Question about Sharp PG-C45X Notevision 2500 Lumens XGA 1024X768 LCD Projector with zoom Lens (PG C45X, PGC45X) Multimedia Projector
Have yellowish stain projecting on my screen - Sharp PG-C45X Notevision 2500 Lumens XGA 1024X768 LCD Projector with zoom Lens (PG C45X, PGC45X) Multimedia Projector
  • fishman69 Sep 06, 2009
    replaced the bulb same promlem. plus cleaned the lense
  • 346 Answers
HI,
I have done some research and it looks like this might be a common problem for a lot of those kinds of TV's. Here is an article that explains the yellow stain you are experiencing on your TV by Alex Scoble. If it is a Sony there is a class action lawsuit against them. If you TV is still under warranty then you are in luck. Take advantage of it right away. Here is that article.....hope it helps explain the problem to you.
Unfortunately, while I still like the sets and think that the technology is the best out there dollar for dollar for large screen TVs (50" and up), I have recently run into a problem with my set.
My set developed what is being called elsewhere as the "yellow stain" issue. Basically, something goes wrong with the display engine (probably in the SXRD chips themselves) that makes the TV start to put a yellow tinge to the display, most notably in the upper right hand corner of the screen. The longer the TV is on, particularly when displaying static images, the worse it gets. The problem goes away after the set is turned off for a few hours, but then comes back again after the SXRD HDTV has been on for a little while.
If you display a static image for 30 minutes or so, such as the main menu of the Xbox 360, the problem will show up when you switch to watch something else. Again, the problem mainly manifests itself on the upper right hand of the screen, but you will start to see the "yellow stains" elsewhere as well.
Another good example? Play a game such as Need For Speed: Carbon on your SXRD set for 30 minutes or more and when you switch to watch something else, you will continue to see a yellow stain in the shape of the Heads Up Display (HUD) used for the cars in the game.
Now, not all SXRD sets have this issue, but apparently enough do that there is a class action lawsuit against Sony over the issue.
Anyhow, today I had a repair person out to replace the display engine for my 50" XBR SXRD unit, a process which took around 3 hours or so. I was lucky that it happened while the unit was under warranty.
Then again, since the repair does not extend my warranty, even for the replacement part, I may be out of luck if the issue happens again in 9 months time.
What's odd to me is that none of the large screen manufacturers that I know of are offering anything other than a 1 year warranty standard on their sets. Sony is no different in this regard. Yeah, sure you can buy an extended warranty, but when you are already spending several thousand dollars on a TV, it's eggregious to have to spend even more for what should be a standard item for a solid state TV.
Doesn't it strike anyone as odd that old CRT sets typically had a 3 year (or longer) warranty, but these new sets that should have lower failure rates (except for perhaps the bulbs in rear-projection units) than older sets have just 1 year?
Any way you toss it, based on the comments of the repair person who fixed my set, Sony does indeed have a PR problem on their hands (poor Sony, this is what PR problem number n+1 for them in the last year or so) in regards to the relatively high failure rate of what should be one of their biggest hit products.
But as I said at the opening of this article, I still see no other technology that compares to SXRD (when it's working at least). DLP is half baked as long as they are only using one display element and JVC's LCoS variety isn't nearly as sharp as SXRD, oh and all the other large screen offerings are quite a bit more expensive than the SXRD units as well.
I just hope that Sony does good for all the customers out there that are having the "yellow stain" issue with their SXRD sets. In particular, they should fix for free even those sets that have the problem beyond their warranty period.
I'm also wondering if anyone with a newer generation SXRD unit has run into this issue or whether Sony was able to resolve whatever the problem was with their manufacturing process.
Posted on Sep 06, 2009
  • Sharp Master
  • 19,396 Answers
Check both the lens and the lamp. Probably the lamp need replacement.
Samsung HCN4226W yello stain around the screen
Its a problem with the screen, Plasma depends upon a chemical and eletrical impluses to create a display... I think you might just want to change the screen.
Jan 10, 2008 | Samsung HCN4226W 42" Rear Projection...
I have this blob discoloration that is in the center of my screen. what could this be its a yellowish green color
Yellowish green colour is usually caused by a burnt blue LCD Panel or the light engine requires servicing.
Jan 15, 2011 | Zenith E44W46LCD 44" Rear Projection...
Discolored screen
If this is an older tube projection tv, it sounds like you have burnt phosphors on the crt. No solution except for replacement of the crt's and that is expensive.
Sep 01, 2009 | Hitachi Televison & Video
The screen turns yellowish
That is true, problem is as old as lcd projection. Suggest buying a dlp product. they don't color decay
Nov 26, 2008 | Mitsubishi HC5000 LCD Projector
Stain on samsung dlp projection tv screen
Sorry to hear that. It is damaged/scratched sound like
Nov 15, 2008 | Samsung DLP HL-P4663W 46" Rear Projection...
I'm getting a smoky yellowish stain on the lower left side of my.
you have dust on the LCD's ..... it can be fixed by taking apart where the LCD's are and useing a air to blow it off .... but this is not a job for some one who dont know what there doing it is easy to brake the ribbing cables or damage the LCD's
Nov 11, 2008 | Panasonic PT-50LC14 50" Rear Projection...
Hitachi 50V710 has a yellowish circle in the middle of the screen
If you're good with electronics you can probably do it yourself. It's the price of the part that hurts ... around $1000.
Feb 18, 2008 | Hitachi 50V710 50" Rear Projection...
Yellow residual image/smear
I think it is time to buy a new set but if you want to invest some money in it then take it to a qualified tech as these projection sets are a bit complicated.your problem is a convergence the projection lens needs to be adjusted lens.good luck and bleeeing from belize
Mar 20, 2007 | Hitachi 57F500 57" Rear Projection...
100 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
