Question about GE Adora (DSF25KGTBG) Side by Side Refrigerator
Ge adora top half not cold on both sides - GE Adora (DSF25KGTBG) Side by Side Refrigerator
    Sergeant:
    Champion:
  • 214 Answers
Sir, To solve this problem, you must open the compressor area at the back bottom of the refrigerator and chek the temperature of the pressure line. If the temperature is between 55celcius to 60 than its ok. Or else you need to change the refrigerant. I suggest you to contact the service authority.
Thanks for contacting Fixya.
Posted on Sep 13, 2009
Refrigerator no cold
Sounds as if it lost its gas in the move. Check for broken pipework or capillary. It might be repairable.
May 16, 2012 | GE Adora (DSF25KGTBG) Side by Side...
GE Adora Refrigerator. On the freezer side, water seems to be leaking from the top/back of the freezer. Not sure how it's happening, as it's usually frozen when I realize it. My housemate believes...
Hello
Check fill tube that puts water into ice maker. You may need to use hair dryer to thaw out. Look for a tube that comes out of back wall of freezer behind ice maker section. Make sure its there and pushed all the way in .This is a bad GE design. (could have fallen out)
hope this helps
Aug 16, 2011 | GE Adora (DSF25KGTBG) Side by Side...
My food is freezing in the refrigerator section. It is a GE adora
yes try lowing your number on your t-stat knob. and also the other knob should control the amount of cold air coming from the freezer to the ref. u want to make freezer colder that makes ref. section warmer. and that help. try this ok. later gator.
Feb 17, 2011 | GE Adora (DSF25KGTBG) Side by Side...
GE side by side ADORA, refer and freezer or not cold, cleaned and unplugged to maybe reset. Unit is 4 years old.
return air ducts from the freezer may be iced up, unplug unit and use a hair dryer to defrost. The ducts will be behind the rear panel, but just let the hot air circulate for a couple of hours to really defrost it
good luck
Nov 26, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
My G.E Adora refrigerator freezer is not cold enough. Ice cream is melting and refrigerator is at too cold and is freezing food, It is only 5 years old. It is a side by side. Help!
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Sep 18, 2010 | GE Adora (DSF25KGTBG) Side by Side...
Our GE Adora Refrigerator's ice maker isn't working properly
Perhaps your freezer isn't set cold enough - or your freezer door seal is not sealing correctly and the ice cubes are melting in the bin and sticking to one another and the spiral screw that delivers the ice.
Mar 14, 2010 | GE Adora (DSF25KGTBG) Side by Side...
My GE Adora side by side refrig. has stopped making ice and I am having a hard time regulating the settings on it. The freezer is too cold and the refrig. section isn't cold enough. I also have noticed...
Defroster circuit/timer has failed.
The water line to the icemaker has probably frozen,so no ice. The cooling coils are in the freezer, and the cold air moves to the fridge via vents and circulation fan.
When it all ices up, no air gets to fridge, fridge gets warm.
Many models have a mechanical defroster timer located under the lower front kick panel. Manually rotate the timer until you hear the compressor stop.
Defroster heater then should come on and you hear scorch/hiss/gurgle of defrost sounds. If the timer is working, the fridge should come back on after about a half hour or so.
Sometimes timer fails, sometimes heater element fails. There is also a defrost thermostat that's part of the heater assembly.
http://www.appliance411.com/faq/howdefrostworks.shtml
Oct 23, 2009 | GE Adora (DSF25KGTBG) Side by Side...
Top rack slider
All I can think of is that the runners on the rack are not in the runner slide on the machine properly or there is an obstuction (EG:loose screw)in the runner on the machine side
Jan 22, 2009 | GE Adora GHDA656LSS Stainless Steel...
GE Adora Side by Side Loose Handle
do the covers pop off to tighten screws on the handles
Oct 21, 2008 | GE Adora (DSF25KGTBG) Side by Side...
GE Adora (DSF25KGTBG) Side by Side Refrigerator Logo
159 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
