Question about Samsung 52 in. LCD Flat-Panel HDTV
When i push the power button it will click for 4 min before it comes up. any suggestions?
    Scholar:
  • 50 Answers
You most likely have low DCR or bad caps on the main power supply! I would like to help you fix your TV! Please feel free to call or message me if you would like help fixing your TV!
I'll need the model# of your TV and you'll need to be willing to remove the back cover from the TV! Do not lay the TV on the floor or a bed! Use a solid table with a towel laid down as not to scratch or damage the front panel!
Thank you! :-)
Dave
1-503-432-9904
pleasefixitdave@yahoo.com
Posted on Sep 06, 2009
Hitachi 42" ultravision...power light on, hear
Tries pushes the power switch on the remote few times,each times push wait like a 1 mins or 2 mins for the tv Tuner signal board to take it effect.This process should get ur tv picture back,because the tv Tuner signal board it is old and having problems,evenually require replacement of a refurbish tv Tuner signal board.Tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish tv Tuner signal board for the replacement.
May 23, 2011 | Hitachi UltraVision 42HDS52 42 in....
Lights come on but no fans or powerup
Please follow the steps below.
1. Please removed the battery and unplugged the power supply.
2. Held down the power button for 45 seconds.
3. After 45 seconds reinstalled the battery and the power supply and pushed the power button and if it works then you don't need to replace your motherboard.
4. Else try it couple of times or up to five times before it worked if worst comes to worst.
Thanks
Aug 26, 2009 | Acer Aspire 5050-3242 Notebook
Samsung HC-R4755W turns on and off by itself.
Have Capacitors checked in the power relay circuit, also if you have young children who like to push the buttons on the front of the set make sure none of the buttons are sticking inward or stuck in a pushed in posistion. More then likely it might be caused by a faulty System control board which we call the signal board, or bad connections on the power supply, Have a tech check the connections on the Flyback transformer and the High Voltage Deflection Area on the HV Power supply. I believe you have Cold Solder Joints in the HV Power Supply.
Hope you this helps you..
Apr 21, 2009 | Samsung HC-R4755W 47" HDTV
Akai tv
The power supply most likely failed on your LCD.
How old is your LCD?
Jul 26, 2008 | Akai LCT3201TD 32 in. LCD Television
F-11
FIRST COMMENT
F11 Serial communication error Communication between the Central Control Unit (CCU) and the Motor Control Unit (MCU) cannot be sent correctly.
Possible Causes / Procedure
1. Unplug washer or disconnect power.
2. Check wire harness connections to the MCU, the motor, and Central Control Unit (CCU).
3. Check the drive system for any worn or failed components.
4. Plug in washer or reconnect power.
5. Verify CCU operation by running a Diagnostic test or any cycle.
6. Check the MCU by looking for operations of the drive motor.
7. Check the drive motor for powered rotations.
8. Check that the serial harness at the MCU is not mounted upside down. The wires should be to the left when facing the MCU connectors.
Replace failed component.
Jun 15, 2008 | KitchenAid KHWS01PMT Front Load Washer
Damn TV....why doesn't it turn on when you push the power button??
Good Day, U-Fix- it;
Try this; CHECK FOR 10 VDC AT PIN 5 OF IC502 OF LOW, CHECK IC503 PART # 270P704010 ON THE MAIN PCB. 2. CHECK R529 .82 OHM 1/2 WATT OFF PIN 4 OF THE FLYBACK. IF OPEN CHECK C411 2200 UFD @ 35V AND IC 451 PART # 270P064020. ON THE MAIN PCB.
CHECK IC700 PIN 4 (AC-OFF) FOR 0 VOLTS DC, IF HIGH, CHECK FOR LEAKY D980 PART # 264P045040 ON THE MAIN PCB. 2. CHECK FOR 4.7 VOLTS DC AT CONNECTOR RF PIN 3 AND 4 ON THE SIGNAL PCB IF LOW SUSPECT PROBLEMS WITH THE SWITCHES/BUTTONS ON THE CONTROL PCB PART # 935D394001.
Good Luck, big IRISH.
Apr 29, 2008 | Mitsubishi VS-50603 50" Rear Projection...
Whirpool estate dryer teds680eq2 does NOTHING when start button is pushed.
NO POWER CAN BE A MULTITUDE OF PROBLEMS.
1 DOOR SWITCH 2. THERMAL FUSE. 3 MOTOR 4. TIMER
5. HOUSEHOLD VOLTAGE. 6. PUSH TO START SWITCH.
CHECK ITEMS IN THE ORDER LISTED.
THE DOOR SWITCH HAS AN ARM THAT EXTENDS DOWN INTO THE SPACE WHERE THE DOOR CLOSES. IT IS LOCATED IN THE UPPER RIGHT CORNER. PRESS IT WITH YOUR FINGER TO SEE IF IT CLICKS. THEN CLOSE THE DOOR AND SEE IF IT CLICKS WHEN THE DOOR SHUTS.
IF NO CLICK, REPLACE THE SWITCH.
THE THERMAL FUSE IS LOCATED BEHIND THE LOWER BACK PANEL OF THE DRYER DOWN BE THE EXHAUST. IT IS A SMALL WHITE ITEM WITH TWO WIRES ATTACHED.
JUMPER ACROSS THE TWO WIRES. PUSH THE START BUTTON. IF THE DRYER COMES ON, REPLACE THE THERMAL FUSE AND CHECK FOR PROPER OPERATING TEMPS.APPROX 160-175DEGREES FAHRENHEIT.
IF IT GOES BEYOND 220 DEGREES, REPLACE THE CYCLING THERMOSTAT LOCATED BESIDE THE THERMAL FUSE.
THE OTHER ITEMS SUGGESTED ARE MORE IN DEPTH AND REQUIRE A KNOWLEDGE OF READING SCHEMATICS.
Apr 16, 2008 | Dryers
No sound, just clicking
try recovery mode. to do this just connect it to your computer and push the hold button so the orange is showing. next push and hold the record button and the power button. it should go into recovery mode.
Feb 10, 2008 | SanDisk Sansa e260 MP3 Player
Rca p52937sg
Try unpluging it for 15 min.and try it ,if it don't work it might have a leak in your button,it is a simple and cheap repair.I suggest to call your local repair shop.
Dec 23, 2007 | RCA P52937 52" Rear Projection Television
Samsung 52 in. LCD Flat-Panel HDTV Logo
69 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
