Question about Amana Refrigerators
Doors are not in alignment and bind when closing
  • 96 Answers
Have you tried to adjust the hinges? If not locate the hinges back off the screws, put something like a pencil between the doors and tighten the screws.
Posted on Sep 06, 2009
My garage door lurches while it is opening
If the alignment is true and rollers move with ease, you should not have any jerking motion. Unlock the door catch from the pulley line of the motor. The door should be FREE to lift by hand. With the door Free of the motor/line-pulley, lift by hand. Do so a number of times and see if it binds or is free to move up and down easily. If it binds, the alignment is off and needs adjustment. If it moves quite well, then the problem can be the door sensors. These are the two face to face sensing devices at the bottom of the metal guides on both sides. These sensors need to be horizontal and fixed to allow Line Of Site to operate correctly. Check both Alignments, Rails and Sensors.
Feb 03, 2015 | Genie Garage Door Opener 2562-TC 1/2 HP AC...
I have two Chamberlain LiftMater Professional garage door openers that are less than 5 years old. One unit works fine; but the other recently developed a problem where the door does not close properly. ...
switch out the motor units or use a simple hand held "spring scale" to see if the resistance on the two doors is similar. My bet is that something it binding.
is the unit that is not working used more or less often than the one that is working?
Nov 28, 2010 | Garden
I have two liftmaster garage doors. both of them have the same problem. when it is cold (50F or colder), when you press the button for the doors to close (iether from the remote or the wall switch) the...
You can re-post and see if a paid expert picks up the question.
It sounds like a peculiar situation with both doors doing something odd and identical.
You can buy new sensors for $20 and try on one door.
But why would both sensors give out same time and both do it only when temperature is below 50?
The cold weather factor seems to point to a battery-operated device that is not functioning.
Except same thing happens when you push wall button.
The sensors are not battery operated.
And what would be battery operated half-way through the closing sequence?
A bind in the door ... you can add grease to the track and replace individual wheels ... but why low temperatures? The wheels and track wouldn't change that much between 50 and 80 degrees.
Disconnect the door and see if it raises and lowers satisfactorily by hand, and that should eliminate a bind in the door.
But why would both doors bind? It would be odd if one door did that.
The problem sounds like it's in the electronics... but opener brands have unique circuit boards that require testing each part.
Usually circuits boards are just thrown out and new board installed, but finding replacement board and installing would probably be more expensive than new opener.
Certainly you must have the manual from 5 years ago.
Is there a parts drawing or troubleshoot section in manual?
Nov 20, 2010 | liftmaster Chamberlain Garage Door Opener...
Door not closing as it has dropped down slightly
Refrigerator Door alignment has long been the bane of homeowners worldwide, so you're not alone.
Any time you remove a door on a refrigerator you take it out of alignment. The best solution for reattaching the doors is from the bottom to the top. This way you will have access to all the screws as you assemble. First set the primary bottom pin, be careful to remember adding the non friction white plastic washer on this pin/hinge. How ever many washers you took off, you will have to replace. Also remember that all of the weight of both doors finally rest on this one main pin so it's alignment is most critical. Once this pin has been screwed into place (loosely) you may close the door and concentrate on manually adjusting the door until it is square and aligned with the body. Take special note of the gasket on the hinge side only and be sure that it isn't squashed bent curled or severely mashed as this will defeat proper sealing of the door.
IF the gasket is compressed to far you can add spacers to the facing of the bottom and middle hinge to bring it away from the main body of the box itself.
If you have lost your spacers you can make new ones easily from coffee can lids.
Once the bottom pin is aligned you can loosely attach the middle pin/hinge which controls movement of both the refrigerator door and the freezer door. Now you should be able to open the Fridge door without it binding on the bottom. If so, you should now close the door, realign to the body and tighten these screws. Check once again for free door movement. Now proceed to the freezer and repeat the above procedure, making sure to add the non-friction washers.Align to the box and make sure the gaskets close and float easily then tighten the screws and Viollah!
You're done!.
Mar 05, 2010 | Refrigerators
Freezer door pops open when other door is closed
when both doors are closed, do the tops of the doors line up evenly. if not, take a level and make the unit level in both directions the best you can and see if that takes care of the binding that appears to be taking place
Nov 22, 2009 | Freezers
My door lock indicators wont work
the rods inside the panel have to be aligned to lock into the sliders to get them to work properly
Jul 07, 2009 | 2000 Chevrolet Silverado
Zeroing scope adjustment
First, adjust wind-age and elevation to center or zero position. Remove your scope from the gun and make sure that the scope mounts are aligned, this is critical. Purchase an alignment tool is necessary. Then remount the scope. The scope should seat in the mounts without binding. If it does bind, the mounts are not aligned.
Start sighting in at close range,10 to 30 yards, then move out to 100 yards.
Jan 03, 2009 | Tasco 3-9x40 World Class Riflescope 30/30...
Can't open bedroom door
Check to see if the wood or the lock is binding. Try this:
Leave door open and turn on heat. After a few hours, try to close door and see if it's catching on the frame. If it is, plane the door where it is binding. You can check for binding by using chalk on the door and after closing it, see where the scrub marks are.
If it's the lock, take out the striker plate and using a chisel, make the cut out deeper. Install the striker plate and test it again.
Oct 22, 2008 | Hussmann Freezer 12 Facing Straight Glass...
Refrigerators Logo
53 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
