There is a thick black bar across my screen. What
There is a thick black diagonal bar across my screen, it goes away after the television has been on for an hour or so. What could be the problem.
    Problem Solver:
  • 15 Answers
The thick bar you are seeing could be a couple of things - either your HDMI or any other wire your connecting has been run too close to electrical lines, or your cable incoming needs to be grounded and/or filtered. It could also be a defect in the TV - does it happen when the DVD is on as well?
Total Control Remotes - www.totalcontrolremotes.com is a good place to contact to help you with these kinds of isssues.
Posted on Sep 06, 2009
Toshiba 27A40 has single colored line across enter
Vertical output has cracked soldering. Around $150 to fix.
May 01, 2010 | Toshiba 32A33 32" TV
I have a black shadowlike bar about 4 inches thick running across the tv from top left to bottom right. how do i get rid of this. some time ago i had the same bar which just ran down the left side of the...
This could be due to some electrical interference. Make sure you are using a grounded (3-pin) power plug, and that the outlet is properly wired. For that take the TV to a another location and see if the problem goes away.
Make sure you don't have fluorescent light fixtures nearby--they can interfere with the picture, if the bulbs or ballast is defective.
Apr 13, 2010 | LG RU-52SZ30 52" Rear Projection...
4 inch horizontal black bar across my 42 inch dell plasma. tv doesnt shut off and sound ok
The thick bar you are seeing could be a couple of things - either your HDMI or any other wire your connecting has been run too close to electrical lines, or your cable incoming needs to be grounded and/or filtered. It could also be a defect in the TV.
Sometimes it will just go away.... Its hard to tell without actually looking at your setup and television.
Feb 25, 2010 | Dell W4201C 42 in. Plasma HDTV
The tv comes on and then goes completely out after about 20 sceonds. While it is on there are diagonal lines on a lime green field that do not move.
yes. if you have a black bright screen with about 16 to 20 horizontal lines going across, you have no video. suggest local service center. if it is a magnavox, this is easy. you have an open 1 ohm(approx. value) resistor on the crt board.
Nov 12, 2009 | RCA Televison & Video
Black Bars and Power Issues
Sounds like a solder bridge bewtween the IC pins double check the solder for any pins accidentally bridged with solder.
Sep 06, 2009 | Televison & Video
There is a rectangular black box across the screen - it goes away when I use the favorite button and have multi screens showing - it returns when I close out the favorites. Color, sound, picture quality...
in the customer menu--find the closed caption settings---you will most likely find the set has been set to TEXT 1---with the remote select either CC1 or OFF---the black box was for text (books) and was not ever used much---usually someone engages it by accident
Aug 07, 2009 | Toshiba 57H81 57" Rear Projection...
Black screen except for diagonal bar of image across middle of screen
Do the icons appear around the image? If so, maybe the front lens shutters are stuck?
Jul 31, 2009 | Sony Cyber-shot DSC-W80 Digital Camera
Pink bar across top of tv screen
This could be from 2 things. 1 is the optical block is going bad or 2 you got a peice of dust blown in from the cooling fan and its blocking the color filter internally. If you are capable you can take the tv apart and blow compressed air into the color block and remove the dust. Hope this helps
May 25, 2009 | Sony KDF46E2000 46" Projection HDTV
Red,green and blue lines across screen
I f these lines are slightly diagonal and they all showed up at the same time. you probaly have an open resistor in the ABL circuit. since your set is 13 yrs old, I would not put a penny into it.
You might take the front grill cover off and the panel behind it and find the little black box with 6 little controls 3 are for focus 3 are for screen turn the screen ones ever so slightly counter clock wise. the control in the middle is the green screen adjustment. If the green line goes away try the one labeled r for red and b for blue.
Mar 31, 2009 | Hitachi 50V500 50 in. HD-Ready LCD...
Televison & Video Logo
528 people viewed this question
Top Televison & Video Experts
Electro Med Services...
