Question about Acer Aspire One Netbook 8.9" Notebook
Power pin push back in netbook - Acer Aspire One Netbook 8.9" Notebook
    President:
  • 2,600 Answers
Are you asking about the socket on the left side of the unit? If this has been pushed in, you will have to disassemble the netbook. I have the service manual and place a link below that goes through all the steps and explains all operations of that model netbook. There is no other way to repair this type of damage. Good luck ParrotHead PC Repair
http://tim.id.au/laptops/acer/aspire%20one.pdf
Posted on Sep 06, 2009
Why won't my Netbook turn on?
A netbook brand new? Let me guess, an Acer One Aspire? There is no detail about the devicein question here.
If it's brand new, just return it, warranty. If it's an Acer One, you probably need a patch for the BIOS which by the way, is kin dof hard to get. Search for BIOS patch for XXXX (netbook model)
Apr 10, 2015 | Kocaso NB1400 13.3-Inch Netbook
Netbook won't turn on when plugged in
When you plug in the power cord is there any lightswhatsoever on the laptop, where the plug goes in or on the AC Adapter of thepower cord?
When you press the power button do you hear fans running, hard drive spinning,lights on the computer, hear any beeps or lights constantly blinking, hear theDvD/CD drive click and the light on the drawer of the DvD/CD turn on for asecond or two? If so the laptop is trying to boot or may have booted, butthe screen is not showing for some reason.
Beep tones and blinking lights tells the technicians what is going on with thelaptop and why it is not booting. Most times it's a motherboard issuewhen you hear beeps or blinking lights continuous.
Maybe your power cord is bad if you don't get anything to happen whatsoeverwhen you press the power button. And if that's true maybe you wasoperating off the battery the last time you had it on and since the power cordis bad, it was not charging the battery so the battery is drained and the powercord is bad.
Maybe you have a Static Charge Buildup. Remove the Power Cord, Remove theBattery, then Press and Hold the power button for 30seconds. After 30 seconds plug the power cord back in (leave the batteryout) and hit the power button to see if it boots. If it does, you can putthe battery back in and let it charge.Maybe your DC Power Jack which is where the power cord plugs into the computer is bad. Take an ink pen and push the tip inside the jack and see if the little pin wiggles, if so the jack is bad. You'll have to take the laptop apart to fix it. Most times it is soldered onto the motherboard, so you will have to desolder the old and solder a new one.
Mar 31, 2012 | Dell Inspiron Mini 10v Netbook Computer
Can't turn on my mini netbook inspirion - help
Maybe you have a Static Charge Buildup. Remove the Power Cord, Remove theBattery, then Press and Hold the power button for 30seconds. After 30 seconds plug the power cord back in (leave the batteryout) and hit the power button to see if it boots. If it does, you can putthe battery back in and let it charge.Maybe your DC Power Jack which is where the power cord plugsinto the computer is bad. Take an ink pen and push the tip inside thejack and see if the little pin wiggles, if so the jack is bad. You'll have totake the laptop apart to fix it. Most times it is soldered onto themotherboard, so you will have to desolder the old and solder a new one.
Mar 31, 2012 | Dell (INSPIRION MINI 10) Netbook
Broken central pin on power jack of Asus Eee PC 1015ped
I realize I'm providing a solution to an older problem, and may never hear back from the original poster.
I am providing a solution because in the event it may help someone else.
The center pin you state is part of the DC Power Jack. The jack on the laptop, that the plug from the AC adapter (Charger) plugs into.
The center pin is the Positive connection.
The outer metal pieces, on the inside of the cylindrical shape surrounding the center pin, make up the Negative connection.
http://www.lapdiy.com/asus-eeepc-eee-pc-1015ped-netbook-dc-power-jack-connector-p-581.html
Click on the two views shown of the jack to enlarge.
The view on the left, shows how the jack normally sits on the motherboard. Front faces you, and in upright position.
The view on the right shows the jack upside down, and the back faces you.
Note the 4 metal tangs which protrude up. Each has a squarish hole in it.
These tangs go through the motherboard, and are soldered to the motherboard. These tangs are Negative connections.
They connect to the metal pieces inside the cylindrical shape.
Looking at the Back of the jack, (Right view), you see a metal tang coming out of the center.
This tang is the Positive connection. It attaches straight to the Center Pin.
To replace the DC Power Jack, the Eee needs to be completely disassembled down to the motherboard in your hands.
(Observe Anti-Static Precautions. Use an ESD wrist strap. Average cost is around $3 to $6. Connect the alligator clip to a good ground source.
{ I connect to an unpainted surface, of the metal frame of an open, empty desktop computer case )
The broken DC Power Jack is c-a-r-e-f-u-l-l-y removed from the motherboard, and after the area is prepped, the new DC Power Jack is soldered into place.
http://www.youtube.com/watch?v=_2htZGio8es&feature=related
Regards,
joecoolvette
Oct 20, 2011 | ASUS Eee PC 1005HA-PU1X-BK Netbook
Power pin broken off
if this is the cable connector to your netbook then replace it preferably with a genuine partOtherwis e if its the socket on netbook you can buy these on the net but youll have to solder it in yourself ,,which is tricky but possible
Jul 19, 2011 | ASUS Eee PC 1005HA-PU1X-BK Netbook
I had a problem with firefox on my acer one, decided to use rescue disk to reinstall, now all I get is a black screen! The computer starts, no bios screen comes up, but lights flash, external dvd drive...
Your best bet is to take out the hard drive, plug it in to another computer, back it up, and then reinstall with the original disc, then put everything back on.
Mar 01, 2011 | Acer Aspire One Netbook 8.9" Notebook
My HP mini 110 have a bios password how i reset it?
you have a tutorial here...i hope it will help you
http://www.governmentsecurity.org/forum/index.php?showtopic=2411
Feb 12, 2011 | HP Mini 1000 Netbook
Have a new 7" Sylvania
Assuming that the restart was pushing the reset button on the back, then see my TIP at: http://www.fixya.com/support/r7350901-fix_synet07526_wifi_flashing
Dec 27, 2010 | Sylvania G-Netbook
My netbook EEPC 1610P DC input power pin which is coming from Netbook is broken, unable to charge battery
If you broke the central pin of the power jack in your favorite Asus netbook like my Seashell - don't despond.
You can do something like this:
http://sites.google.com/site/emerghelp/
Oct 23, 2010 | ASUS Eee PC 1005HA-PU1X-BK Netbook
Acer Aspire One Netbook 8.9" Notebook Logo
196 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
