My aspire 5610 laptop is not booting and giving continuous sound
  • 1 more comment
  • srikanth_pac Sep 06, 2009
    how to swap the memory stic
    how to remove the ram and place it again in my acer aspire 5610
    how can i open the ram in acer aspire 5610?
  • 453 Answers
Http://www.retrevo.com/search/v2/jsp/mytrevo/myTrevo.jsp?page=man&e=1#myManualsDownloadForm
Click on the link above and look for the base view. It has 6 screws and remove the compartment. Once the compartment is removed. you will have two hinges on either side of the memory stick. move the clip slightly and the memory stick will pop out.
Kindly comment for further information.
Posted on Sep 06, 2009
  • 6,487 Answers
This is a sound of a bad RAM or memory of the computer, so what you can do here is to remve the ram and put it back in and that should correct the problem....
  • 19,396 Answers
If Windows start booting, then try reinstalling the system.
If the computer does not even start booting, and there is a continuous beep on startup, then try swapping or replacing the memory sticks.
If that does not work , then motherboard is faulty.
Hearing continuous beep sound at startup that disappears on Esc
I started having the smae problem yesterday with my Acer 1410 bought end of 2009. It started after I had stoped some suspicious process to work on start up (using msconfig). During the night I scanned the computer for virus but found nothing. Tonight I will enable those process to work on start up again and see what happens.
I will post the information tomorrow.
Aug 02, 2010 | Acer Aspire One PC Notebook
The sound on my computer wobbles. What could be
Could be that you need to clean up your computer, you may have too much running from boot up, and you dont have enough system resources left for smooth playback.
Give this a go
http://www.fixya.com/support/r5272277-secure_clean_computers
Jul 18, 2010 | Acer Aspire 5600 Series 5610-2013 Notebook
I have Laptop ACER Model No Aspire 5610.previously Sound was functioning Properly.Now only after inserting the headphone pin i can hear the sound .if i take out the pin & or if i call from my laptop...
The Speaker of your laptop has a problem. You need to check the connection or it could be the speaker was dusty due to not functioning. Try to clean the speaker of your laptop but if the problem are not solve you need to replace the speaker for that laptop.
May 29, 2010 | Acer Aspire 5610-4648 Notebook
Turns on but wont go pass the startup screen
Try to put an operating system boot disk in your drive then turn on laptop.
When the screen says press any key to boot from cd/dvd press a key.If it is vista when you do boot from cd it will give the option in the lower right corner to repair-click on this-select repair startup option.if that fails try a re-install of your op sys.
May 31, 2009 | Acer Aspire 5610 laptop vista combo with...
How to install solaris os on acer aspire 5610 model
Hello!!
You can insert the cd before booting and u can continue installing by selecting in which drive u need to install!!
Jan 15, 2009 | Acer Aspire 5610-4648 Notebook
Acer Aspire 5610 Laptop
If it had vista installed first then u are sol, unless u use a new hard drive. That is probably why your cam and several other things don't work. The laptop was designed for VISTA.
Oct 17, 2008 | Acer Aspire 5610-4648 Notebook
How to format acer aspire 5610 without cd
To format your laptop you need to insert a windows installation disc into the drive, restart the machine and before windows loads up you should see a "press anykey to boot from cdrom"
press key and follow the instructions, it will give you the option to format the laptop before it reinstalls it again.
any problems just let me know
All the best
John
Jul 27, 2008 | Acer Aspire 5610-4648 Notebook
Acer Aspire 5610 again
Are you trying to boot and run from CD or install XP?
Jul 25, 2008 | Acer Aspire 5610-4648 Notebook
Acer aspire 5610 wont boot windows XP
turn on pc enter bios setup select default settings save and restart.have os disk in drive wait for screen display any key to start from cd.press any key to load disk.in options select install windows ( not repair) your system will find existing os ,now you can choose repair or install fresh copy.if you choose to install fresh copy delete partition first and create new partition and format.
Mar 02, 2008 | Acer Aspire 5610-4648 Notebook
Cant get out of hibernation
does the laptop boot at all ? or just not logging to windows ?
if not logging to windows then unplug the laptop's battery the replug it and restart
if the problem remains,, try to boot in safe mode by pressing F8 continuously and then choose Safe Mode
if you success in booting in safe mode go to control panel and disable hibernate then try to reboot in normal mode
Dec 25, 2007 | Acer Aspire 5610-4648 Notebook
k24674
