Question about RCA P56830BL 56" Rear Projection Television
Rca 56 promblem
Tv has 3 light,blue,green are ok red is out would this be lamp which looks to be one piece like capacitor etc.possible to replace myself if its just to remove/unplug n if not what price range for part n repair. TBERNARD
  • 61 Answers
Sounds like you have a bad screen asy,this is located under the plastic were the tubes come up thru the plastic,its in the right top corner and has 6 turn controls on it,part number is 204809,this part must be generic,the part has been discontinued by Thomson.
Posted on Mar 06, 2008
I took the back of the tv off and the blue lamp is not bright like the red and green. Could this be a coolant problem or lamp. I have the PT5492S Akai rear projection TV.
The blue is usually dimmer than the other two lens; what I would suggest is try to look into the lens with the set on; BE CAREFUL AND NOT TOUCH ANYTHING INSIDE THE SET.
If the red and green show a picture but the blue looks like a floodlight you have bad Glycol in the blue tube (common in these sets).
If all have a normal picture remember to wipe the lens clean at the top; do not try to take the lens etc apart.
Before you rate this information let me know what you find.
Aug 15, 2011 | Akai PT5492S 54" Rear Projection...
Samsung model hlt4675sx\xaa projection tv wont work. the stand by/temp light flashes red and the lamp light flashes green? it makes the sound that it makes when it turns on but no picture. we looked at the...
It could be the temp sensor going bad. This sensor sits on top of the metal housing which the bulb assembly slides into. The bulb assembly will have a hole on top and this is where the sensor is above. There is a small blue and white wire that plugs into it. If you pull the wire out and put a paper clip or wire in the coupling you will basically bypass the sensor connecting the blue and white wire. If your tv turns on then that is your problem. Its cheap too. Here were my symptoms..1] Turn tv on 2] Bulb would light up..(which eliminates the ballast) regular picture would show up (which eliminates the bulb and color wheel) 3] 30 seconds later tv would shut down with 3 flashing lights. After bypass the tv turned on as always and hasnt shut down yet. Always un plug tv first. Get the replacement part to avoid overheating and possible fire
Jul 31, 2011 | Samsung DLP HL-P5663W 56" TV
PT50LC14 Color problem with color too much yellow and green no white or blues can not correct is this the lamp again im on why does it seem that I end up replacing the lamp every year (on number 3 now)....
ok,,your problem is not on the lamp itself.,the problem is on your screen controller.the controller is connected on the plyback you can adjust the screen intensity of the red,green,blue cathode..on your screen adjustment.
May 17, 2010 | Panasonic PT-50LC14 50" Rear Projection...
When looking for a replacement lamp for my RCA D52130 I can't find any reference to it anywhere. Does anyone know what lamp it takes and where I can get one?
This TV does not have a Lamp. It has 3 Tubes, Red, Green and Blue and they, don't go bad quick like the lamp they normally last for years.
Good luck
Feb 18, 2010 | RCA D52130 52" Rear Projection Television
Screen is black two green blinking lights 1 red
Ur power supply needed to be rebuild,like changing capacitors,extra..Or buy a new power board,because it dead.
Sep 13, 2009 | Samsung DLP HL-P5663W 56" TV
Sound but no picture on RCA R52WH74TV.
You do not have Lamp in this set it is Projection has 3 Tube Red,Green,Blue. On power/deflection board CK capacitor cp150 2200uf 16v look to see if capacitor is puffed up on top if so replace it and 2 other caps in same circuit 220uf 35v they are green with gold writing on them also CK second ribbon connector make sure it is pluged in good.
Dec 21, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Replaced parts--here's where we/re at
Check all tubes Red ,Green look for crack or broke some even leak fluid out on board.
Aug 29, 2008 | RCA D52W19 52" Rear Projection Television
Sharp 56DR650 shows power but wont turn on, Sometimes it turns on
That's error code 32. Indicates lamp trouble or failure. The system will shut down automatically.
Aug 29, 2008 | Sharp 56DR650 56" Rear Projection HDTV
Televison & Video Logo
52 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
