Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
Replaced logic board and still doesn't work
I have a brand new 1/2 horse chamberlein opener. It is a screw drive, and i have replaced the logic board because the motor " overheated" according to the manual. So they said get a new logic board, well tried that and still doesn't work.
Any tips???
Thanks
  • petroccij Sep 07, 2009
    it just clicks once or twice and it doesn't move at all. It overheated so we waited like it said for 15 min. Then tried again and it wouldn't ever work again. Chamberlein sent me a new logic board, and it still doesn't work. Brand new machine too!!
  • Don Maggard May 11, 2010
    What does it do and what caused the motor to overheat? Why didn't you call for warranty service?
    Problem Solver:
  • 11 Answers
CHECK FOR SAFETY REVERSING SENSORS WIRE OPEN BROKEN OR DISSCONECTED , SHORTHED OR WIRE REVERSED
Posted on Sep 11, 2009
    President:
  • 3,197 Answers
Sounds like a bad motor.
Posted on Sep 09, 2009
I have an old Sears garage door opener 139.663900 that went dead this week.
you sure it has power going to it? the outlet it is plugged into is working for sure?
Jul 17, 2015 | Building Materials
Brand new Troy-Bilt XP Horse, model 13bx79kt011 - Won't Move
Confirm the park brake is off. If a hydro-static drive tractor starts but engagement of the operator controls for the transmission drive results in neither a forward or reverse drive of the mower itself, the operator should check that the manual bypass controls have not been left in the activated (bypass) position.
Look in to where the lever connects and confirm the movement. You should be able to hear the hydraulic oil with a slight whine as you activate the drive forward pedal!
See page 18 for bypass setting?
Cut and paste link
http://www.troybilt.com/wcsstore/TroyBiltUS-CAS/Attachment/ownersManuals/riders/HorseXP_2012_769-07569[1].pdf
Jun 27, 2017 | Garden
Ps3 disc spin
PS3 blu-ray drives are famous for this fault. sony know about it just like the YLOD fault but claim not responcabillity. which just sums sony up as a whole really.the disc wont spin as the motor that rotates the disc has shorted out (mainly due to poor parts i.e not brand new) as sony SHOULD be using.
sometimes the solder under the motor heats up so much it just melts and in turn also melts the contacts, thus stops the disc from spinning.
if your good at soldering and are patient, you could have ago at resoldering it again. then send sony the bill!! or do the easy way, open the ps3, remove the blu ray drive, take off the logic board (the main chip board at the bottom of the drive) and buy another drive from ebay. tip for you though, if you have a 60gb ps3, get a blu ray drive from a 60gb machine, if you have a 40 or 80gb get a drive from the same model, etc etc, you need the logic board as they are paired to the motherboard in the ps3, another cheap way sony tried to stop people fixing them and trying to force people to pay them for repairs. LMAO! anyway, when you get the other drive, just plug all cables in to your logic board and disgard the one the drive came with (the new drive i mean) and pop the drive back in once you get the bottom screwed back on, close the top, and that should be you all set again. hope this helps
Jul 16, 2012 | Sony Playstation 3 (PS3) Console
Hi, My g. door opener doesn't work. The
5 Blinks on the logic board LED indicates that possibly the motor has overheated. If you have unplugged the unit and waited minimum of 30minutes before plugging it back in, and it still will not operate, then the logic board will need to be replaced.
I hope this helps
May 12, 2011 | liftmaster Chamberlain Garage Door Opener...
Chamberline 1/2 horse truble shoot
check the infared sensors make sure those are working right. Yo may have to adjust the tension for bring down the door.usually a screw on the motor to adjust the senisitivity.
Oct 09, 2009 | Chamberlain Powerdrive PD422D 1/2 HP...
When my i-pod is attached to my computer it works and when it is
You need a new battery then. You can order one online for a reasonable price and installation is fairly easy. I have posted two web sites that sell batteries for iPods as well as step by step instructions for the click wheel iPod models. www.ifixit.com
iPodbatterydepot.com
Top Case Removal Begin by using a flat tool to separate the white plastic front case from the silver backcase. You will need to stick your flat tool into the crevice, work it down into the crevice,and then pry up so that the casing separates. Apply enough pressure so that your flat tooldoes not slip and scratch your iPod!Continue separating the casing by gently prying up all the way around the unit. It shouldbe much easier to pry the casing apart after you get the initial corner started.
