WATER JUST KEEPS RUNNING OUT AND NOT FILLING THE WASHER
  • 1,543 Answers
If the water is running out the drain (not leaking onto the floor) make sure the drain pipe the hose goes into is at least 34 inches higher than the bottom of the washer, and that it is not sealed. This will prevent syphoning.
Posted on Sep 06, 2009
WATER KEEPS ON FILLING
I am not very clear with this question, but my friends also facing such problems.--www.doinggroup.com. Email id: market@doinggroup.com. yours Eko.
Dec 17, 2013 | Frigidaire GLWS1439F Top Load Washer
Unit is filling up half way or so and just keeps running, but will not fill up all the way almost like water is draining and running at same time
Tub keeps filling does not overflow.
Solution:
Drain hose must be 36 inchs above floor level to prevent siphoning.
Dec 26, 2009 | Roper RAS8445KQ Top Load Washer
When you turn it on keeps filling water and it over flows , second problem some times when it runs it keeps running to all the cycles never stops tell you manually stop it
Find the tube from the tub to the water level switch. Remove the tube from the switch and blow the sand and stuff out the line. Pump out any water in the washer and restart. 6b0c2cb.jpg
May 16, 2009 | GE WBSR3140DW Top Load Washer
Water keeps filling the washer
If the washer keeps filling and overfilling then unplug the machine and see if the water still continues to come in. If this is the case, you have a bad water valve. If the washer just keeps filling and never gets to the top then your drain hose is shoved too far down into your house standpipe and must be pulled up and an air gap established.PART NUMBER 285805 @ 30.00 FOR WATER VALVE
Apr 08, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Water will not stop filling washer
cut power to washer ..does it stop filling? suspect water level control or small hose to it is off ..keeps running in? shut off water to washer and change fill valve where hoses attach..just won't fill to top and start? raise level of drain hose up and be sure it is not too tight in drain pipe to prevent siphoning
Jul 15, 2008 | Whirlpool Washing Machines
Roper washer
I have the same damn issue with my Samsung washing machine(Top Loader) Not quite sure why it does it.Help please really annoying.
Jun 05, 2008 | Whirlpool LSB6200KQ Top Load Washer
Washer won't fill
On the drain valve there must be some dirt that does not let the valve close or the valve must be defective and needs to be replaced. By the way you did not mention the make of the washer.
May 11, 2008 | Washing Machines
Water Just Keeps Filling!
replace the water inlet valve, the valve that the black hat and cold lines connect to
Apr 19, 2008 | Kenmore 3.5 cu. ft. King Size Capacity Top...
Washer constantly fills with hot water even when turned off.
Sounds like a bad mixing valve. To verify that it is the valve you need to turn off the washer when it is filling. If water keeps running, replace the valve, Cost is under $50. for most washers.
Jan 03, 2008 | Washing Machines
Washing Machines Logo
96 people viewed this question
Top Washing Machines Experts
