Question about GE GSS25JF Side by Side Refrigerator
HOW DO I DEFROST FREEZER - GE GSS25JF Side by Side Refrigerator
  • seaside959 Sep 06, 2009
    not what i was talk about
  • 10,515 Answers
Most modern freezers don't need to be defrosted, but should be washed out and cleaned periodically. Following are steps for defrosting freezers that need it -generally when ice builds up to a thickness between 1/4 inch and 1/2 inch.
  1. Step 1 Turn the freezer off. Controls may be inside the refrigerator.
  2. Step 2 Remove all food from the freezer and store in an ice chest while you are defrosting.
  3. Step 3 Remove ice in the freezer compartment. This can be done by: a) letting the freezer door stand open until ice melts; b) putting a pan of hot water in the freezer compartment and closing the door, then checking for melting ice and reheating the water every 10 to 15 minutes; c) using a hair dryer by aiming warm air at ice in freezer until it melts.
  4. Step 4 Pick up ice and water as it melts with a dishcloth or sponge and deposit into sink.
  5. Step 5 Use a sponge or dishcloth and a bowl of warm water to thoroughly wipe out inside of freezer once the freezer is cleared of ice.
  6. Step 6 Turn the freezer back on, close the door and let run for 10 to 15 minutes before returning food to the freezer.
  7. Step 7 Put food back into freezer and close the door.
You can also look at the Video :-
http://www.videojug.com/film/how-to-defrost-a-freezer
Hope i helped you.
KINDLY RATE THE SOLUTION IF 100% SATISFIED.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Sep 06, 2009
  • taran_2005
    taran_2005 Sep 06, 2009
    Sir,
    Kindly read your question.
    Thanks
Refrigerator and freezer get cold but freezer does not freeze whirlpool 1997 model et22dkxfn00
Can you remove the rear panel in the back of your freezer and tell me what the frost pattern looks like? When a refrigerator loses Freon the frost pattern looks like this photo HERE If the rear wall of your freezer looks like this you still are having a defrost problem photo HERE
Here is what that will look like behind the rear panel of the freezer should the defrost heater and defrost thermostat need replaced HERE
You mentioned that you have already replaced the defrost timer so we should not be concerned about that. The defrost heater=> 2315530 Defrost Heater
The defrost thermostat=> 4387503 Defrost Thermostat
I will be here should you have questions or comments, Thanks Sea Breeze
Mar 04, 2013 | Whirlpool Refrigerators
Freezer not cold.
Check the temperature setting
Assure that there is enough room for air flow in the freezer or freezer
Check for air flow restrictions in vents
Test the temperature control
Clean the condensor coils
Check the door seals
Test the door switch
Test defrost heater
Test defrost timer
Test evaporator fan
Check for a clogged drain tube
Check for refrigerant leak
Freezer is too cold
Freezer is noisy
Hissing and popping is normal, it is the defrost heater.
Check that the freezer is level
Check the drain pan
Check the condensor fan
Check the evaporator fan
Inspect the compressor mounts
Freezer runs continuously
Defrost the freezer
Freezer starts and stops frequently
Check the outlet voltage
Test the condensor fan
Test the compressor relay
Test the overload protector
Test the compressor motor
Freezer does not defrost automatically
Test the defrost timer
Test the defrost heater
Test the defrost thermostat
Freezer has an unpleasant odor
Remove spoiled food
Clean freezer interior with a solution of h
Clean freezer interior with a solution of hot water and baking soda
Clean the door seals
Remove breaker strips and check for wet insulation
Water on floor outside of freezer
Check the drain pan
If you have an ice-maker, check the water supply hose going into and coming out of the water inlet valve
Water inside the freezer
If you have an ice-maker, check freezer and ice-maker for level
Hope this will help in solving the problem.....
Oct 07, 2010 | Frigidaire Refrigerators
Freezer is working refrigerator is not.
The freezer is not defrosting. Look at the back wall of the freezer section and see if it is frosted. Locate the defrost timer and advance it till it clicks once. This should advance the freezer to the defrost cycle. Check to see if the defrost heater is on. If the defrost heater is glowing behind the freezer rear panel the you know you have to replace the defrost timer. If the heater is not glowing then you have to check if the defrost heater or defrost timer is in default.
Dec 27, 2009 | Amana ABB1927DE Bottom Freezer...
Freezer temp very unstable... lots of ice build up on inside inte
This appears to be a defrost problem. Either the defrost heater is burned out or the defrost thermostat is defective. Look into the rear wall of freezer for a layer of frost building up that will tell you that there more than likely is a large area of snow and frost building up on the evaporator coil. Once you manually defrost the coils you will be able to see the part number WR51X10038 Defrost Heater. It has a glass tube on the outside so it will be easy to spot if the defrost heater element inside is burned out. If you change the defrost heater I recommend that you replace the defrost thermostat part number WR50X10054 Defrost Thermostat. The defrost controls on your model come from the mother board so the is no defrost timer or adaptive defrost. The mother board make the decision when to defrost. When you are able to unplug and inspect the evaporator coils in back of freezer back wall panel let me know what you find, Thanks Sea Breeze
Sep 18, 2009 | GE PTS22LCS Top Freezer Refrigerator
Freezer suddenly is creating mounds of freezer "fluff"
That snow is the condensate build up on the evaporator coils behind the rear panel of your freezer. Normally the freezer will go into defrost about every 10 hours and this snow will melt and drain out the defrost condensate line below the evaporator and go to a pan under your refrigerator and return back to the air inside your home. I believe your freezer is missing the defrost cycle either because the controls for the defrost are defective or the defrost heater and defrost thermostat is defective. I would be watching for an increase in refrigerator temperatures soon, due to loss of defrost. We will need to unplug and examine the evaporator coils behind the rear wall of the freezer. If frozen or covered with snow then defrost with a hair dryer and lets check the defrost heater and all its related components. Sea Breeze
Aug 20, 2009 | KitchenAid KSRS25ILSS Side by Side...
Freezer frosts up and food gets soft
Repair the defrost system, defrost timer,defrost thermostat and defrost heater.
Aug 18, 2009 | Refrigerators
Frosts up wont get cold MCBR1000S
If freezer is icing up, you might have a defrost problem. Frost free models have a heating element that is controlled by a timer to automatically defrost ice, defrost timer turns on defrost heating element every 12 hours to melt ice in freezer and allow good air flow.
You can test defrost element with an ohm meter(located inside freezer coils-will have two wires going to a plug connection), if OK replace defrost timer (located in various places depending on make and model
Aug 17, 2009 | Magic Chef CTB1821AR Top Freezer...
Freezer stopped working
ok,is the freezer fan working?is there frost buildup in the freezer?it sound like you have a defrost problem whick means your defrost timer,defrost heater or defrost sensor has failed,you need to check all the defrost parts to pin point the problem,let me know what you find-mike
May 22, 2008 | Traulsen Reach in Freezer - G12010
GE Monogram Side by Side 42" Freezer light is lit on front panel.
The defrost timer is what I think you are asking. It is behind a cover near the light, The timer puts the fridge in defrost ever 6 to 8 hours. If the timer is bad it will stop the cycle of defrost and cause the freezer and the cold food section to warm spoiling the food and increase the freezer temp. Try turning the timer screw clockwise until you hear the fridge compressor stop. If after this listen for a crackling noise that will be the sound of defrost taking place. If doing this starts defrost, you will need to replace the timer.
Oct 20, 2007 | GE Monogram ZICS360NRRH C... Bottom...
GE GSS25JF Side by Side Refrigerator Logo
317 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
RepairNinja
RepairNinja
