Question about Bose Lifestyle 30 System
Lifestyle 20 bose
I dont have the main unit is it possible to make the sub turn on without it?
  • Anonymous Mar 27, 2014
    However I recken the highs are very weak which leads me to believe something in the circuitry is causing both anomalies , I have it on almost full highs and back the sub off to under half and still its muffley ! which do you think?
    Scholar:
  • 48 Answers
By main unit i assume you mean the head unit or the CD control unit.
the answer is YES,
bose sell a part that will conect your ipod to you r bass box direcly ( or at least they used to) it was not passily powerd by the ipod however as the i pod can't maintain the current necessary to sustain the power up of the amp's control circuit. so it was powered externaly.
the answer is. you need 5 v dc at 500ma capacity on the centre pin to power up the bass module and thus bring the bassbox to life, the remainig pins carry L/R and a control voltage to adjust the volume, i will need a bit of time to find out which pins exaclty do what, as i cant remeber off the top of my head, but i'll bet you'll find the answer on a diagram if you do a search on the web. please also note that the 5vdc can also be varied between 1.5vdc and 8.5 vdc to adjust the volume of the bass box and the system overall, and so that is the major problem for you to solve if you want to build your own amp. ( maybe get your hands on a second head unit ( CD 20 ) cheap on ebay or something or spalsh out and buy a remanufactuerd one from bose. but maybe thats not what you had in mind .
:-) have fun.
Posted on Mar 08, 2008
Benwin 5.1 surround sound system Humming loudly without anything pluged into it!!!
It is sad your having a problem with your
If humming can be heard on all speakers, then it could probably
be on the power supply.
If it is only on the main SUB unit, then it could be the amp itself.
But check for power supply capacitors that supplies voltages to the
amps.Check for amp output DC voltages too.
Oct 04, 2012 | Audio Players & Recorders
Tip
ERROR CODES AND DESCRIPTION
2X Blink - Main Power Error
A 2X protection mode blink pattern can be activated due one of the
following defects.? Loss of REG12V (LVP)*
? Loss of -125V (Single Line)
? Excessive -125V Level (OVP)*
? Loss of Power-ON Signal
? Excessive PFC Voltage (OVP)
? Excessive PFC Temperature (OTP)*Low Voltage Protection (LVP)
*Over Voltage Protection (OVP)
For more check the following link. Use the search tab on the top right corner to find your product
www.electro-medical.blogspot.com
google.com/+AjinGopakumar
on Feb 15, 2015 | Sony Kdl-32ex720 - Series 32" Ex720 Bravia...
I have the Samsung HTDS 1000 system and i get the PROTECTION error as soon as I open it. I've noticed that this occurs only when the 13 pin cable from the sub is connected to the main unit. When I...
The protection message appears only when a short is detected. Since you get this message only with the sub connected it means that the sub is shorted and you will have to repair or replace it.
If you decide to repair you should open it and test the electronics - amplifier and power source - of the sub.
Apr 01, 2011 | Audio Players & Recorders
Can I plug just one subwoofer into my Yamaha EMX88S? What kind of sub do I need to get for it? Do I need to have 2 subs plugged in for it to sound right? Do I daisy chain the subs with the A15 speakers I...
it is not reccomended to daisy chain passive subs with main speakers, because there is no crossover unit involved. you want a sub to have a crossover frequency around 100hz, so that only frequencies lower than this go through the subs, and not in the main speakers.
you could get away with 1 sub plugged into the mono output on the front, subs dont have to be stereo. you would need a self popwered sub, or an additional amplifier+crossover for passive subs. your best bet would to be to get a powered sub and hook it up to the front panel mono out. powered subs usually already have the crossover built--in.
Nov 25, 2010 | Yamaha Emx88s Powered PA Mixer System
Wireless speakers will not pair with the main unit
TheSony Audio Interactive Radio Frequency (S-AIR) is a wireless digital audiotransmission signal that plays surround sound using a radio frequency that canbe placed anywhere that is convenient within the maximum communication distancewithout the signal breaking up. The system can transfer up to four channels ofCD quality (48kHz, 16 bits) audio data with no data compression.
