Question about RTO Esab Handy Plasma 550 W/25' Pt 31XL Torch 0558002612
Lotos 520d plasma part not working, arc works great
Hooked everything up and welding is great although i have not tried the tig but plasma just blows air and nothing else
  • 25 Answers
Be sure you have the ground is connected to the postive terminal on the bottom of the front of the machine. Air pressure should be 70psi as the air flows out of the torch.
Posted on Oct 18, 2009
    Problem Solver:
  • 5 Answers
Check ur ground
Posted on Sep 11, 2009
What polarity do I use for tig welding aluminum, and what color electrode for miller hf-p dial arc
Jackie, watch the linked videos on tigging aluminum. "I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
May 31, 2016 | Miller Welding Tools
I have a mishto 220 mig tig mma I can get the arc to work fine but the mig there's no arc at all the machine sounds like its welding but no arc at the gun I'm using gassless wire I thought it may be an...
They told me at welding school the mig transformer has a different slope (whatever that means?) to the tig and mma transformer so I am a little surprised at your question. The implication is two transformer are needed for the three types of welding and for tig and mig a dc converter and also for dc mma welding.
From your description it seems as though welding current is not arriving at the tip of the mig torch or the current is arriving in the wrong form.
You say the mma is fine but you didn't say whether it is fine on ac welding, dc welding or both. I have not tried mig welding with ac and have no idea whether it would be successful but I imagine a lot of sparks and not much welding. The problem could be the rectifier unit is either not working or is switched out of the circuit.
Polarity is important too with dc tig and mig welding.
I hope this provides food for thought.
Feb 04, 2015 | Welding Tools
My tig welder wont arc unless I touch the metal with it
my guess would be the type of welding machine you have.usually there is extra switch which says start control also continious cycle , sometimes smaller machines dont have these switches to allow a wider variety of tweeking the welder ,also its ok if you have to touch the base metal cause thats what starts the contact with the work peice ,keep a arc after touching about 1/4 inch away from work peice ,also a good steady hand rest will make a good welder in any situation this should allow the arc to remaim stable with a comntinious weld arc puddle. happy welding
May 22, 2010 | Miller SYNCROWAVE 250 DX TIG RUNNER WELDER...
No full arc
the spark that you see when you touch work peice is high frequency,recheck connections like good ground (tight and clean)on the unit and work peice.no ground no fire.
Jun 03, 2009 | Welding Tools
I NEED TO AIR ARC CAN THIS MACHINE DO THIS AND HOW
hook up to the stick position on the machine - to work + to the stinger hook stinger to the air arc hook up air to the air arc turn welder up to top {350}turn air on at the push button on the air arc & get busy
Apr 09, 2009 | Miller DYNASTY 350 TIG WELDER w/TIG TORCH...
GIANT 200AMP INVERTER ARC WELDER NO POWER TO THE LEADS
remove the fan from the circuit and try it then, does it weld ok with the fan removed?
Dec 13, 2008 | Inverter 220 Volt Tig Arc Welder
Mig problem
For certain type of work TIG is required, like welding chrome moly for some racing organizations. Intricate work, like gunsmithing is also well suited to TIG. TIG is used by many auto restorers who prefer a more precise, perfect finish that requires little to no finish work. TIG is most similar to gas welding in technique, so if you've done oxy-fuel welding, TIG should be a natural transition. MIG is required by law and by insurance companies in many localities for structural repair of automotive frames. MIG is also much easier to learn and faster to weld. For doing other types of welding, like sheet metal, it can be a matter of personal preference. For an auto body repair shop or a novice welder, a MIG is a good, practical all-around welder.
Aug 27, 2008 | Troy MIG100 90-Amp. Wire Feed Welder
How to TIG Weld
TIG stands for Tungsten Inert Gas welding. Also called GTAW (Gas Tungsten Arc Welding) and Heliarc® which was Linde's trade name for the TIG process when it was introduced many years ago. The arc is started with a tungsten electrode shielded by inert gas and filler rod is fed into the weld puddle separately. A slower process than MIG, it produces a more precise weld and can be used at lower amperages for thinner metal and can be used on exotic metals. TIG does require quite a bit more time than MIG to learn. It is similar in technique to gas welding.
Aug 27, 2008 | Radnor Model 105Z55 Push On Smooth TIG...
RTO Esab Handy Plasma 550 W/25' Pt 31XL Torch 0558002612 Logo
519 people viewed this question
Top RTO Welding Tools Experts
Bill Boyd
Are you a RTO Welding Tool Expert? Answer questions, earn points and help others