With the casing separated, grasp the top half (the part with the front bezel) and flip it over. Note that there is an orange cable in the top left corner that connects the iPodlogic board to the headphone ports. If you gently grasp the cable and pull, it will slide out of its connector on the headphone port module board.
Headphone Jack Board Removal Before proceeding, you must remove the top case.There are two t6 screws holding the headphone port in place. Remove both of these screws. You can now remove the headphone module.
Hard Drive Removal Before proceeding, you must remove the top case.Hold the hard drive up, and remove the black tape on the hard drive connector. This will reveal the hard drive cable’s connector to the logic board.To remove the hard drive, grasp the cable (thumb on top index finger onbottom) and gently pull the cable out (away from you and the connector)The hard drive will now be free of the iPod logic board.
Hard Drive Cable Removal Before proceeding, remove the hard drive.To remove the hard drive cable, hold the drive, and gently pull up on the cable.It should come out easily.
Headphone Connector Cable Removal Before proceeding, remove the hard drive.To remove the headphone connector cable, Grasp the cable, and gently pull up. It should come out easily.
Logic Board Removal Before proceeding, remove the hard drive and headphone connector cable First, disconnect the battery connector by grasping the cable and gently pulling up to disconnect the cable from the logic board connector. Remove the 6 black T6 Screws.
With the screws removed slightly move the logic board to the left to give more access to the clickwheel cable. Gently pull this cable to free it from the logic boardconnector.The logic board will now easily come free from the case. The LCD will still be attachedto the logic board.
LCD Removal Before proceeding, first remove:Hard DriveHeadphone Connector CableLogic BoardTo remove the LCD, grasp the green connector cable, and gently pull to free it from the logic board connector. It should come out easily.
Battery Removal Before proceeding, first remove:Hard DriveHeadphone Connector Cable Logic Board To remove the battery, use a flat tool to pry the battery up. It is held on with a lightadhesive, and should come up by using just a little force. Lift the battery out of the unit.
Everything goes back in with gentle pressure and of course replacing screws and what not. All in all though, it is allot cheaper then buying a new iPod or other MP3 player :) I hope this is helpful to you
May 09, 2009 | Philips GoGear SA5285/37 Digital Media...
Ipod won't turn on
You may need a new hard drive for your iPod. Its allot easier to replace then you would think to :) If you go to the following web page there are a few video's on trouble shooting this kind of issue as well as instructions on taking apart the ipod and replacing a few of the items. Also below I have posted a step by step guide on completely disasembeling an iPod.
http://fixyouripod.weebly.com/
http://www.ifixit.com/
Mar 10, 2009 | Apple iPod nano
Water damage
It sounds to me like you need a new battery for your iPod. To order a replacement battery kit, you can go to (www.ifixit.com) There is also a free video at (http://fixyouripod.weebly.com) Below is also a step by step instruction (guide) to taking apart the iPod piece by piece so that the replacement can be done in an easy safe manner. If for any reason you have difficulties please do let me know :)
Feb 27, 2009 | Apple iPod nano MP3 Player
Garage door opens after a power surge.
Unplug the operator for 2 mins.and remove the wires to the wall control. plug the operator back in if the operator starts running  the logic board is most likely fried (bad) and should be replaced.
Nov 23, 2008 | Chamberlain Powerdrive PD422D 1/2 HP...
Error message
If it really is a "logic board" problem, then it's time to responsibly recycle the printer, and to purchase a brand-new printer; hopefully, you can find one that uses the same ink-cartridges as your current printer.
A "pro" would charge you $50 to $100 to _look_ at it, with _no_ guarantee of being able to fix it; instead, invest that money in the new printer, which you _know_ will work.
Sep 19, 2007 | Canon PIXMA iP3000 InkJet Photo Printer
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
290 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
