Question about Kenmore 71042 / 71044 Gas Kitchen Range
The oven will not heat up. I can see the pilot or
The oven will not heat up. I can see the pilot or ignitor lit up, and I can smell the gas, the oven just doesn't work sometimes and sometimes it does
  • 20 Answers
The gas valve operates on "passed through" electricity from the ignitor - if you have a marginal ignitor, then the valve will give you problems. Intermittent problems are the worst to diagnose, but the way you are describing it, my first action would be to replace the ignitor. If it doesn't work after that, then try the valve, but be prepared for the price tag cause it's kinda scary. Good luck.
Posted on Sep 06, 2009
Model FA100 serial 866FA4 pilot lites and stays lit,oven will not always start...acts like gas valve is not always opening??? could this be a problem with pilot safety??
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or
Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Mar 04, 2011 | Blodgett BC-14G Gas Single Oven
Smell gas when oven lit
Oven not Working or Oven not Heating
heatman101
Nov 09, 2010 | Amana ARGS7650SS Gas Kitchen Range
I have a gas stove. The oven is not getting gas. The pilot light is lit, and the range works normally. Do you have any idea why the oven is not getting gas?
heatman101
Oct 16, 2010 | Hotpoint Ovens
My oven is not lighting and it doesn't even smell like it is getting gas to it. I do not see any pilot light lit but even when I try to light it there is nothing yet the stove works fine. Any idean of what...
heatman101
ghdhdg
Jun 02, 2010 | Kenmore 40494 / 40495 / 40499 Electric...
It won't heat up... even though there is a flame
Check The Power Source
If the gas oven won't turn on, the first thing to do is check the power source. Most modern gas ovens are electrically powered. Check to make sure the oven is plugged in and the breaker isn't tripped.
Check the Heat Source
When a gas oven won't heat, the pilot light can also be set too low; if the pilot is lit but the oven isn't catching, adjust the flame.
Newer gas ovens use electric ignitors that produce sparks. If the oven doesn't heat, the ignitor could be broken.
Feb 05, 2010 | Ovens
The oven pilot does not light. The broiler will not work. The only thing that does is the light. GE XL44 range. The burners light and the pilots stay lit.
    If you have standing pilots, make sure the pilot for the oven/broiler is lit as well.  When you turn the thermostat up to call for heat, you should see the pilot get larger. That larger pilot flame heats a hydraulic sensor and opens the main burner valve.
    Jan 10, 2010 | GE Profile Spectra JGBP90 Gas Kitchen...
    Tappan TGFS26C, Oven igniter not even
    Lets take the oven problem first. Sounds like you have a Hot Surface Ignitor problem. This is the device that glows and lights the burner. You can buy a universal ignitor at most appliance or heating and air conditioning supply houses. Note carefully how the old one is mounted. You may have to make some adjustments to mount the new ignitor, but it MUST be close to the gas burner like the old one! You don't smell gas because the gas valve will not open until the ignitor is hot. All ignitors work with the same voltage, so simply connect the new wires to the old ones.
    I'm not certain if you have a standing pilot for the stove top burners or electronic ignition. Remove the top panel to check. If you have a gas pilot, relight it. If electronic ignition, clean the ignitors. If that does not solve the problem you may have to call a technician, as these systems can be complex.
    Hope this helps.
    Ray
    Nov 20, 2008 | Tappan TGF363 Gas Kitchen Range
    Oven does not heat
    Ignitor, good luck getting the old one out. That is why I'm here.
    Jun 26, 2008 | Tappan TGF320 Gas Kitchen Range
    Roper gas oven won't work
    replace the thermal coupling on the pilot make sure it is in the flame of the pilot it looks like a copper wire or tube if its bad it wont open the gas valve after the pilot heats it up
    Mar 02, 2008 | Ovens
    Kenmore 71042 / 71044 Gas Kitchen Range Logo
    89 people viewed this question
    Top Kenmore Kitchen Ranges Experts
    Dan Webster
    Dan Webster
    Mike Carew
    Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
