Question about Vizio 42 in. LCD TV
I'm watching football and cannot see the top score
I'm watching football on my 42" Vizio and cannot see the top score bar or the bottom ticker. Under adjustments, it says my "v-size" is not available to adjust. Any ideas?
  • Anonymous Mar 23, 2014
    Can't see the football score on the top left corner of screen
    Problem Solver:
  • 15 Answers
You should adjust the aspect ratio on your cable box. Depending on your cable company there should be an aspect/HD zoom button. If this does not work go into the TV settings using the "menu" button and try to find a reference to aspect. Make sure it's set to 16:9 normal vs. stretch. You can contact Total COntrol Remotes (www.totalcontrolremotes.com) for help with this kind of issue.
Posted on Sep 06, 2009
Testimonial: "Yayyyyyy...You have made my football watching experience magnificent!!!!!!! Thank you so much!"
  • creinh2115
    creinh2115 Dec 09, 2012
    Thank you so much. Been fighting with this for weeks.
    New Friend:
Correct- changing the setting is acheived through the cable (remote), not the tv settings (vizio remote). In the top right of the tv screen it likely says 760i and it needs to be set at 1080i.
Posted on Nov 23, 2012
Vizio tv settings
Check your aspect setting; ie: picture size, zoom settings
Nov 28, 2013 | Televison & Video
Cannot see score bar at top of screen during NFL games
Try operating on screen adjustment command, if there is no way to adjust screen position , then it may be a faulty component inside the TV.
Is the tv still under guaranty?
Sep 07, 2008 | Sony Grand WEGA KF-50WE620 Television
The image display on my Westinghouse 42" LED TV does not fit the screen. It is zoomed in, so when watching sports, i cannot see the score and time ticker.
Using the remote go to the menu for the TV. Look for picture or aspect ratio. Make sure it is set to 16:9 and not zoom or auto. That should clear the problem up.
May 15, 2012 | Westinghouse LD-4258 42 Class Widescreen...
The screen on our 42"
  • Turn on your VIZIO HDTV. Press the orange button with the "VIZIO" logo, which looks like a letter "V" with a triangular wedge in the center. If there is no VIZIO logo button, press the "Menu" button. Press the "Right Arrow" button twice to highlight the "Setup" icon, which looks like a wrench.
  • 4
    Press the "Down Arrow" button three times to highlight the "Wide" menu item. Press the "Left Arrow" or "Right Arrow" buttons repeatedly until the correct aspect ratio is selected. "Normal" is for a standard definition 480i signal, which has a 3:4 aspect ratio. "Wide" is for high definition signals, and has a 16:9 aspect ratio. "Panoramic" stretches the outside of the image while keeping the center at the normal aspect ratio. "Zoom" enlarges the image on the screen. Press the "Last" button twice to close the VIZIO on-screen menu.
  • 5
    Watch the image on the screen of your VIZIO HDTV to ensure that the picture is at the right aspect ratio. If it still looks distorted, it's most likely because you chose the wrong aspect ratio setting, because your source device is set incorrectly or because you used the wrong connection method.
  • Feb 27, 2011 | Vizio VW42LF 42 in. LCD HDTV
    The vertical screen cannot be adjusted. Watching football games the score cannot be seen at the top of the screen. changing vertical center and vertical size has no effect
    You question shows its Sony KDL-46S2000 lcd tv so adjust screen format like zoom etc to adjust picture size best fits in screen.
    Screen format option is available in Menu.
    Dec 06, 2009 | Sony BRAVIA KDL-46S2000 46 in. LCD HDTV
    Adjusting screen on HD TV
    I had the same problem. My cable company told me to press the # button on my remote to change it from "zoom" to "normal" and it solved the problem.
    Oct 21, 2007 | Televison & Video
    Wacthing sports -Tickers and scores are off screen in HD
    skilled,senior tech needed to access servicer mode and check/adjust geometry/convergence. if unresponsive,then replace convergence and re-check geometry and alignment.
    Sep 30, 2007 | Sony KP-51WS510 51" Rear Projection...
    Sharp 42In
    Go to the Menu
    Select Setup
    Select Position
    Select V-POS and move the slider to the right.
    If you do this when the score scroll bar is on the bottom of the screen you can make the adjustment to suit your needs.
    Sep 21, 2007 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
    Picture size too large
    Did you try chaging the aspect ratio in the setup menus yet?
    Feb 19, 2007 | Philips 46PP9302 46" Rear Projection...
    Open Questions:
    See all Vizio 42 in. LCD TV Questions
    Vizio 42 in. LCD TV Logo
    5,189 people viewed this question
    Top Vizio Televison & Video Experts
    pzarnold
    Level 1 Expert
    Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
