Question about Logitech Z-2300 Computer Speakers
One of my speakers sounds scratchy as well.
This has nothing to do with the balance or the subwooker. one speaker is just sounding bad no matter what I plug it into. I am thinking about trying to use alternate speakers since they just use a standard RCA jack.
  • 3,153 Answers
This usually points to a torn cone on the speaker itelf or dirt that has somehow gotten into the speaker coil.
if its dirt then a can of compressed air for cleaning computers sometimes does the trick but it does mean opening up the speaker after you disconnect it.
Posted on Sep 09, 2009
Sound center
Replace center channel speaker with known good one. If no longer scratchy then the voice coil of removed unit is rubbing against the magnet pole and the speaker needs to be replaced. If the replacement speaker also sounds bad, then the amp for the center channel needs repair.
Nov 23, 2013 | Yamaha RX-V490 Receiver
I have a toshiba satellite A200. Recently installed windows7 then the sound comes very scratchy and only on right side. Even the headphone aswel. I replace my laptop speaker but didn't work and I also...
Hello there, go to the menu and write down sound, look for the sound folder then open it.Right click the speakers that you are using, goto levels then click on the balance button, make sure that there both in the middle of the bars, then press apply, then ok.
Hope this helped.
Jan 30, 2013 | Computers & Internet
I have just reinstalled my Sansui component stereo system, and have a couple of problems. One is a scratchy noise on one speaker channel. The other is a seeming lack of results when I attempt to use the...
Buy some electronic contact cleaner, remove top, spray volume and balance pods and use the straw provided to target the small hole. Move controls back and forth as you apply the cleaner. If that fails! then the problem is a bad driver or audio output semiconductor.
Mar 16, 2012 | Audio Players & Recorders
Right front channel not working
try to check balance adjustment if working.
Apr 16, 2010 | Sony STR-DE475 Receiver
No sound on my Dell Dimension 3000
i would try checking the plug for your speakers to see if it is loose.
If you move the plug is there any static that comes from the speakers?
If you have headphones maybe try plugging them in to see if you have sound through them.
If you do have sound then i would say it is your speakers that are bad.
If you get no sound or scratchy sound through the headphones, then i would suspect either a loose jack connection for your audio or a dying audio chip.
Feb 14, 2010 | Dell Dimension 3000 PC Desktop
Suddenly my speaker volume is low and scratchy
Congrats, you yourself is a good troubleshooter. Just pinpointed your problem. What you just diagnoist can be easilly checked just by taking other good known speaker. If that works your speaker is short check for audio output wires. If not your card needs replacement. If need further clarifications just comment.
Aug 04, 2009 | Creative Labs Gigaworks S750 Computer...
Scratchy sound from cd/dvd combo
sounds like the speakers are either damaged or have gotten water in them and damage the laptop speakers.
Mar 29, 2009 | HP Pavilion Media Center M1090n (PC100A)...
Re: scratchy speaker sound quality
Have you tried with headphones?  Scratchy WITH heaphones. Reinstall driver. If it's NOT scratchy with headphones.  Either your speakers are blown, (which usually doesn't happen), you need to reinstall your sound card drivers, or bad settings.  Double click sound horn. Turn some volumes haflway, or mute sound channels you aren't using. Options Properties will let you show ALL sound properties. Ctrl+S makes the sound properties half size.
ReInstall Drivers: Start - Settings - Control Panel - System - Device Manager, Expand Sound Controllers, Right Click on your sound card, Click Uninstall.  Reboot and reintall.
Might ask to reinstall automatically.  Thats fine.  Install then reboot.  I prefer to cancel the install until I have rebooted.  But both ways tend to work.
Hope you don't have to change your speakers.  Need to pull your mobo to get to em. Instructions here pg. 5-55
James Mac
Sep 08, 2008 | Compaq Computers & Internet
Scratchy Sound, Major Problem
Try the speakers on another PC with good working sound. This will indicate either a speaker problem or a sound card issue.
If speakers work ok on 2nd pc, then you have a sound card issue on your pc. If speakers are still scratchy on 2nd pc.. check the metal connector end, make sure it is clean and shiny. If there is any rust or other oxidation, clean it off with a very fine grade of sand paper
Apr 28, 2008 | Logitech X-530 Computer Speakers
Scratchy noise?
Are the speakers old? The only thing that can make a random scratchy noise on the speakers as far as I know is a dirty volume knob. Try turning it all the way up and all the way down (with nothing playing) and see if that helps. If it does, blow them out with some compressed air. I'm thinking your issue is probably software / driver related though, does the scratchiness happen in other programs? WinAmp? Windows Media Player? .. if it does, you've narrowed it down to a driver-related issue, go to your sound hardware's manufacturer website and download the latest drivers.
Jun 15, 2007 | Altec Lansing 641 Computer Speakers
Logitech Z-2300 Computer Speakers Logo
211 people viewed this question
Top Logitech Audio Players & Recorders Experts
Michial Gueffroy
Jerry Umali
Are you a Logitech Audio Player and Recorder Expert? Answer questions, earn points and help others
