Question about Whirlpool Ultimate Care II LSQ9564J Top Load Washer
My washer gets stuck on wash cycle...
Today my washer washed my clothes for 2 hours! we left and came back and the timer hadn't moved......I figure the timer is bad, but anyone else have an opinion? The spin cycle works fine i spun all the water out and got clothes out. It didn't move off the spin cycle either when i turned the dial to it.....
The only other detail is that the basin was tipped to the right...but maybe just because the clothing was uneven....Any help appreciated!
  • Whirlpool Master
  • 1,606 Answers
I would replace the timer . Pt # 3954071 . If the model number above your thread is correct .
Posted on Sep 06, 2009
Testimonial: "THANKS "
Will not rinse or spin
I have had similar situation with my top load washer over the years. It has been the timer 3 times and the water pump 1 time.
How I came up with it being the timer. The knob which you set it on the type wash you want. Put it on a different cycle and see if it completes the wash cycle. example if my washer is not working when I put it on heavy wash cycle I might put it on the casual wash cycle. If you change the wash cycle and it goes through the complete cycle it is probably the timer which is part of the knob you change for different wash cycles with.
If it stops when it is time to empty the tub on all cycles it may be the water pump which empties the tub. The one time I had a problem with the water pump it was a small piece of coal had the pump locked up. I never figured how it got out of the tub and to the pump but I put it back together and it worked fine.
It should not go into the spin cycle if the tub is full of water.
Two of the timers I bought cost 40 - 60 dollars. One was 140 dollars I bought a new washer that time because the washer only cost 220 dollars.
Dec 03, 2017 | Estate Washing Machines
Maytag quiet series 100 dishwasher won't complete a wash cycle - just keeps running and running until I turn it off after 2 or 3 hours
washer timer is faulty, gets stuck, if this occur more often , you definite need parts replacement on the washer timer switch.
Dec 28, 2013 | Maytag Washing Machines
Rinse cycle not happening
CHANGE THE LID SWITCH AND OR TIMER
Apr 08, 2009 | Haier XQJ50-31 Top Load Washer
Kenmore 90 series washer will get stuck in between cycles
Sounds like the timer has failed. It's a common problem.
Part number 8545379, $83.69 from SearsPartsDirect.com
Feb 04, 2009 | Kenmore 24032\24036 Top Load Washer
Matayg Atlantis Washing Machine gets stuck in the Rinse Cycle and will continue to rinse for hours.
This is the sign of a bad timer. It is not sensing how long it has been in the cycle. The timer is not advancing. Replace the timer.
Feb 03, 2009 | Maytag Atlantis MAV6000 Top Load Washer
How to Reset a GE top load Invensys washer timer?
remove slide cover .. move the slide lever back untill it is on #1 or the lowest setting... hope it helps
Oct 31, 2008 | GE Energy Star WCVH6260F Front Load Washer
My Hoover Model Not listed/stops during the cycle
the cycle timer is beginning to sieze because it needs oil. disassemble washer to the point where you can apply small drops of 30W machine oil to the timer's bearings
May 20, 2007 | Hoover HTC243 Top Load Washer
Whirlpool Ultimate Care II LSQ9564J Top Load Washer Logo
193 people viewed this question
Dan Webster
Dan Webster
Sal De
