be recalibrated. There are only 2 buttons on ths model ON/Zero and 2nd is mode for grams, oz etc. Discovered by trial and error have to hold down the on button and repeatedly click the measure button as it powers up, screen says err2 press on button again and says 5000g, put 5000g weight on scales, press on button again display says CAL press on button and it at first came up with EEEE and failed but next attempt it said PASS and it all worked again. I used 2 x 1.5kg bags flour and 2 x 1Kg bags sugar to make 5kg with bit tipped out of one to make exact and checked on another set scales. So trick appears to be finding how to get your scales in to calibrate mode and what the weight it expects is.
Jun 15, 2009 | Balance Health & Beauty
Radio displays EEEE, wont accept code
Did you enter the code in the proper sequence? I reprogrammed mine and it took quite awhile to reset. The manual will tell you how long it takes. It works fine now. Hope this helps.
May 10, 2009 | 1992 Volvo 740
Digi-Weigh Body Fat & Calorie Monitor/Scale Logo
48 people viewed this question
Top Digi Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Digi Health and Beauty Expert? Answer questions, earn points and help others
