Question about Coleman Electrical Supplies
Onan microquiet 4000 will not turn over. It was running for about 10 to 15 minutes at a time. Sometime even 30 minutes and then it goes dead. After trying to crank it back several times, it was turning over but not cranking. Now it will not turn over. Did I burn up the starter ?
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 29 Answers
Sometimes people mistakenly think there's a problem with a carb on Onan 4000 generators. Be sure to ensure the fuel pump is pumping fuel to the carb by pulling the hose off the carb and watching for adequate flow. A faulty electric fuel pump can often only show symptoms or act up after it is warmed up. Sometimes it may run for 10 or 20 minutes and just shut down. Check for fuel flow immediately upon stalling if this is your symptom. Mine would shut down after 20 minutes and not restart for awhile. I pulled the hose off the carb immediately and noted there was no fuel in the line and it would not pump fuel while holding the start switch on either. If you are mechanically savvy you can disconnect the hot wire the positive wire (red) leading into the fuel pump and connect it with 12 V and see if it pumps fuel out the hose also, but be careful to capture the fuel coming out the hose). Once cooled down it pumped fuel in a weaker than normal stream, but when hot after 10 or 20 minutes it quit pumping causing stalling of the generator. Replaced the fuel pump (and new filter while at it) and everything worked fine again on my 1995 Onan. Much stronger fuel stream noted too from the hose.
Posted on Aug 25, 2017
3 Suggested Answers
  • 4 Answers
SOURCE: what dose code 48 mean on an Onan Microquiet 4000
I assume it is a ky spec j-l. It is a field sense fault. The controller is not sensing the field voltage. Check for broken wires or replace controller.
Posted on Aug 12, 2009
  • 73 Answers
SOURCE: Onan Microquiet 4000 starter will spin but not turn engine
bendix is actual the spring that pushes the gear back out of the ring gears engagement your issue is more likely a rusted /corrodied incline engagemnt gear a little lube will probably bring ti right back (do not us WD_40) this is not a lubricant it is an anti lubricant any light oil will do Good Luck
Posted on Oct 23, 2009
Onan 4000 Microquiet shuts down after running for 20-30 minutes. If I direct 2 high power (400+ CFM) fans to the underside of it -it will keep running indefinitely.
check the current draw from the machine
being a 4000 watt machine if you are drawing 4000 watts it is overloaded as that is the surge power available not constant power which is around 3500 watts
that would account for the requirement of fans to keep it cool
even if It is not 4000 watt what ever capacity it is it is running in an overload situation
Jul 10, 2016 | Onan Microquiet 3600 & 4000 Generator
Onan 4000 won't turn over
check for bad battery, loose terminals ,dirty terminals , faulty starter relay
if it is not starting check for oil level is correct ( low oil level sensor turns off ), diesel -air in system
Jun 11, 2016 | Onan Microquiet 3600 & 4000 Generator
Onan 4000 microquiet generator
Check the ignition circuit, and trigger coil for correct resistance on the trigger coil, and the ignition coil. The trigger coil is a small module on the engine shaft near the flywheel.
Jan 31, 2015 | Onan Microquiet 3600 & 4000 Generator
Onan generator microquiet 4000
Check the pickup tube in the vehicle, the fuel pump is suspect. If you check the fuel pump pressure and it is ok, then try installing a test check valve between the fuel delivery hose to the generator. If it solves the problem the pump is losing it's prime internally, so replace the fuel pump.
May 24, 2013 | Onan Microquiet 3600 & 4000 Generator
Onan 4000 generator has no spark
If there is no spark, the ignition module may be bad, or the wiring to it. Have the module ohmed out. Also the magnetic trigger assembley that is on the rotor that sweeps past the ignition module maybe broken. If they check ok, suspect the control board
Mar 23, 2013 | Onan Microquiet 3600 & 4000 Generator
I have a Onan Microquiet 4000 in my Motorhome. It sat for a while and then I was unable to start it. I took off the carb and thoroughly cleaned it. The generator fired right up after that, it runs great...
Sounds like the float is out of adjustment, it's not keeping the bowl filled.If the float is not at correct height or the bowl was not placed back in the correct position it could show these symptoms , some bowls have a small indent on them and that recess should clear the float for proper movement of float. Or check to make sure that you have no water in fuel tank. Good Luck...
Mar 31, 2011 | Watts Onan Portable Generator - 4000 ,...
Oct 12, 2009 | Electrical Supplies
Onan MicroQuiet 4000 Generator
Remove the air cleaner and inside near the throat of the carb is two bolts holding the carb to the intake remove these. Unhook the fuel line and twist the carb to allow the linkages to remove.
Sep 14, 2009 | Watts Onan Portable Generator - 4000 ,...
Onan microquiet 40000 in toyhauler ,runs for 15minutes and off
Take and locate the oil pressure switch and try bypassing it,if that aint it check fuel filter and pump.
Jul 22, 2009 | Watts Onan Portable Generator - 4000 ,...
Electrical Supplies Logo
352 people viewed this question
Top Coleman Electrical Supplies Experts
John Trevino
Shawn DuRee
Phil Walker
Phil Walker
Are you a Coleman Electrical Supply Expert? Answer questions, earn points and help others