You have to pair the S-Airunit with the Main HTS unit. When the sound transmission is not established,the indicator of the S-AIR sub unit does turnsoff, flashes or turns Red. Please try the steps mentioned below and checkif the issue can be resolved: · Make sure that there is no other S-Air unit nearthe one which you're using. If any, place it more than 8 meters (26 1/4 feet)away from the unit. · Make sure that the units that you are trying topair are within one meter (3 feet) of each other. · Confirm that the ID of the main unit and theS-AIR sub unit are set to the same ID. · You performed pairing the main unit and anotherS-AIR sub unit. Perform the pairing steps again with the desired S-AIR subunit. · The unit is paired to another S-AIR sub unit. Cancelpairing. · Install the S-AIR main unit and S-AIR sub unitaway from other wireless products. · Stop using another wireless product long enoughto confirm if the S-AIR main unit and S-AIR sub unit gets connected. · The S-AIR sub unit is turned off. Make sure theAC power cord is connected and turn on the S-AIR sub unit. How to cancelpairing? · Perform the ID setting of the unit as follows: · Press POWER to turn the unit on. · Press the FUNCTION +/- button repeatedly untilDVD appears in the front panel display. · Press DISPLAY while the system is in the STOPmode. · Once the CONTROL MENU display appears on the TVscreen, press the up arrow or down arrow to select SETUP , and then press + . · Once the options for SETUP appears, press the uparrow or down arrow to select CUSTOM , and then press + . · Once the SETUP display appears, press the uparrow or down arrow to select AUDIO SETUP and then press + . · Once the options for AUDIO SETUP appears, pressthe up arrow or down arrow to select S-AIR SETUP , and then press + . · Press the up arrow or down arrow to select ID ,and then press + . · Press the up arrow or down arrow to select thedesired ID, and then press + . · Once you select an ID (A, B, or C), theconfirmation display appears. · Once you have selected a new ID (or evenselected the same ID as before), pairing is cancelled. NOTE: To confirm the current ID, performsteps A-G listed above. When you pair the unit with the S-AIR sub unit, PAIRINGappears beside ID on the display for selecting an ID.
Pair the unit again and check if the issue is resolved.
Good Luck!
Nov 03, 2010 | Sony BRAVIA® DAV-HDX576WF Theater System...
The light on the refrigerator side of my Sub Zero does not work
The light switch at the top of the door frame is bad. it controls all the lighting including the display for the board. you will have to remove the grille up top, remove the cover over the 2 switches, and replace the switch that is all white. the one with a black back is for the fan and rarely goes bad. Just unplug the unit or at least turn it off before changing this switch, as it is live any time the unit is turned on.
May 05, 2010 | Sub-Zero 690 Side by Side Refrigerator
How to clean drain tube at the bottom of the refrigerator?
Sub zero drains dont usually cause a cooling problem. You could be having that drip because its not cooling enough. Check to make sure both doors close completely, check light switches-do the lights turn off? You will have two or three fans on this unit, one by the compressor, one in the freezer, and possibly one in the fresh food section.
If you have further questions, visit my website and send me a question. www.FixMyFridge.net
Mar 17, 2010 | Sub-Zero Bottom Freezer Refrigerator
Jbl sub 135 motorboating b4 warm up JBL sub135 I never heard it called motorboating, but that is a good description of the sound, It's like the sub is trying to output sounds which are not in its range...
Turning the unit on without any input signal, the speaker did the pop and scratching sound. I found on the limiter board ( small pc board on the main input pc board) that there is a wire jumper on the back side of that had a cold solder joint. You will have to clean up the glue that was used to hold the wire on the back side of the board. I just replaced the wire with new one.
Look at the +15vdc off of Q117, I moved it to the left side of the pc board and added a heat sink to the unit. The 1 watt resistor created some cold solder joints that you will have to check.
hope this helps
Feb 19, 2009 | Audio Players & Recorders
JVC TH-M505 powers off right away
The unit is going in to shutdown. My guess is a failed output. Service is going to be required.
Sep 20, 2006 | JVC TH-M505 System
Bose Lifestyle 30 System Logo
252 people viewed this question
Top Bose Audio Players & Recorders Experts
Invebo
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
