Question about Canon EOS Digital Rebel XS / 1000D IS Digital Camera
Canon eos rebel won't turn on, charged the battery, replace and it would turn on but if you turn it off it won't turn back on. Took the battery out and replaced it would turn on until you turn it off again, then it won't turn back on. What do you think?
  • 1,606 Answers
Went through the same thing. Ended up sending it back to the Canon repair depot. Evidently this is a common and rather annoying problem with the Rebels main board power section It is covered under warranty so it is best to check for coverage and get it in there.
Posted on Sep 06, 2009
Testimonial: "Thanks, i give it a try!"
5 Suggested Answers
SOURCE: Canon Rebel focus
I would only suggest you might clean the metal contacts on the inside rim of the lens....just be very careful what you use....a pencil eraser is good but make sure you clean away any shavings that might get into the camera...
Posted on Dec 14, 2007
Maanita
  • 1142 Answers
SOURCE: Canon EOS Rebel 300D: Suddenly
Hard reset do a flea power then check the unit
Posted on Apr 08, 2008
  • 155 Answers
SOURCE: canon rebel eos ds6041
DS6041 is the model number for Canon EOS Digital Rebel or 300D. It is a 6.3 megapixels DSLR camera from Canon.
All software and manuals available from the Canon site
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=314&modelid=9430
Posted on Feb 18, 2009
SAFFOTO
  • 77 Answers
SOURCE: Canon EOS Digital Rebel XT will not turn on.
It could be a number of things. The first thing you shouild do is remove the back cover and check for loose screws. If you don't find any, the problem may be a damaged battery door switch, a damaged memory card slot door switch, or worse- it may be a defective power board.
Posted on Feb 03, 2010
My Canon xti stopped working at my son's graduation. I had a full battery and took a few photos.....then turned it off.....and when I turned it back on again, it was completely dead. Tried several...
Hiyou might have a problem of either main pcb or power control pcd (dc/dc convertor). it is common but it cost. It cause usually come from loosen screw going around inside and short. If it is lucky, then your unit would just a fuse brown. If not, it has to change main pcb and all of computer adjustment is involved. Your local repair shop would charge you around $65 to 235.
Jun 04, 2011 | Canon EOS 400D / Rebel XTi Digital Camera...
I have a canon rebel xs, i took a few pics and then it stopped working. the battery had charged all day and says it is charged but it wont come on. I have had this battery for 2 years, could it be the...
The light at the bottom right is just telling you it's looking at the memory card. My canon batteries are about two years old and are due for replacement because they are not holding charge very well. Unfortunately all rechargeable batteries eventually lose their ability to hold charge
Jan 16, 2011 | Canon EOS Digital Rebel XS / 1000D IS...
My camera wont turn on. The battery is freshly charged, it is installed properly and the battery compartment door is shut correctly. At one point the flash would come up, but no display on the lcd and the...
I can help you fix the BUSY Error or Error 99 of your Canon EOS Rebel XS / Canon EOS 1000D.
Installation of this Canon EOS Rebel XS / Canon EOS 1000D firmware version 1.06 update will solve these problems:
  1. Some cameras may exhibit a phenomenon in which the LCD monitor does not display, the shutter does not release, and the BUSY indication remains lit in the viewfinder.
  2. The message, "Err 99 Shooting is not possible. Turn the power switch to<OFF> and <ON> again or re-install the battery", appears on the camera's LCD monitor, and after the above operation is carried out,the LCD monitor displays in a language that is different from the actual language setting.
See the firmware instructions and download the firmware upgrade by following these Fixya Tips :
  1. Follow this link to download a pdf version of the firmware installation instruction guide.
  2. Follow this link to download the Windows Version of the Canon EOS Rebel XS / Canon EOS 1000D firmware version 1.06 update.
  3. Follow this link to download the MAC version of the Canon EOS Rebel XS / Canon EOS 1000D firmware version 1.06 update.
  4. Follow this link to download the Canon EOS Rebel XS / Canon EOS 1000D Instruction Manual.
I hope that helps.
Mar 25, 2010 | Canon EOS Digital Rebel XS / 1000D IS...
Dec 04, 2009 | Canon Rebel XT / EOS 350D Digital Camera
Canon 100 d screen is blank seems to be frozen when trying to take a pitcure flash will pop but will get busy sign battery fully charged
I hope that helps.
Oct 10, 2009 | Canon EOS Digital Rebel XS / 1000D IS...
Camera stopped taking pictures
Same thing happened to me a while ago. I was in a panic. I turned it on and off several times...no change. Finally, I turned the camera to the off position, took the battery out of the camera for about 30 seconds and put it back in again and it worked fine. No problem since.
Jul 27, 2009 | Canon Rebel XT / EOS 350D Digital Camera
I took my EOS1000D on holiday took two photo's now all I get is ''BUSY'' on the display
I can help you fix the BUSY Error or Error 99 of your Canon EOS 1000D.
Installation of this Canon EOS 1000D firmware version 1.06 update will solve these problems:
I hope that helps.
May 05, 2009 | Canon EOS Digital Rebel XS / 1000D IS...
Canon EOS Rebel problem
This is usually caused by a defective shutter release switch - it'll have to go into a repair shop - independent shops will charge about $110 USD - Canon charges about $180
Nov 26, 2008 | Canon EOS 400D / Rebel XTi Digital Camera
XT not turning on
I was taking pics with my rebel EOS and it turned off. I charged and changed the battery but wont come on
Sep 18, 2008 | Canon Rebel XT / EOS 350D Digital Camera
Canon EOS Digital Rebel XS / 1000D IS Digital Camera Logo
1,675 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
