Question about Whirlpool Duet GHW9150P Front Load Washer
Detergent dispenser filling with water and i can't remove it to empty it.
My whirlpool washing machine (front loading) is not rinsing the water from the fabric softner section and I cannot remove the dispenser tray from the machine to empty it. The machine is pretty new and problem has only started in the last week or so. Can anyone help?
  • Whirlpool Master
  • 744 Answers
This video will show you how to clean the whirlpool soap drawer and will also show you where to put the detergent. Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Aug 23, 2013
It comes out push on the little black tab and pull, then take it apart and rinse it
Posted on Dec 09, 2007
2 Suggested Answers
SOURCE: Detergent dispenser filling with water and i can't remove it to empty it.
Hello Everyone,  I had the same problem with my washing machine, what I didn't find the push button they are talking about, but what I realised, that at the bottom of the drawer, in the middle of it, there is a hing that keeps the drawer in its place, I used a screw driver to push that hing, and got the drawer out.
I have cleaned the fabric softner section, but when i put it on again, I got the same problem again, I am not sure about the reason of that.
If someone can help on that one, that would be great ;)
Posted on May 02, 2009
Whirlpool front load washer w/bulk dispenser - over several wash cycles, the dispenser slowly fills with water and dilutes the detergent.
http://producthelp.whirlpool.com/Laundry/Washers/Washer_Cleaning_and_Care/How_to_unclog_my_Front-load_Washer_Dispenser
Apr 22, 2017 | Whirlpool Washing Machines
Water leaking from detergent drawer
The first thing to do is take note of what the washer is doing when water leaks out in order to help pinpoint the cause. Does it only leak when filling? Is it leaking during wash or rinses? Or is it leaking only when it goes into spin?
Only leaks when filling
  • Water pressure that's too strong. Some dispensers can't cope with high water pressure. Make sure the washer is level as one leaning forward can leak if combined with high water pressure. Try turning the tap on the washer down. Only suspect this if you know the water pressure is high and it looks like it's gushing in quite fast on fill
  • If there is an optional detergent flap fitted in the drawer for holding liquid detergent make sure it is removed or drawn into the up position if using powder otherwise it prevents detergent running down into the drum
  • A build up of grease and slime in the nozzles at the top of the dispenser where the water flows in causing water to spray at the front and run out when filling. Check this article -black jelly-like substance in soap dispenser and on soap drawer (In extreme cases I've had to replace the dispenser.)
  • A build up of undissolved detergent in the base of the soap dispenser under the drawer (depending on the design). Remove the soap drawer and check the bottom of the soap dispenser for a build up of detergent that could allow water to run over the lip of the dispenser
  • Blocked dispenser hose: Some washing machines can flood water out of the soap dispenser if the hose leading out of the dispenser into the tub gets blocked. Blockages can be something put into the drawer by a child or a chunk of undissolved detergent tablet. Indesit, and Candy, as well as some of the later Hoover washing machines suffered from this design flaw. The hose where the water is flushed down, was right at the front of the soap dispenser on these washing machines and it wasn't wide enough. Undissolved powder from a tablet or lumps of detergent through poor water pressure can block this hose solid causing water to back up. Unplug machine, remove lid and feel this hose carefully for obstructions.
  • Overfilling: If the washer starts to fill and never stops it will flood out of the drawer eventually - Washing machine overfills
Leaks out of drawer during the wash or rinse cycle
  • Too many suds? If you can see the door glass is white with foam up to the top it could be foaming out of the dispenser. Too much foam in the washing machine
  • Overfilling: If the washer starts washing but the water doesn't stop coming in it will eventually fill the drum so much it will start to pour out of the soap drawer and other places. If this is the fault you should be able to see the drum is so full of water it's making a different sound, maybe labouring under the load, and the door glass full to the top with water. You should also hear that water is still running into the machine and be able to detect it by opening the drawer. However, in most cases an over filling washing machine should trigger an error code long before it gets to this stage but if you suspect overfilling check this page - Washing machine overfills
  • Surging: There are (often intermittent) faults that can cause the motor to spin out of control on wash or rinses. Instead of turning slowly the fault causes the motor to surge into spin instead which throws the laundry and all the water about violently. Water can then be forced out of the soap dispenser drawer. This fault should be relatively rare these days but if you observe this behaviour call an engineer to diagnose the cause.
Leaks from drawer only when spinning
  • If it only comes out on spin it can be caused by a partial blockage preventing the water being pumped out fast enough resulting in excess water being thrown around on spin and backing up into the dispenser. This fault is similar to the surging fault described in the last list but different in that the problem only occurs when it's on a proper spin cycle and much of the water has been pumped away. Troubleshooting this fault is all about finding out why it isn't emptying the water properly which is usually due to a partial blockage. Follow the same troubleshooting as described for a washer not pumping any water out at all - Washing machine won't empty water
  • If water is being forced out of the drawer when the washer is spinning but it is on wash or rinse and shouldn't be spinning follow the procedure for surging in the previous section above
Dec 23, 2016 | Washing Machines
Why would the machine leak out the detergent drawer when filling?
When the machine starts to wash water passes into the detergent dispenser and carries the detergent into the drum, if the detergent outlet is blocked, or resticted, this will cause the water to leak out of the dispenser.
Check the dispenser to see if an accumulated crust of powder is clogging the outlet holes, most dispensers are removable for cleaning, check your machine instructions for details.
Dec 13, 2010 | Whirlpool GHW9400 Front Load Washer
Detergent dispenser does not empty after washing
it could be either a leaking water inlet valve or the pump is not emptying all the water from the machine and when it goes in to spin centrafugal force forces water back up the filler pipe
Jan 17, 2010 | Kenmore 44102 Front Load Washer
Fab. softener dispenser will not empty
I had this exact problem, with the exact same washer (but the Kenmore version), and it was solved by replacing (Not sure the exact name of the part) but its the plastic Detergent Dispenser housing, that you can see when u remove the Detergent Dispenser draw. There was a crack in mine,,, and the softner would either fully, or dispense half into the first rinse cycle.
Mar 13, 2009 | Frigidaire GLTF2940ES Front Load Washer
Detergent dispenser is filled with water after wash is completed.
The water is left there because the syphon action is not working in the dispenser, what you need to do is to remove the dispenser drawer completely and thoroughly clean the conditioner compartment, poking any holes or tube, particularly the syphon tube with a piece of flexible wire or similar to ensure it is completely unblocked.
. to test, fill the conditioner compartment with water, and it should slowly empty itself, if it does not, then it is still blocked.
Plz rate this solution.Thanks.
Dec 27, 2008 | Bosch Washing Machines
Dispenser full of water
believe it or not whirlpool says that's normal its in your owners manuel under dispenser because the washer mixes the bleach soap fabric softener with water for it to dispense they say its normal for water to remain but if you want to empty it there is a tab that you can press down on in the dispenser and remove it have a bowl handy
Jan 22, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
216 people viewed this question
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
